[Sammelthread] Asus Sabertooth 990fx
Inhalt:
  • Spezifikationen
  • Bilder
  • Bios
  • Review´s / Test´s
  • Downloads
  • Kompatibilität
  • Preis
  • FAQ
Spezifikationen:
CPU
AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
Supports AM3+ 32 nm CPU
Supports CPU up to 8 cores
Supports CPU up to 140 W
AMD Cool 'n' Quiet™ Technology​
Chipset
AMD 990FX/SB950​
AMD 990FX/SB950
Memory
4 x DIMM, Max. 32GB, DDR3 1866/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture​
Expansion Slots
3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8) *1
1 x PCIe 2.0 x16 (x4 mode, black)
1 x PCIe 2.0 x1
1 x PCI​
Storage
AMD SB950 controller :
6 x SATA 6Gb/s port(s), brown
Support Raid 0, 1, 5, 10
JMicron® JMB362 controller :
2 x SATA 3Gb/s port(s), black
1 x Power eSATA 3Gb/s port(s), green
1 x eSATA 3Gb/s port(s), red​
LAN
Realtek® 8111E , 1 x Gigabit LAN Controller(s)​
Audio
Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- Blu-ray audio layer Content Protection
- ASUS Noise Filter
- Optical S/PDIF out port(s) at back panel
IEEE 1394
VIA® 6308P controller
2 x IEEE 1394a port(s)
(1 at mid-board, 1 at back panel)​
USB Ports
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
14 x USB 2.0 port(s) (10 at back panel, black+red, 4 at mid-board)​
Special Features
ASUS Dual Intelligent Processors 2 with DIGI+ VRM
TUF ENGINE! Power Design :
- 8 +2 Digital Phase Power Design
- TUF Components (Alloy choke, Cap. & MOSFET; certified by military-standard)
- ASUS DIGI+ VRM Utility
- E.S.P. : Efficient Switching Power Design
Ultimate COOL! Thermal Solution :
- TUF CeraM!X Heatsink Coating Tech.
- TUF Thermal Radar​
ASUS Exclusive Features
- MemOK!
- AI Suite II
- Anti-Surge
- ESD Guards
- Front Panel USB 3.0 Support
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Profile
- ASUS EZ Flash 2
- ASUS MyLogo 2
- Multi-language BIOS
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector​
Back I/O Ports
1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 3Gb/s
1 x IEEE 1394a
1 x LAN (RJ45) port(s)
2 x USB 3.0
10 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)​
Internal I/O Ports
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x COM port(s) connector(s)
6 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s) (4 -pin)
4 x Chassis Fan connector(s) (3 x 4 -pin, 1 x 3 -pin)
1 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x Clear CMOS jumper(s)​
Accessories
User's manual
ASUS Q-Shield
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x TUF Certification card(s)
1 x TUF 5 Year Warranty manual(s) (by region)​
BIOS
32 Mb Flash ROM, UEFI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2,​
Manageability
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc Drivers
Anti-virus software (OEM version)
ASUS Update
ASUS Utilities​
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )​
Bilder:
Bilder von Huddel (nochmals danke)
Bilder von JACK RABBITz
(Quelle: User Huddel, Asus, JACK RABBITz)
Bios:
(0402)
Review´s/Test´s
Deutsch
HWLUXX
hartware.net
pcgameshardware
Tom´s Hardware
Englisch
guru3d.com
hardwarecanucks.com
legitreviews.com
Downloads
ASUS Sabertooth Downloadbereich
Asus FTP-Server derzeit wieder mal offline :-(
Betabios 0607 -Fan ignore Bug gefixed, CPU-Lüfter Monitor lies sich nicht abschalten, dadurch kam eine Fehlermeldung beim Booten
Bios 0705
1. Enhance RAID expansion card compatibility.
2. Enable support for Spanish and Russian Language.
3. Enhance RAID0 performance with SB950 native SATA ports.
4. Enable support for UEFI RAID Driver to support RAID partition above 2.2TB
Bios 0810
Bios 0813
1. Improve memory compatibility
2. Improve system stability
Bios 0901
Probleme mit X6 CPU´s, Board startet nicht mehr!
Bios 1102
1.Improve system stability.
2.Enhance compatibility with some USB devices.
3.Patch system hanged when use AM3 1090T or 1100T CPU.
Bios 1208
Bios 1304
Bios 1503
Kompatibilität
Arbeitsspeicher
-Kingston HyperX 2133Mhz 4x 2GB
-G.Skill Ripjaws-X 8GB Kit
-G.SKILL 8GB Kit DDR3-1600 F3-12800CL8D-8GBECO / 1,35V
inkompatibler Arbeitsspeicher
-2x2GB G.Skill F3-10666CL8D-4GBRM 8-8-8-24 1,5v (kein Boot möglich)
Luftkühlung
-Prolimatech Megahalems (mit Retentionmodul)
Wasserkühlung für Chipsatz
Preis
HWLUXX
FAQ
Asus Supportforum
Ich hoffe das geht erstmal soweit (Ist mein erster Sammelthread :)), ich versuche alles aktuell zu halten, nun her mit den Erfahrungen und Informationen...
Moin Gemeinde,
ich habe hier eine Sache die ich mir nicht so recht erklären kann. Hab nun einen FX 8350 in meinen Rechner gebaut.
Meine Temps. überwache ich mit Core Temp als Minianwendung.
Das seltsame ist, bei Volllast passt auch alles, im Leerlauf springt mir die Anzeige zwischen 15 - 38 Grad hin und her.
Das Verhalten hatte ich vor mit meinem 965BE nicht.
Die CoreTemps werden falsch ausgelesen. Du kannst dich nur nach der CPU Temp vom Mainboard orientieren.
Sprich also das was ASUS Thermal Radar mir sagt ??
Was mich wundert ist das pendeln, das die Temps nicht stimmen, dachte ich mir schon, aber das pendeln hatte ich vorher nicht.
Moin Gemeinde,
Hey, kurze Frage: ich plane genau den selben Umstieg in Sachen CPU. Welche UEFI-Version verwendest Du? Musstest Du diese vor dem Gebrauch updaten?
Danke!
@JACK RABBIT,
Ich hatte vorher das BIOS Version 1604 eingelesen. Stand eh an und mit der Vorgänger Version wollte ich nicht lange probieren.
Ich komme mit dem blöden Bios nicht klar.
Hab nun die Kiste auf 4.4 GHZ bei 1.380 Volt und 54° bei Volllast. Das ganze hab ich erreicht mit einem FSB von 220MHZ. Speicher bin ich noch nicht weiter, der läuft mit 588MHZ.
So nun hab ich gedacht ok, wenn es so läuft nehme ich den FSB wieder runter auf 200 und dafür einen Multi von 22. Klappt nicht, ich hab beim starten dann einen Multi von 20.5 und bei Volllast macht er ganz seltsame Sachen. Speicher passt dann überhaupt nicht, manchmal meckert er beim booten rum das Overclocking nicht läuft und will ins BIOS.
Hab mir schon mal ein paar Bilder zusammengesucht, von den BIOS Einstellungen, aber die sind alle etwas älter, das passt bei mir nicht so recht. Einige Werte sagen mir auch nichts, muss ich gestehen.
Kann mir da mal wer ein paar Tips geben..
Danke
So nun läuft er wie ich es wollte, nur Speicher hab ich noch Arbeitsbedarf.
Zur Zeit läuft der im JEDEC Mode mit 666 MHZ auf 9/9/9/24/34 bei 1,50 Volt.
Ich hab aber die XMP-1866 Spezifikation mit 933 MHZ bei 9/10/9/27/48/2T bei 1,50 Volt.
Ich finde aber keine XMP Einstellungen ??
So sieht es im Moment aus:
[/URL][/IMG]
Danke!!!
@JACK RABBIT,
Danke
@Dummbatz. Im Bios unter "Ai Overclock Tuner" die Option DOCT (oder wie sie nochmal heißt). Dann erscheint unten ein neues Menü und dort wählst du "Profile 1" => XMP
Danke Reous,
Schau ich mir Morgen mal an.
Da bin ich auf Manuell, weil ich mit der Einstellung mal Probs hatte.
ASUS Sabertooth 990FX in der 3. Auflage ist ''PCIe 3.0 Ready''
Wie in einem früheren post schon mal angekündigt hier jetzt genaueres zum ""neuen Sabertooth 990FX""
Erstes AMD-Mainboard mit PCIe 3.0
ASUS hat auf der CES in Las Vegas das weltweit erste Mainboard für AMD-Prozessoren gezeigt
dass kompatibel mit dem PCI Express 3.0 Standard ist:
Die dritte Revision des ASUS Sabertooth 990FX hat außerdem eine neue Kühlung bekommen, die durch eine um 50 % größere Kühlfläche deutlich mehr Wärme abtransportieren kann.
Außerdem gibt es eine Echtzeit-Temperaturauslesung (Thermal Radar), aber das Highlight ist natürlich die für AMD-Plattformen erstmalige Unterstützung von
PCI Express 3.0 - offiziell "PCIe 3.0 Ready", weil immer noch die entsprechenden Erweiterungskarten fehlen, mit denen PCIe 3.0 voll ausgenutzt und getestet werden kann.
Das ASUS Sabertooth 990FX ist mit dem AMD 990FX Chipsatz ausgestattet und unterstützt die aktuelle AMD Sockel AM3(+) Prozessoren wie die FX, Phenom II, Athlon II und Sempron 100 Serien.
Auch gewährt ASUS wieder bei Registrierung eine 5-jährige Garantie wie schon bei den bisherigen SABERTOOTH 990FX Boards.
Eine Besonderheit, die sonst nur bei absoluten High-End Mainboards anzutreffen ist, ist die große Anzahl an vier-poligen Lüfteranschlüssen. Es stehen fünf 4-polige und ein 3-poliger Anschluss bereit.
Ganze fünf Stück stehen für PWM-Lüfter bereit. Ein drei poliger Anschluss gesellt sich noch dazu. Und natürlich darf auch Thermal Radar nicht vergessen werden.
In den temperaturkritischen Zonen des Mainboards wertet es entsprechende Sensoren aus, um beispielsweise die Lüftersteuerung zu optimieren.
Im inzwischen traditionellen EFI BIOS können
die Spannungen können jeweils in folgenden Bereichen verändert werden:
CPU Offset Voltage bis +-0.700 Volt in 0.006250V-Schritten
CPU/NB Offset Voltage bis +-0.700 Volt in 0.006250V-Schritten
CPU VDDA Voltage 2.200 - 2.800 Volt in 0.006250V-Schritten
DDR3 Voltage 1.20 - 2.50 Volt in 0.00625V-Schritten
NB Voltage 0.800 - 1.512 Volt in 0.006250V-Schritten
NB HT Voltage 0.800 - 1.512 Volt in 0.006250V-Schritten
NB 1.8V Voltage 1.800 - 2.800 Volt in 0.005V-Schritten
SB Voltage 1.100 - 1.800 Volt in 0.005V-Schritten
VDD PCIe Voltage 1.100 - 2.200 Volt in 0.005V-Schritten
VDDR Voltage 1.200 - 1.800 Volt in 0.005V-Schritten
Die Taktraten bzw. Multiplikatoren können jeweils in folgenden Bereichen verändert werden:
Referenz-Takt 100 - 600 MHz
Speichertakt DDR3-800/1066/1333/1600
CPU/NB Frequenz 7x - 10x Referenztakt
HyperTransport-Link 800 MHz - 2.0 GHz in 200-MHz-Schritten
PCI Express Takt 100 - 150 MHz
Voraussichtlicher Preis ca. 170 EURO
Quelle
Ein erstes/r Artikel/Review dazu
ASUS Sabertooth 990FX - Artikel Hartware.net
Ich hoffe mal es besitzt noch höhere Ram Multis :d.
Ansonsten stört mich nach wie die min Ram Voltage. Hätten da ruhig weiter runter können.
@ Reous
nochmals schönen Dank, nun läuft er so wie er soll, ich es haben möchte.
Hab bei dem Kram immer Schiss das Windows zu killen, wie handhabt Ihr das wenn Ihr CPU so durch testet ??
Hab zwar immer ein Update, aber das ja auch ziemlich aufwendig wenn man das immer wieder neu einlesen muss.
Grüße
Dummbatz
Ich habe bis jetzt noch nie ein Windows durch OC Versuche gekillt. Wenn du trotzdem Angst hast was kaputt zu machen kannst du auch unter Linux testen. Da ich langsam versuche auf Linux umzusteigen, mach ich das auch des öfteren.
Hallo zusammen,
ich bräucht mal eure Hilfe....
Entweder bin ich zu blöd oder blind, aber ich finde den Punkt im BIOS nicht wo ich RAM der Graka zuweisen kann. Hat mal jemand einen Tip?
Außerdem könnte mir mal jemand verraten warum ich beim besten Willen nicht übertakten kann? Win7 stürzt im dem Fall sofort ab, auch bei kleinsten Übertaktungen.
Gruß,
Mansour
Auszug CPUZ:
Number of processors 1
Number of threads 6
Processor 1 ID = 0
Number of cores 6 (max 6)
Number of threads 6 (max 6)
Name AMD FX-6100
Codename Zambezi
Specification AMD FX(tm)-6100 Six-Core Processor
Package Socket AM3+ (942)
CPUID F.1.2
Extended CPUID 15.1
Core Stepping OR-B2
Technology 32 nm
TDP Limit 95 Watts
Core Speed 1404.7 MHz
Multiplier x FSB 7.0 x 200.7 MHz
Stock frequency 3300 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP
L1 Data cache 6 x 16 KBytes, 4-way set associative, 64-byte line size
L1 Instruction cache 3 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 3 x 2048 KBytes, 16-way set associative, 64-byte line size
L3 cache 8 MBytes, 64-way set associative, 64-byte line size
FID/VID Control yes
Min FID 7.0x
# of P-States 7
P-State FID 0x17 - VID 0x0B - IDD 18 (19.50x - 1.412 V)
P-State FID 0x14 - VID 0x0B - IDD 18 (18.00x - 1.412 V)
P-State FID 0x11 - VID 0x15 - IDD 11 (16.50x - 1.287 V)
P-State FID 0xE - VID 0x1A - IDD 9 (15.00x - 1.225 V)
P-State FID 0x8 - VID 0x24 - IDD 7 (12.00x - 1.100 V)
P-State FID 0x2 - VID 0x2D - IDD 5 (9.00x - 0.987 V)
P-State FID 0x10C - VID 0x34 - IDD 4 (7.00x - 0.900 V)
PStateReg 0x800001B2-0x00001617
PStateReg 0x800001B2-0x00001614
PStateReg 0x8000016C-0x00002A11
PStateReg 0x8000015C-0x0000340E
PStateReg 0x80000145-0x00004808
PStateReg 0x80000130-0x00005A02
PStateReg 0x80000124-0x0000684C
PStateReg 0x00000000-0x00000000
Package Type 0x1
Model 00
String 1 0x0
String 2 0x0
Page 0x0
CmpCap 5
Base TDP 14 Watts
Boosted P-States 2
Max non-turbo ratio 16.50x
Max turbo ratio 19.50x
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Attached device PCI device at bus 0, device 24, function 4
Attached device PCI device at bus 0, device 24, function 5
Chipset
Northbridge AMD RD9x0 rev. 02
Southbridge AMD SB950 rev. 40
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 16384 MBytes
Channels Dual
Memory Frequency 802.7 MHz (1:4)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Bank Cycle Time (tRC) 41
Uncore Frequency 2006.7 MHz
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 4096 MBytes
Max bandwidth PC3-10700H (667 MHz)
Part number CMZ8GX3M2A1866C9
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.2
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-16-23 @ 444 MHz
JEDEC #2 7.0-7-7-19-27 @ 518 MHz
JEDEC #3 8.0-8-8-22-30 @ 592 MHz
JEDEC #4 9.0-9-9-24-34 @ 666 MHz
XMP profile XMP-1866
Specification PC3-14900
Voltage level 1.500 Volts
Min Cycle time 1.071 ns (933 MHz)
Min tRP 9.64 ns
Min tRCD 10.71 ns
Min tWR 15.00 ns
Min tRAS 28.93 ns
Min tRC 50.64 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 6.0-7-6-18-32-2T @ 622 MHz (1.500 Volts)
XMP #2 9.0-10-9-27-48-2T @ 933 MHz (1.500 Volts)
DIMM # 2
SMBus address 0x51
Memory type DDR3
Module format UDIMM
Size 4096 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
Min tRP 9.64 ns
Min tRCD 10.71 ns
Min tWR 15.00 ns
Min tRAS 28.93 ns
Min tRC 50.64 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 3
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 4096 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
Min tRP 9.64 ns
Min tRCD 10.71 ns
Min tWR 15.00 ns
Min tRAS 28.93 ns
Min tRC 50.64 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 4
SMBus address 0x53
Memory type DDR3
Module format UDIMM
Size 4096 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.2
Min tRP 9.64 ns
Min tRCD 10.71 ns
Min tWR 15.00 ns
Min tRAS 28.93 ns
Min tRC 50.64 ns
Min tRFC 160.00 ns
Min tRTP 7.50 ns
Min tRRD 7.50 ns
Command Rate 2T
DIMM # 1
Monitoring
Mainboard Model SABERTOOTH 990FX (0x0000045B - 0xEA31EDC0)
LPCIO
Hardware Monitors
Hardware monitor ITE IT8721
Voltage 0 11.73 Volts [0xEB] (+12V)
Voltage 1 4.91 Volts [0xEA] (+5V)
Voltage 2 0.90 Volts [0x4B] (CPU VCORE)
Voltage 3 1.64 Volts [0x89] (VIN3)
Voltage 4 0.30 Volts [0x19] (VIN4)
Voltage 5 3.18 Volts [0xD4] (+3.3V)
Voltage 6 1.63 Volts [0x88] (VIN6)
Voltage 7 1.81 Volts [0x97] (VIN7)
Voltage 8 1.69 Volts [0x8D] (VIN8)
Temperature 0 38°C (100°F) [0x26] (CPU)
Temperature 1 32°C (89°F) [0x20] (Mainboard)
Fan 0 527 RPM [0x502] (CPU)
Fan 2 474 RPM [0x590] (FANIN2)
Fan PWM 0 0 pc [0x0] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
Hardware monitor NVIDIA NVAPI
Voltage 0 0.95 Volts [0x3B6] (VIN0)
Temperature 0 32°C (89°F) [0x20] (TMPIN0)
Fan 0 1710 RPM [0x6AE] (FANIN0)
Fan PWM 0 40 pc [0x28] (FANPWMIN0)
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
Name NVIDIA GeForce GTX 560 Ti
Revision A1
Memory size 1024 MB
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x1462)
Model ID 0x1200 (0x2382)
Performance Level Default
Core clock 50.5 MHz
Shader clock 101.0 MHz
Memory clock 135.0 MHz
Performance Level 2D Desktop
Core clock 405.0 MHz
Shader clock 810.0 MHz
Memory clock 324.0 MHz
Performance Level Unknown
Core clock 910.0 MHz
Shader clock 1820.0 MHz
Memory clock 2100.0 MHz
Software
Windows Version Microsoft Windows 7 (6.1) Home Premium Edition Service Pack 1 (Build 7601)
DirectX Version 11.0
@Mansour
Ich schätze dass du die von dir gesuchte Option auch nicht finden wirst. :shake: :shake: :shake:
Das Sabertooth hat KEINE integrierte Grafik und deshalb kannst du deiner Grafikkarte auch keinen weiteren Speicher zuweisen.
Dazu wäre entweder ein Board mit integrierter GraKa nötig oder ein anderes Board auf dem du eine CPU mit integrierter GraKa - Einheit hast.
oki doki :coffee:
fuzzy
Die PC Zusammenbauer - und Supporterliste
Hi fuzzy,
danke für die Antwort.
Hast Du noch einen Tip warum ich nicht OC kann?
Gruß,
Mansour
Win7 x64 Installation bricht ab
N'abend allerseits,
ich habe hier ein kleines Problem und finde keine Lösung. Vielleicht könnte mir jemand weiterhelfen?
Mainboard = Asus Sabertooth 990FX
CPU = AMD FX6300
Mem ? Corsair Vengeance CMZ16GXX3M2A1866C9 (16 GB - 2 Module a 8 GB)
Graka = EVGA GT560TI (Nvidia)
Festplatte = diverse
Rechner startet einwandfrei und ich komme ins Bios. Habe mehrere Festplatten (Samsung 500 GB, Samsung 160 GB, Samsung SSD 124 GB). Egal welche Festplatte ich angeschlossen habe, ich starte die Win7 Installation von CD, es erschein der weisse Ladebalken, danach das Microsoft Logo und darunter ein kleiner Ladebalken und nach ca. 10 Sekunden schaltet der Rechner automatisch aus. Dies passiert bei jeder Festplatte oder der SSD (immer nur eine einzelne angesteckt). Habe auch schon einen Win7 USB Stick mit integrierten Treibern von der Sabertooth CD erstellt (mit RT7 Lite) ... Es passiert genau dasselbe. Ich weiss nicht mehr weiter.
Gruss
Oliver
Hast wahrscheinlich schon nachgeschaut aber Temps sind in Ordnung und Lüfter drehen alle?
Installation mal mit nur einem Ram Riegel probiert?
Ja, temps i.O.und Lüfter laufen einwandfrei. Ja, auch mit einem Riegel identischer Fehler ...
Gruss
Oliver
Nur aus Neugier, wie installierst du Windows7? Im UEFI oder im normalen Modus? Versuch mal bei der F8 Bootauswahl das Laufwerk ohne UEFI davor.
Auch das habe ich probiert. mit F8 in die Boot-Auswahl und dann nur die Platte ausgewählt (ohne UEFI). Mittlerweile erscheint der Windows Startbildschirm (ohne das ich irgendwas verändert hätte) und es läuft bis zum "Entpacke Dateien" ... Genau nach 2% geht der Rechner einfach aus. Egal ob mit Samsung Festplatte oder ob mit SSD.
Gruss
Oliver
@omg1010
Evtl. nochmal alle Steckverbindungen lösen, Kabel/Stecker kontrollieren und wieder "sicher" verbinden.
Was für ein Netzteil benutzt du? Auf dem Board den 24-pol UND den 4/8-pol angeschlossen?
Richtigen, festen Sitz des Kühlers (welcher) kontrollieren, evtl. nochmal abnehmen, WLP erneuern und wieder montieren.
??Möglicherweise liegt's aber auch an deinen 2 x 8GB RAM Modulen?? Wer weiß :confused:
Wenn der Rechner ^^so einfach ausgeht^^ wie du schreibst, scheint's ein Hitzeproblem zu geben, oder dein NT verteilt zu wenig Spannung.
good luck :coffee:
fuzzy
Leute, auf dem Aufkleber rechts neben den Speicherbänken müsste normal die Seriennummer draufstehen oder ?
Und nicht nur da. Die steht auch auf einem Sticker auf dem Karton ...
Lasse gerade MemTest laufen und bekomme viele Fehler. Ich muss die beiden Module mal einzeln in verschiedenen Bänken testen. Wahrscheinlich liegts ja daran. Leider habe ich kein 2. Mainboard um die Speicher darin zu testen.
Gruss
Oliver
Ja das Problem ist, dass ich das Board hier im Forum gekauft habe.
Die Nummer auf der Rechnung, steht auf dem Karton unterm dem Strich code,also unter UPC und nicht bei Serial No:
Und der Aufkleber auf dem Board hat eine ganz andere Nummer....
Hallo evtl.auch hilfreich...
Für Samsung Festplatten gibt es ein Patch
Samsung F3 and F3EG Firmware Patch/Update
Firmware patch/update for certain Samsung F3 and F3EG drives.
This patch code is released in order to solve the compatibilty problem between some motherboards (the AMD SB850 chipset and the Intel P67/H67 chipset) and Samsung-brand hard drives, F3 and F3EG models only.
This is relevant for Samsung-model internal drives with the following model numbers:
F3.exe - HD323HJ / HD502HJ / HD503HI / HD103SJ / HD105SI
Download the F3.exe patch file here.
F3EG.exe - HD153WI / HD203WI
Download the F3EG.exe patch file here.
ich bin gerade nochmal im UEFI gewesen und da ist mir aufgefallen das es nicht mehr die Funktion gibt den PC automatisch um eine bestimmte Uhrzeit zu starten oder habe ich es nur übersehen?
Ich könnte so eine Funktion z.Z. gut gebrauchen, die alten Mainboards die ich bisher hatte, hatten alle diese Funktion.
hoffe bin hier richtig habe auch das borad und richtige problem bein OC. Bin eigentlich viel im PCGH unterwegs aber da hier ein fredd für das borad gibt frage einfach mal hier ob ihr mir helfen könnt. Ich mache mal ein linki zu mein problme. ab Post 18 gehts los
Wie im anderen Forum schon geschrieben wurde, stelle LLC mal auf High. Der 8120 sollte bei 4GHz so um die 1.25 bis 1.30v benötigen.
