[Sammelthread] Asus Rampage II Extreme R.o.G. (Intel X58) [4]
Chrisch
Legende
Münsterland
[blockquote]
Spezifikationen Spezifikationen
CPU
  • Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor
  • Supports Intel® Dynamic Speed Technology
  • Supports 4.8GT/s & 6.4GT/s QuickPath Interconnection
Intel® chipset
  • Northbridge:
    - Intel® X58 Express chipset
  • Southbridge:
    - Intel® ICH10R
Memory
  • 6 x DIMM, Max. 12 GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066 Non-ECC,Un-buffered Memory
    - Triple channel memory architecture
    - * Supports Intel® Extreme Memory Profile (XMP)
    - **Due to Intel spec definition, DIMMs of DDR3-1333 or above are out of spec.
Expansion Slots
  • 3 x PCIe 2.0 x16 support at x16, x8, x8, or dual x16 speed
  • 2 x PCIe 2.0 x 1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 1 x PCI 2.2
Multi-GPU Support
  • Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
    - * We recommend that you use full tower chassis for building a 3-Way SLI system.
Storage
  • Intel ICH10R controller
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 xUltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
    - 1 xSATA 3.0 Gb/s port
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8 -Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2 Support Teaming Technology
Internal I/O Connectors
  • 3 x USB connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector
  • 7 x SATA connectors
  • 1 x IEEE 1394a connector
  • 1 x Chassis Fan connector
  • x 8-pin ATX 12V Power connector
  • 24-pin ATX Power connector
  • 1 x EL I/O Shield Connector
  • 3 x thermal sensor connector
  • 1 x En/Dis-able Clr CMOS connector
  • System Panel
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 8 x ProbeIt connectors
  • 1 x LCD Poster connector
  • 1 x BIOS FlashBack boot up selection header
  • 1 x ROG light connector
Back Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Special Features
  • External LCD Poster
  • Onboard Switches: Power / Reset / Clr CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ROG BIOS Wallpaper
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Accessories
  • ProbeIt Cable
  • 3-Way SLI Cable
  • SLI Cable
  • ASUS Optional Fan
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
BilderBilder
Das Mainboard
Die Verpackung und das Zubehör
(Quelle: Xfastest.com)​
Das BiosDas Bios
- Bilder folgen
Biostemplate (Extreme Tweaker)Biostemplate (Extreme Tweaker)
Code:
Extreme Tweaker
CPU Level Up:
Memory Level Up:
Ai Overclock Tuner:
OC From CPU Level Up:
OC From Memory Level Up:
CPU Ratio Setting:
BCLK Frequency:
PCIE Frequency:
DRAM Frequency:
UCLK Frequency:
QPI Frequency:
EPU II Phase Control:
Loadline Calibration:
CPU Differential Amplitude:
Extreme OV:
CPU Voltage:
CPU PLL Voltage:
QPI/DRAM Core Voltage:
IOH Voltage:
IOH PCIE Voltage:
ICH Voltage:
ICH PCIE Voltage:
DRAM Bus Voltage:
Debug Mode:
Keyboard TweakIt Control:
CPU Spread Spectrum:
PCIE Spread Spectrum:
CPU Clock Skew:
IOH Clock Skew:
CPU-Configuration
CPU Ratio Setting:
C1E Support:
Hardware Prefetcher:
Adjacent Cache Line Prefetch:
Intel(R) Virtualization Tech:
CPU TM Function:
Execute Disable Bit:
Intel(R) HT Technology:
Active Processor Cores:
A20M:
Intel(R) C-STATE Tech:
-C State package limit setting:
DRAM Timing Control
DRAM CAS# Latency:
DRAM RAS# to CAS# Delay:
DRAM RAS# PRE Time:
DRAM RAS# ACT Time:
DRAM RAS# to RAS# Delay:
DRAM REF Cycle Time:
DRAM WRITE Recovery Time:
DRAM READ to PRE Time:
DRAM FOUR ACT WIN Time:
DRAM WRITE to READ Delay:
DRAM Timing Mode:
DRAM Round Trip Latency on CHA:
DRAM Round Trip Latency on CHB:
DRAM Round Trip Latency on CHC:
DRAM WRITE to READ Delay(DD):
DRAM WRITE to READ Delay(DR):
DRAM WRITE to READ Delay(SR):
DRAM READ to WRITE Delay(DD):
DRAM READ to WRITE Delay(DR):
DRAM READ to WRITE Delay(SR):
DRAM READ to READ Delay(DD):
DRAM READ to READ Delay(DR):
DRAM READ to READ Delay(SR):
DRAM WRITE to WRITE Delay(DD):
DRAM WRITE to WRITE Delay(DR):
DRAM WRITE to WRITE Delay(SR):
DRAM REF Voltage
DRAM DATA REF Voltage on CHA/B/C:
DRAM CTRL REF Voltage on CHA/B/C:
DownloadsDownloads
Bios Downloads
  • Bios 0407
    - First release Bios
  • Bios 0503
    - Revised QPI/DRAM Core Voltage setting in CPU Level Up
  • Bios 0602
    - Fix system may hang after resume from S3
    - Improvie Memory compatibility
  • Bios 0701 (beta)
    - keine Changelog
  • Bios 0705
    - Fixed the CPU ratio setting incorrect in TweakIt Batch File function.
    - Revised the default value of keyboard TweakIt control hotkey to "P" in BIOS setup
  • Bios 0804
    - Updated EC firmware (Fixed system would hang at POST with ADAPTEC SAS RAID Controllers ASR-5405 attached.)
  • Bios 0901
    - Fixes Bug issues with 4870X2's in Crossfire X not showing Video.
    - Fixed Memory Compatibility Issues
  • Bios 0903
    - Fixed the function for adjusting BCLK abnormal in TurboV when set BCLK > 200MHz in BIOS setup
  • Bios 0904
    - System Stability Improved When Overclocking Bclk High
  • Bios 1001
    - Fix AI suite report different CPU temperature as LCD Poster
  • Bios 1403 (beta)
    - keine Changelog
  • Bios 1504
    - Updated configuration table of OC Station.
    - Fixed Target DRAM Frequency incorrect for DDR3-1333 with non-extreme CPU when set DRAM Frequency to auto in BIOS setup.
    - Supported display warning message when set CPU Voltage or QPI/DRAM Core Voltage over 1.8V in TurboV.
  • Bios 1639
    - Improve memory compatibility
    - Updated ASUS EZ Flash 2 from V3.38 to V3.44
    - Updated ASUS O.C. Profile from V1.38 to V1.44
  • Bios 1704
    - Support new CPUs.
  • Bios 1802
    - Support new CPUs.
Wichtige InformationenWichtige Informationen
  • Achtet auf die Speicheranordnung, wenn die Riegel in den falschen Slots sind bootet das Mainboard nicht (hat mit dem IMC der CPU zu tun!)
    - Dazu bitte Seite 2-15 im Handbuch nachschlagen.
[/blockquote]
Naja....
Die FPS steigen wenn die Bandbreite steigt!
Das ist mehrfach von PCGH getestet worden!
Kann aus eigener Erfahrung sagen das es stimmt
Und jap du hast recht ist erst die Graka die limitiert und dann kommen die Daten in den Ram
Oh ja, das stimmt natürlich. Aber bitte die Relationen dabei sehen. Wenn man niedrige einstellige Prozent-Werte als Steigerung sieht. Bitte :-)
Macht nix :d
Sind aber mehr , wenn ich 2-3 Frames gut mach und dadurch von Dia Show auf Film wechsel reicht mir das als steigerung ;)
Nö eigentlich kann man bei SATA-Platten nichts mehr falsch anschließen... entweder der Stecker paßt ... oder eben nicht! ;)
Die wenigsten Platten haben noch Jumper... und ich wüßte auch von keiner Platte, bei der man was um-jumpern müßte, wie es ganz-ganz früher noch war.
Ich würde als Tipp noch mal MT ( Memtest ) zu Rate ziehen.
Bootfähigen USB-Stick machen, MT drauf und laufen lassen.
Habe ich auch schon gemacht...alles ok...was ist hier los?
Kann es die CPU sein?
Kann ich testen ob diese 100% in Ordnung ist?
kannst du deine harware bei einem anderen brett testen?
wenn ja das würde ich auch mal machen.wenn nicht dann würde ich an deiner stelle mal zu einem pc shop hinfahren und die hardware mal testen lassen.
wie aussieht hast du ja auch alle möglichen sachen ausgetauscht bzw mal um gesteckt.
---------- Beitrag hinzugefügt um 18:56 ---------- Vorheriger Beitrag war um 18:55 ----------
Macht nix :d
Na ganz so schlimm ist es mit meiner graka aber nicht :lol::lol::lol:
Ja da hast Du wohl recht...
Habe fast alles ausgetauscht. Nur die cpu oder grafikkarte noch nict. Meinste dfas die Karte die Ursache sein kann?
Testen :
CPU = LinX
Grafikkarte = Furmark
aber cave : auf die Temps achten !
edit:
was mir einfällt : hast du MT denn voll durchlaufen lassen ( nach Möglichkeit mehrmals ) ?
Weil MT brauch bei 6GB RICHTIG lange !
Smooth hats angedeutet,bleiben nur noch diese sachen zum testen.enns dann nicht geht ab zum shop oder bei einem bekanten der auch einen X58 system hat
Testen :
CPU = LinX
edit:
3D Mark 06 = 25500 Punkte! Gestern Abend getestet...
LinX kenne ich noch nicht...
Ne, habe ich nicht voll durchlaufen lassen.! Mache ich aber in paar mi. Dauert ca. ne Stunde...der Test,oder?
-3D06 ist nicht wirklich aussagekräftig... da hatte ich schon 3DVantage was abgeschmiert ist und bei 06 clean run. Und Furmark ist noch mal ne Kathegorie härter.
- LinX downloaden ... und mal laufen lassen ;)
- MT hat bei mir ( mit 6GB ) fast 1,5h gebraucht ( oder mehr ?!? ) ... egal da solltest du auf jeden Fall ein paar Durchläufe machen, denn es kommt vor, daß es bei ersten Durchgang unauffällig ist und erst bei Zweiten oder Dritten Run einen Fehler bringt... von daher anschalten und ... Kaffeetrinken fahren, Einkaufen gehen... schlafen gehen... vllcht beischlafen und anschliessendes schlafen *g* ... auf jeden Fall brauch es ZEIT ! ;)
Beischlafen und anschließend schlafen...der ist gut ;)
3D Mark Vantage stürzt meist beim 2. Grafiktest ab...
Das ist sicher!
Kann es sein das es echt die Karte ist? Kann Call of Duty 6 flüssig zocken...
Ab zu lagt es...
Das ist sicher!
Na, dann hast du schon mal einen Verdächtigen.
Jetzt kannst du noch verschiedene Treiberversionen ausprobieren... aber denk daran, die Treiberreste mit DriverSweeper oder ähnlichen zu beseitigen bevor du einen anderen Treiber installierst.
ich hätte eine frage zu dem board...
ich hab hier einen bekannten, den ich nur telefonisch zur seite stehe kann.
er hat das problem, dass er mit seinem neuen board das problem hat, dass das board nur bei jedem 2. versuch startet. beim ersten versuch bleibt der bildschirm schwarz und er piept auch nicht.
ich vermute, dass es irgendwie mit den 2 bios´en zusammenhängt. er hat mir inzwischen auch was gesagt, dass da wohl am anfang eine fehlermeldung kommt, die hinweist, dass er vom 1. bios nicht starten konnte.
wisst ihr was dazu?
wisst ihr was dazu?
Einfach mal den Bios-Jumper umjumpern.
Just give it a try. ;)
Fehler besteht weiterhin...Grafikkarte habe ich gerade eine neue gekauft. Bringt nix.
Die ght dann morgen retour ;)
ABER ICH HABE IMMERNOCH DAS PROBLEM DAS MEIN RECHNER NICHT SCHNELL GENUG REAGIERT. WIE BESCHRIEBEN. WINDOWS CD REIN, 5 MIN WARTEN, WEITER DRÜCKEN, WIEDER 5 MIN WARTEN LANGE INSTALLIEREN FEHLERHAFTES WINDOWS:::WARUM NUR?
Entweder ist ein Bios korrupt oder keins drauf, schau dir mal das Bild an, da ist beschrieben wie man einstellt welches bootet.
[URL=http://saved.im/mtuxmjq5enhu/biosfashback.html][/URL]
Dann laß doch einfach mal MT über Nacht laufen.
danke jungs. ich geb morgen bescheid, ob das geholfen hat.
also das mit der RMA, wie geht das genau
ich habe jetzt hardwareversand angeschrieben, und denen mein problem geschildert, muss ich dann an hardwareversand mein board (Bulk) schicken, und die schicken es dann zu ASUS, und es wird ausgetauscht ?
kann es auch sein das sie es gar ned nehmen ?
Board komplett einpacken normalerweise, es sei denn die haben gesagt Bulk aber kann ich mir nicht vorstellen!
Retouraufkleber drauf der dabei war und zurück damit!
ok gut,
ich muss nur noch auf antwort seitens Hardwareversand wartem
die tridents veraukaufe ich wieder, (sind aktuell im MP), ich hol mir lieber corsair ram
die CPU lasse ich dann testen wärend das board auf reisen ist, und dann sollte es passen wenn ein neues board kommt
@Super-Hotze
Du hast Win7 und im Bios Dein Floppy-Laufwerk nicht auf Disable gesetzt? Würde genau auf Deine Fehlerbeschreibung passen.
ok gut,
Brauchst nicht warten!
Board mit fehlerbeschreibung eintüten retoureaufkleber druff und wech damit
Hi klinck mich hier auch mal ein hab heute das Bios 1639 drauf gehaun und endlich geht der BCLK mal höher hier ein Screen von 229 es waren auch 230 drin mehr habe ich noch nicht getestet, wie schauts bei euch aus ?
http://freeocen.de/wbb2/attachment.php?attachmentid=3796
Das wird aber doch definitiv nicht deine 24/7 settings sein oder?
versuch doch lieber ein 24/7settings zu ereichen was du auch benutzen willst.
230BCLK bekommen doch fast alle hier hin.
also das problem besteht weiterhin, dass der rechner erst beim 2. versuch startet, es kommt jetzt zwar keine fehlermeldung mehr, dass der rechner nicht vom 1. bios starten konnte, aber sonst ist alles beim alten geblieben.
habt ihr noch nen tipp?
Hast du schon mal die baterie vom board ein mal raus genommen und ca. 5 min gewartet.
bring meist immer etwas.
