Hi
bin grad beim googeln auf vollgendes gestoßen --->Link <----
anscheinend will asus n bios für das p5b herausbringen mitdem man auch bei den kleineren c2d `s den multi nach oben und unten einsellen kann
na das hört sich doch super an oder
cu brokk
The new 0507 BIOS for the P5B Deluxe, dated 8/10/2006, has two new and exciting features:
1. Provide better maximum overclocking.
2. Add the ability to adjust the multiplier of most Conroe CPUs even if they are not Extreme Edition.
At present, every Core 2 Duo chip we tried unlocked down (this included both B1 and B2 steppings); however, none of our samples unlocked both up and down. ASUS tells us that many Core 2 Duo chips also unlock upwards, but the upper limit is around a 14X multiplier with those chips that do unlock in both directions. If true, we're certain those chips that can unlock completely will be quickly figured out by enthusiasts and those models and steppings will become the most highly desired Core 2 Duo chips.
Certainly this new BIOS makes the ASUS P5B a much more desirable motherboard. We do need to remind readers, however, that we have generally reached even higher overclocks on the 975X chipset when compared 1:1 with the 965P. ASUS has told us they are not finished with this "Conroe Unlock" feature and that they are working on BIOS revisions to also bring Core 2 Duo unlock to 975X chipset motherboards. We have seen hardware modifications to the Intel 975 BadAxe that allow unlocking, and it would be great if ASUS can accomplish the same with a simple 975 BIOS upgrade, as they have on the P5B Deluxe.
cu brokk
