Gigabyte K8NSNXP (nForce3 250)
Don
[printed]-Redakteur, Tweety
Preis: 175€
Review folgt in Kürze !!!
  • Socket 754 for AMD Athlon64
  • NVIDIA nForce3 250 Platform Processor
  • Super I/O: ITE IT8712F chip
  • Silicon Image sil3512 controller
  • GigaRAID ATA 133 RAID controller
  • T.I. IEEE1394b controller
  • Marvell 8001 Gigabit Ethernet controller
  • ICS 1883 LAN PHY chip
  • Realtek ALC850 Audio AC'97 Codec
  • Type: DDR400/ 333/ 266- 184pin
  • Max capacity: Up to 3GB by 3 DIMM slots
  • Internal I/O Connectors
  • 4 x Serial ATA connector
  • 4 x UDMA ATA 133/100/66 Bus Master IDE connectors
  • 1 x FDD connector
  • 2 x USB 2.0/1.1 connectors (supports 4 ports)
  • 2 x IEEE 1394b connectors (supports 3 ports)
  • S/P DIF input/output pin header
  • 3 x cooling fan pin headers
  • CD/AUX in
  • 1 x Game/Midi connector
  • 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
  • 5 x PCI slots (PCI 2.3 compliant)
  • 1 x DPS slots
  • PS/2 Keyboard / Mouse
  • 2 x USB 2.0/1.1 ports
  • 2 x RJ45 ports
  • 2 x COM ports
  • 1 x LPT
  • Audio (1 x Line-in / 1 x Line-out / 1 x Mic) connector
  • CPU FSB / Multiplier / Vcore Voltage adjustable via BIOS
  • AGP Voltage / Clock adjustable via BIOS
  • DIMM Voltage / Clock adjustable via BIOS
  • ATX power connector and ATX 12V connector
  • Power-off by Windows 98/ Me/ 2000/ XP shut down and switch
  • ATX form factor
  • 30.5 x 24.4 cm
  • System health status auto-detect and report by BIOS
  • Hardware detecting and reporting for case open, CPU voltage, and fan speed.
  • 2 X 4M bit flash ROM, Award BIOS
Hallo !
Welchen Ramspeicher benutzt Ihr denn so für das Gigabyte - K8NSNXP ?
Ich habe nämlich Probleme mit 2x512MB MDT - SS Speichern !!!
Bitte um Antworten, danke !!!
