[Sammelthread] Asus P5Q / P5Q3 Deluxe (Intel P45) [4]
ASUS P5Q/P5Q3 Deluxe
Übersicht:
1. Allgemein
  • 1.1 Layout
  • 1.2 Features
  • 1.3 Technische Daten
  • 1.4 BIOS Screens
  • 1.5 Lieferumfang
2. Nützliches
  • 2.1 Informationen
  • 2.2 FAQ
  • 2.3 Reviews
  • 2.4 Kompatibilitätsliste
1.1 Layout:
Quelle: asus.de
1.2 Features:
- PCIe 2.0
- CrossfireX Ready
- Dual-Channel DDR2 1200
- ASUS True 16-Phase Power Design
- ASUS EPU-6 Engine
- ASUS Express Gate SSD
- ASUS Drive Xpert
- AI Nap
- Stack Cool 2
- Fan Xpert
- DieHard BIOS
- Q-Shield
- Q-Connector
- EZ-Flash 2
- O.C. Profile
1.3 Technische Daten:
CPU
LGA775 socket for Intel® Core™2 Extreme/Core™2 Quad/Core™2 Duo/Pentium® dual-core/Celeron® dual-core/Celeron® Processors
Compatible with Intel® 05B/05A/06 processors
Supports Intel® 45nm Multi-Core CPU
Chipsatz
Intel P45/ICH10R with Intel® Fast Memory Access(FMA) support.
Front Side Bus
1600/1333/1066/800 MHz
Memory
4 x DIMM, max. 16GB, DDR2 1200/1066/800/667MHz, non-ECC, un-buffered memory
Expansion Slots
2 x PCI Express 2.0 x16 slots, support ATI CrossFireX™ technology at x8 link
(PCIe x16_1 blue, PCIe x16_2 black*)
1 x PCI Express x16 slot at max. x4 link(black)
2 x PCI Express x1 slots
2 x PCI slots
*PCI Express x16_2 slot (black at max. x8 link)
Southbridge
- 6 x SATA 3Gb/s
- Intel® Matrix Storage Technology with RAID 0, 1, 5, 10 support
Marvell 88SE6121
- 1 x UltraDMA 133/100/66 for up to 2 PATA devices
- 1 x External SATA 3Gb/s port (SATA On-the-Go)
Silicon Image Sil5723 (Drive Xpert technology)
- 2 x SATA 3Gb/s
- Supports EZ Backup and Super Speed functions
LAN
Dual Gigabit LAN controllers
Marvell 88E8056/88E8001® Gigabit LAN controller featuring AI NET2,Teaming and Redundant
Audio
ADI® AD2000B 8-channel High Definition Audio CODEC
- Support Jack-Detection, Multi-Streaming, and Front Panel Jack-Retasking
- Coaxial/Optical S/PDIF out ports at back I/O
- ASUS Noise-Filtering
IEEE 1394
LSI®L-FW3227 controller supports 2 x IEEE 1394a ports(one at mid-board; one at back panel)
USB
Max. 10 USB2.0/1.1 ports(4 ports at mid-board, 6 ports at back panel)
ASUS AI Lifestyle Features
Back Panel I/O Ports
1 x PS/2 Keyboard/Mouse combo port
1 x Optical + 1 x Coaxial S/PDIF Output port
1 x External SATA port
1 x IEEE1394a port
2 x LAN (RJ45) ports
6 x USB 2.0/1.1 ports
8-channel Audio I/O ports
Internal I/O Connectors
2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
1 x COM connector
1 x TPM connector
6 x SATA connectors (red)
2 x Drive Xpert SATA connectors (orange)
1 x CPU Fan connector
3 x Chassis Fan connector
1 x Power Fan connector
1 x IEEE1394a connector
Front panel audio connector
1 x S/PDIF Out Header
Chassis Intrusion connector
CD audio in
24-pin ATX Power connector
8-pin ATX 12V Power connector
Power on Switch
Reset Switch
System Panel (Q-Connector)
BIOS
16MB AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.4
Manageability
1.4 Bios Screens:
Quelle: hothardware.com
1.5 Lieferumfang:
Quelle: bi-tech.net
2.1 Informationen
Unterschiede zwischen dem P5Q Deluxe und dem P5Q3 Deluxe:
  • Das P5Q verfügt über eine nur 2 phasige Spannungsversorgung der NB und des RAMs
  • Zusätzlicher SATA-Port beim P5Q
  • Das P5Q3 unterstützt DDR3 RAM
Wichtige Einstellungsmöglichkeiten im BIOS:
  • vCore: 0,85 - 2,1
  • tRFC: 20,25, 30, 35, 42
  • tWTR/tWR/tRRD: 1-15
  • tRAS/tRP/tRCD: 3-18
  • CAS Latency: 3-11
  • Ramteiler: 1:1, 5:6, 4:5, 3:4, 2:3, 5:8, 3:5, 1:2
  • FSB Termin. Voltage: 1,2 - 1,9
  • CPU PPL Volatage: 1,5 - 2,78
  • SB Vcore: 1,1 - 1,4
  • NB Vcore: 1,1 - 2,06
  • vDIMM: 1,0 - 3,08
Stromverbauch im Vergleich zum X48:
  • IDLE: 11 - 13 Watt weniger
  • Last: 12 - 15 Watt weniger
Preis:
Produkthomepage:
2.2 FAQ
Messpunkte:
Quelle: Awardfabrik.de (@arne)
Einbinden von AHCI in ein bestehendes Windows XP
Anleitung
Reg-Datei
(danke an Perl-Freak)
Geschwindigkeit der Lan-Ports
Der untere Lan-Port ist schneller, da er über PCI-e angebunden ist. Der obere hat lediglich PCI.
(danke an M!ndfuck)
Umstellung von IDE auf AHCI unter XP und Vista nach der Installation
Einfach den Treiber im Gerätemanager ersetzen ist nicht möglich und wenn doch, dann folgt der Bluesreeen beim nächsten Rechnerstart promt. Einfach AHCI im Bios aktivieren geht aber auch nicht, denn hier könnte XP bzw. Vista seinen Dienst beim Start wiederum mit einem Bluescreen quittieren. Das Problem tritt auf, wenn der AHCI-Treiber in XP bzw. Vista deaktiviert ist. Überprüfen und aktivieren kann man diesen Treiiber nur in der Registry unter folgendem Schlüssel und Wert.
Start > Ausführen > regedit > Enter
HKEY_LOCAL_MACHINE > System > CurrentControlSet > Services > Msahci
Im rechten Fenster doppelklick auf Start und den Wert 4 auf 0 ändern.
Wenn nicht vorhanden, dann die entsprechenden Schlüssel und Werte erstellen.
Ladet hier den Intel® Matrix Storage Manager für XP und Vista herunter und entpacke diesen. z.B. C:\Temp\iata82_enu.exe -a -a . In dem Ordner C:\Programme\Intel\Intel Matrix Storage Manager\winall\Driver befindet sich dann eine Datei IaStor.sys. Diese kopierst du nach C:\Windows\System32\drivers.
Jetzt den PC neu starten, im Bios auf AHCI umstellen und dann die Treiber einbinden oder dieses von XP machen lassen. Neustart ist danach unbedingt nochmal erforderlich. Jetzt laufen die SATA Festplatten und die SATA optischen Laufwerke im AHCI.
Wer SATA DVD Brenner besitzt und diese nicht richtig erkannt werden oder keine leeren Rohlinge mehr erkennen, der sollte wieder auf IDE umstellen.
(danke an Murmel44)
Hinweis zur Lüftersteuerung
3-Pin CPU-Lüfter können nicht geregelt werden.
Achtung!
Es gibt Kompatibilitätsprobleme mit der NVIDIA GTX 260 und GTX 280.
Das Problem sind die 2 Kondensatoren am Ende des PCI-Express Steckplatz, da dort die Grafikkarten aufliegen.
Alle betroffenen Besitzer des Boards sollen sich an rma_germany@asus.com wenden (Fehler wird in Tschechien behoben).
Abweichungen in den Monitoring Funktionen
Wegen den Monitoring Funktionen: Im Bios eingestellte bspw. 2,0V VDimm ergeben beim P5Q Deluxe real anliegende 2,13V.
Also aufpassen was ihr einstellt
P5Q Deluxe Monitorfunktionen:
VDimm ----> Übervoltet um 0,13V
VNb ------> Übervoltet um 0,06V
VTT ------> Übervolter um 0,03V
PLL -------> Übervoltet um 0,07V
(danke an angoholic)
2.3 Reviews
  • Kühler:
    Thermalright Ultra 120 Extreme
    Thermaright IFX-14
    Scythe Ninja Ninja Plus Rev. B
    Scythe Ninja Cu
    Scythe Mugen
    Scythe Andy Samurai Master (nur in eine Richtung)
    Scythe Mine Scythe Mine Rev. B
    Scythe Samurai Z
    Scythe Kama Cross
    EKL Groß Clock'ner (nur in eine Richtung)
    Zalman CNPS9500AT
    Noctua NH-U12P (nur mit Lüfter richtung Gehäusedeckel)
    Thermaltake Big Typ 12 (nur mit einer alternativen Backplatte)
    EK Supreme mit Universalhalterung und 775 Halterung
    Zalman 7700Cu
    Thermalright SI-128
    Apack ZEROtherm BTF90
    Apack ZEROtherm BTF95
    Nocuta NH-C12P
    Arctic Cooling Alpine 7 Pro
  • RAM P5Q Deluxe:
    Mushkin PC8000 5-5-5-15
    Muskin XP2 8500 2x4GB Kit
    Corsair Dominator PC8000
    Crucial Ballistix DDR2 800 und 1066
    Crucial Ballistix Tracer RED 4GB PC2-6400C4
    Kingston ValueRAM DIMM 1GB PC2-6400U CL5
    Kingston HyperX (PC2-8500) KHX8500D2K2/1GN
    OCZ PC2-8500 REAPER CL5 KIT 4096MB
    G.Skill F2-8500CL5-1GBHK
    GeIL DIMM 4 GB DDR2-1066 Kit (GE24GB1066C5DC, EVO ONE)
    G.Skill DIMM Kit 4GB PC2-8000U CL5-5-5-15 (DDR2-1000) (F2-8000CL5D-4GBPQ)
    Corsair Dominator PC2-8500 C5
    Corsair PC2-800 CL4 TWIN2X2048-6400C4
    OCZ Platinum XTC Edition DIMM Kit 4GB PC2-8500U CL5-5-5-18 (OCZ2P10664GK)
Ne, FSB über 500 habe ich sowieso nicht und ja 1:1 ist besser.
Ich betreibe momentan leider nur einen q8200@3,10 bei 1,2375V:rolleyes:, jedoch noch nicht "100%" stabil lt. prime large. Das problem denke ich liegt am Speicher, da der small test ohne Probleme mehrere Durchgänge durchläuft.:confused:
Kann mir wer vllt. sagen, welche Spannungen ich im Bios einstellen beim Deluxe sollte,
wenn nicht übertaktet wird?
Oder kann ich da einfach alles auf Auto laufen lassen?
Skanda...
Schau auch mal hier die erste Seite: Asus P5Q / P5Q Pro / P5Q-E (Intel P45) [5]
Aber wenn du nicht übertaktest kannst im Prinzip alles auf auto auch lassen.
Ja dann reicht der ja alle mal!!!
Also ich kann dir den nur empfehlen. Oder hast dich schon entschieden<?
Nein habe mich noch nicht entscheiden können.:heul:
Kann mich nicht wirklich zwischen geil ultra plus 1066er und g.skill 1066er.
Wobei ich eher zu geil tendiere. Vollbestückung lt. QVL-Liste möglich.
Wobei bei dir laufen die g.skill auch ohne Probl.
Ach, mann ich weiß nicht.:grrr:
Morgen möchte ich bestellen.
Weißt du ob ich auf die revision achten muss? Kann man die so bestellen, ich meine jeder kit mit gleicher Nummer?
Und hast du dich entschieden???
War leider schon länger nicht mehr hier...:shake:
Weiß jemand zufällig, ob das P5Q Deluxe die Spannungen auf Auto übervoltet,
wenn keine Übertaktung vorhanden ist?
Skanda...
@killingsun
Habe auch momentan wenig bis gar keine Zeit gehabt.
Jup, habe mich für 4x2 GB ultra plus von geil entschieden. Kein Problem mit Vollbestückung. Wurden sofort richtig angenommen. getestet sogar mit cl4, 1066 und 1,8V- kein Thema:d.
War jedoch wie gesagt nur testweise. Bin gerade am oc'n und hier habe ich die optimalen Werte noch nicht raus. small test kein Problem, jedoch large und blend. Habe mehrer Tips in einem anderen Thread bekommen, die ich aber erst testen muss.
Werde aber noch berichten, bis denn;)
Mal andre Frage habe ja ein Blu-ray Laufwerk gekauft und eingebaut, und Zack PC startet nicht mehr nur Lüfter drehen sich kein Piepton, altes Laufwerk eingebaut und es funktioniert musste Bios auf Default setzen. Habe dann das neue Blu-ray Laufwerk eingebaut, und zack es ging habe dan alles im Bios eingestellt wie es wahr. Und läuft bis jetzt woran kann das gelegen haben?
Ne es wahr fest.... Gehe davon aus, aber auch wen nicht müsste doch mein PC starten..
Zur Kompatibilitätsliste für Kühler für das P5Q Deluxe kann der Prolimatech Megahalems Rev. B mit dazu :wink:
Hab ich gerade selbst verbaut
q9550 @ p5q-deluxe
Hi leute,
ich hab meinen quad auf FSB 435 prime stable laufen. Ich würde gerne noch ein wenig höher gehen, nur leider steigt mir bei mehr als 435 FSB immer beim prime core #4 aus.
Ich wollte jetzt nicht primär die Vcore noch weiter anheben. Könnte sich mal jemand meine settings ansehen und diese bewerten?
besten dank
Lego
muss den Beitrag wieder aufleben lassen. Habe um mein 775 Board nach und nach auszureizen noch mal zusätzlich mit 2 x 2GB DDR2-120Mhz aufgerüstet.
Die RAMS sind natürlich die gleichen wie die anderen beiden Riegel. Komme jetzt auf 8GB und der PrimeBlend Test bricht nach 5 Min ab.
Habe auch schon ein Bios-Update gemacht was natürlich nichts brachte. Alle Bios-Settings womit es bei 2 x 2GB stabil lief macht jetzt bei 4 x 2GB Probleme.
Hatte die RAMS auch schon auf Auto bzw. ohne OC laufen lassen mit dem gleichen Problem. CPU läuft weiterhin stabil im "small fft test".
Hier nochmals meine alten/neuen Settings für den Überblick:
Ai Overclock Tuner... Manual
CPU Ratio Setting... 8
FSB Frequency... 490
PCIE Frequency... 100
FSB Strap to North Bridge... 333 MHz
DRAM Frequency... DDR2-1177 MHz
DRAM Timing Control... Auto
oder:
CAS# Latency... 5 DRAM Clocks
DRAM RAS# to CAS# Delay... 5 DRAM Clocks
DRAM RAS# Precharge... 5 DRAM Clocks
DRAM RAS# Activate to Precharge Time... 18 DRAM Clocks
RAS# to RAS# Delay... Auto
Row Refresh Cycle Time... Auto
Write Recovery Time... Auto
Read to Precharge Time... Auto
DRAM Static Read Control... Disabled
DRAM Read Training... Disabled
MEM. OC Charger... Enabled
Ai Clock Twister... auto
Ai Transaction Booster... Manual
Common Performance Level... 8
Pull-In of CHA PH1... Disabled
Pull-In of CHA PH3... Disabled
Pull-In of CHA PH4... Disabled
Pull-In of CHB PH1... Disabled
Pull-In of CHB PH2... Disabled
Pull-In of CHB PH3... Disabled
Pull-In of CHB PH4... Disabled
CPU Voltage... 1.3250
CPU GTL Reference 1... 0.640
CPU GTL Reference 1... 0.680
CPU PLL Voltage... 1.52
FSB Termination Voltage... 1.26
DRAM Voltage... 2.20
NB Voltage... 1.30
NB GTL Reference... 0.595
SB Voltage... 1.10
PCIE SATA Voltage... 1.50
Load-Line Calibration... Disabled
CPU Spread Spectrum... Disabled
PCIE Spread Spectrum... Disabled
CPU Clock Skew... Normal
NB Clock Scew... Normal
CPU Margin Enhancement... Optimized
Advanced
>CPU Configuration
CPU Ratio Setting... 8.0
C1E Support... Enabled
Max CPUID Value Limit... Disabled
Intel(R) Virtualisation Tech... Enabled
CPU TM Function... Enabled
Execute Disable Bit... Enabled
Intel(R) SpeedStep(TM) Tech... Enabled
Intel(R) C-STATE Tech... Enabled
Vielen Dank für Tipps und Anregungen :-)
Hallo Leute,
suche dieses MB nun scho seit 2 Wochen, aber leider derzeit nicht zu finden.
Falls jemand von euch sein P5Q3 Deluxe verkaufen möchte, einfach eine PN an mich. Würde mich sehr darüber freuen. ;)
LG elio
Jep, hatte ich gerade im anderen P5Q Thread gesehen. Danke!
Gibts hier Erfahrungen damit?
Einfach dem Link zum Download folgen...in dem Paket sind alle Biose für die P5Q-Reihe drin, für das P5Q Deluxe ist die Version 2201 drin, also eine vor der aktuellen.
Als ich noch mein P5Q Deluxe hatte, hatte ich das ModBios mal drauf. Ist nicht schlecht gemacht, anderer Bootscreen, wenn ich mich recht erinnere und ein paar Änderungen unter der Haube, soweit ich das noch richtig weiss, wohl bessere Ram-Kompatibilität und Performance (sind wohl Teile vom Maximus II Formula drin)
Nun ja, in dem BIOS ist das Intel RAID ROM v9.6.0.1014 drin.
Aber das kann man ja mit dem MMTool austauschen gegen das v10.1.0.1008
  • 8086-2822_v10.1.0.1008.zip
Die Marvell Sachen sind eigentlich aktuell.
Ich empfehle euch dringend, das BIOS über DOS zu flashen mit dem Befehl
AFUDOS.EXE /iP5QD.ROM /PBNC /N
Das P5QD.ROM steht für die BIOS Datei.
Vorher die Setup Defaults im BIOS laden.
Wurde das BIOS erfolgreich geflasht dann startet den PC mit Strg+Alt+Entf, dann gleich ins BIOS gehen und da dann den Powerknopf drücken bis der PC ausgeht. ClearCmos und Batterie mit raus.
Hier noch ein paar Links von mir dazu:
Asus P5Q Treiber und Bios
MMTool unter diesem Link:
Intel Raid ROM im AMI BIOS ersetzen
BIOS per AFUDOS.EXE einzuspielen
