Gf 6200 Agp?
moniduse
Wollte mir eine 6200 kaufen. Jedoch sollte es AGP sein.Gibt es das schon für AGP??
nein, der NV43 ist ein nativer pci-express chipsatz und kann nur per HIS bridge chip agp fähig gemacht werden
soweit ich weiß, will nvidia den 6200 nicht auf agp basis anbieten
ich wurde gerade des besseren belehrt :)
WE HEARD that Nvidia plans to bring all of the Geforce six series back to AGP. Nvidia wants to make Shader 3.0 available for all of its customers as many of them still have AGP systems.
The company is working on a printed circuit board (PCB) that will enable its customers to make 6200 AGP cards. Of course this card will be powered with the BR2, HSI chip which translates PCIe commands to AGP and vice versa.
We are not sure when these cards are going to be ready but 6600GT AGP cards are already available and 6600 standard AGP are expected shortly.
We are quite sure that those cards won't use Turbo Cache as the AGP interface is one way only and it's not wide enough for all of the data. This leaves Nvidia and its partners with two options. To base 6200 AGP on NV43-V chips used in 6200 standard or to base them on NV44 cards used in 6200TC.
This will put some additional pressure on ATI, as it still does not support Shader model 3.0. We know that ATI will chose the same path from R520 to all other future products but Nvidia definitely have lead over the competition as it complete generation weather we are talking about PCIe or AGP cards. ATI bridge chip is still not ready but it should be toward the middle of Q1 2005.
also definitiv kann man sagen, dass es die GeForce 6200 TC (Turbo Cache) nicht für das AGP interface geben wird. die standard GeForce 6200 wird aber vermutlich mit AGP steckplatz, realisiert durch den BR2 chip bzw. die HSI bridge, erscheinen.
aha, danke für die infos. wird aber wohl noch ein bisschen dauern, bis es soweit is.
