[Sammelthread] Asus Maximus III Formula (P55)
Jean-Luc Picard
Weltkulturerbe
Inhalt
1.Algemeines
1.1 Bilder
1.2 Lieferumfang
1.3 OC-Verhalten
1.4 Spezifikationen
2.Information
2.1 Previews / Reviews
2.2 Preisvergleich
2.3 Kompatibele RAMs
2.4 kompatibelen LuftKühler
2.3 Overclocking Ergebnisse
3.Downloads
3.1 Bios
3.2 Treiber
3.3 Software
1. Agemeines
Bilder
ein Dank an Ace.KIA. für die Bilder.
Lieferumfang:
-ROG Maximus III Formula Motherboard
-1xMulti-funktional module (2-port USB 2.0 and 1-port ESATA
-SupremeFX X-FI Audio Card
-1xASUS Q-Shild (I/O shield)
-3x Serial ATA signal cables
-1xROG Connect cable
-1xSLI Cable
-1x 2-1 Asus Q-Connector Kit
-cable ties,User Guide, ROG Support DVD,1xROG Theme label,1ROG cable label(12-in-1)
Spezifikation:
CPU:
Intel sockel 1156 i5-750 Prozessor i7-860/870 Prozessor (Lynnfield)
Chipsatz:
Intel P55 Express Chipsatz
Intel® P55 (PCH) Southbridge
Speicher:
4 x 240 dimm,Max.16GB,DDR3-1066, DDR3-1333,1600,1800,2000,2133(OC) non-Ecc, un-buffered memory modules
Supports Intel Extreme Memory Profile (XMP)
Erweiterungs-Slots:
3xPCIe x16slot
-2xPCIe 2.0 (red) support single at x16 or dual at x8 mode
-1xPCIe 1.0 (white) support at 4x mode
2xPCIex1
2xPCI 2.2
Multi-GPU Unterstützung:
SLI,CrossfireX
Storage:
Intel® P55 (PCH)
-6 x SATA 3.0 GB/s ports
-Intel Matrix Storage Technology supports Raid0,1, 5 and 10
JMicron 322 controller and 2x Jmicron 363 controllers:
-2xSATA 3.0GB/s port (red) RAID 0 and 1(SPD_HDD1SPD_HDD2)
-1xExternal SATA 3.0 GB/s ports (SATA On-the Go)
-2xSATA 3.0 GB/s port (whit) -SATA_0DD1+SATA_0DD2
Audio:
SupremeFX X-Fi
-8channel High Definition Audio CODEC
-EAX Advance HD 4.0
-X-FI CMOSS -3D
-X-FI Crystalizer
-Creativ ALchemy
-1x S/PDIF out header,Coaxial/Optical S/PDIF,Blue-ray support
LAN:
1xGigabit Lan (Realtek RTL8110SC)
Overclocking Features
Extreme Engine Power Design
- 16-phase CPU power
- 3-phase VTT power
- 3-phase Memory power
ROG Connect
CPU Level Up
Memory Level Up
Speeding HDD
iROG
Extreme Tweaker
Loadline Calibration
Intelligent overclocking tools:
- ASUS AI Booster Utility
- O.C. Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
MemOK!
MemPerfect
ProbeIt
Onboard Switches: Power / Reset / Clr CMOS (at rear)
Q-Fan Plus
ASUS EPU
ASUS MyLogo3
ASUS Fan Xpert
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Connector
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
ASUS Q-Slot
ASUS Q-DIMM
Information
Board
http://www.asus.com/product.aspx?P_ID=0ODEkxv4cmlXkqmr&templete=2
Review
http://www.google.de/url?sa=t&source=web&ct=res&cd=2&url=http%3A%2F%2Fwww.overclockersclub.com%2Freviews%2Fasus_rog_maximusiii_formula_preview%2F&ei=3WDGSpu1HoK64QaF57THAQ&usg=AFQjCNEbdV8MRKATUoV2cPAaJTEQ3MJMqw
Preisvergleich >ASUS MAXIMUS III FORMULAR:
http://preisvergleich.hardwareluxx.de/a459238.html
BIOS Empfehlung: 1006AKTUELLES
Kompatibele RAMs/Liste
ftp://ftp.asus.com.tw/pub/asus/mb/LGA1156/Maximus_III_Formula/M3F-QVL.zip
Code:
4x2gb G.Skill (F3-12800CL9D-4GBNQ) CL9-9-9-24 Vdimm=1.50V
2x2Gb G.Skill(F3-12800CL7D-4GBRH, Ripjaws-Series) CL7-7-7-21 VDimm=1,6V
2x2Gb Corsair  (CMG4GX3M2A2000C8, Dominator GT) CL8-8-8-24
2x2Gb G.Skill (F3-17066CL8D-4GBPS) CL8-8-8-24
2x2GB Kingston HyperX KHX1600C8D3K2/4GX
4x2GB exceleram DIMM Kit 4GB PC3-16000U CL9-9-9-24 (DDR3-2000) (EX3-42000X2-GO) 1,65v
Code:
Zalman CNPS 9900Apasst sehr gut darauf und stört die Ram slots nicht.
Zalman CNPS10X Extreme belegt leider den 1 Ram slot.
Noctua NH-U12P SE2
Downloads
Bios
Aktuelle Bios gibt es direkt von FTP-Server
Ich würd ja gleich zwei Danke vergeben wenns ginge :O) Sehr schön !
Na also, hat sich doch noch jemand gefunden :)
Titel noch anpassen: [Sammelthread] ASUS Maximus III Formula (P55)
Unbedingt die Hotlinks der Bilder bei PCGH entfernen und die Bilder selbst bei einem Hoster hochladen (siehe auch der entsprechende Hinweis in den Forenregeln).
Sobald die noch ausstehenden Inhalte drin sind, gibt es eine Freifahrt ins Sammelthread-Unterforum :wink:
ja bin auch dafür das der titel auf Maximus III Formula geändert werden soll. auch die bilder so gestalten das man das fenster nicht nach rechts und links skrollen muss.
am sonsten gute arbeit :)
Ich freue mich schon auf Bilder. Wird es einfach offizielle Ablichtungen geben, oder gibt es selbstgemachte Fotos vom Auspacken etc.?
Jean-Luc Picard@
keine sorge, wir werden dich unterstützen :P
Mein vorschlag für erste posting...
Kompatibele RAMs inkl anzahl der module und vdimm...
und kompatibelen LuftKühler.
OC ergebnise von users wäre auch nicht schlecht :)
hier schonmal meine rams und luftkühler...
4x2gb G.Skill (F3-12800CL9D-4GBNQ) CL9-9-9-24 Vdimm=1.50v
Links: http://preisvergleich.hardwareluxx.de/deutschland/a351375.html
Und mein luftkühler sieht man schon von sig. Zalman CNPS 9900A :) passt sehr gut darauf und stört die ram slots nicht.
Na das sieht doch schon gut aus, damit verschoben ins Sammelthread-Unterforum :wink:
[x] im Ibex Peak Sammelthread und der alphabetischen Übersicht der Sammelthreads verlinkt
ich habe auch sehr starkes Interesse an dem Mainboard.
Als alter Gigabyte Fanboy bin ich mir aber noch nicht 100 % sicher ob ich wechseln soll.
Wird die Maximus Gene Variante auch in diesem thread behandelt ?
Falls nein, kann mir jemand sagen was der Unterschied zum Maximus ist ( außer Formfaktor, onboard Sound, Spannungsversorgung schlechter ) ?
Muß ich schlechtere OC Eigenschaften in Kauf nehmen, oder höhere Temps ?
Für hilfreiche Antworten wäre ich sehr dankbar.
Ratber
Jean-Luc Picard@
hab ich hinzugefügt:wink:
Noctua NH-U12P SE2
Bei Verwendung von einem Lüfter alle Ram Slot frei,bei 2 Lüfter 1 Slot verdeckt!
G.Skill Trident passen ohne Problem und laufen auf dem Board sehr gut!
@ Jean-Luc Picard
Eventuell kannst du die Bilder gerade noch mal hoch laden (Thumbnail für Foren 1 ),das man sie anklicken kann und
größer sieht
http://www.abload.de/
Noctua NH-U12P SE2
@ Jean-Luc Picard
größer sieht
ist schon erledigt
ich werde mal bischen ocien und sehen was das board so kann ;)
In moment bin bei 3600MHz mit 1.206v.
btw, meine rams laufen auch mit CR1 ohne spannung und timing änderung :d
Was ich noch eben raus gefunden habe, das board kann auch timing CR3 ! könnte damit meine rams auf 1700MHz bringen :)
Ich war schon bei 4,3 -4,4 aber nur für Super PI
Der Noctua kühlt nicht so dolle bei 4Ghz Prime komme auf 80°:stupid:
ich bin bei 3800mhz mit 1.27v. und temp liegt bei 70°. ich glaube für 4ghz muss ein wk her. höher gehe ich nicht mehr. möchte die cpu noch paar monaten behalten :)
wie heiss darf eigentlich die cpu werden ? gibt es irrgendwo infos von intel ?
Hallo AMFIII Besitzer
so nun geselle ich mich mal dazu mit meinem MIF III 860.
habe das 0902bios und ohne ende oc einstellungsmöglichkeiten und vieles ist neu dazugekommen das man erst kennenlernen muß was ich bis heute nicht kannte.das gibt was ;-).
habe mir den Orochi Rev.B gekauft aber leider ohne 1156 retentions kit, ist mir aber erst beim zusammenbauen aufgefallen skythe bringt erst im november den 1156 retention kit,von daher habe ich den boxed im moment drauf 54Grad bei 3,68GHZ im IDLE wohlgemerkt und unter last bei 83grad, vondaher kann ich nicht höher im moment ist mir zu heiß.
Hallo Jean,
das case habe ich bei meinem distri gekauft,
gibt es seit 01.09 ca.
da ich viel rumbastle und alle 30tage mein board cpu oder ram wechsle, kam mir das am gelegensten.
schau einfach nach antec skeleto kannste fast überall kaufen.. liegt so bei 100€
hat hier jemand auf dem Board 2000er RAM's bei 20x200 (SMT an) am laufen ?
Ich kann das einfach nicht stabil bekommen...
1600Mhz bei 20x200 scheinen dagegen stabil zu laufen.
Gruß Daniel
Ich habe 2000 Rams!laufen auch soweit,aber 20x200 habe ich Prime nicht getestet da doch zu Warm mit dem Noctua!
@ sarge07
Intel gibt beim i5 und i7 Modellen 72° vor
So, 20x200@1600Mhz sind absolut stabil, nur weiß ich noch immer nicht, warum 2000Mhz nicht wollen...
Dreckskiste !
ich habe auch 2000er ram funzt ohne probleme, hast du auch den 0902 bios drauf da wird nochmal der ram gefixt.
Dreckskiste !
probiere mal mit timing mode ob der hilft. mir hat CR3 geholfen auf 1700mhz zu kommen. aber naja ich hab 1600er ram.
Ace.KIA.@
danke für info. werde dann vorerst bei 3600mhz bleiben. reicht auch vollkommen für alles ;)
