Die Community hat schon eine Vorstellungen wie ein neues Battlefield ausehen soll.
Die Battlefield Formel
Quelle: https://pastebin.com/K3LVeGAx
Gunplay
Hardline (if suppression is added, it should only be visual)
- Little to no visual recoil
- Less spread increase per shot than BF4
- Learnable pattern with spread
- BFV sniping
- Ask @NickelBF
Movement
BFV (pre nerf)
Slight bit of air strafing
Momentum change during slide
Maps
BF3, BF4
- Stop using the same resources for every map (crates, sandbags etc)
- Design maps for a specific gamemode, rather than adapting one map to everything.
Classes
BF3 class system (PDW all class, carbines for engi) - only slightly better than BF4
- BF4 revive system
- Focus on making easily recognizable outlines for each class (e.g. TF2, Valorant, OW)
Setting
- 2000-2023
- Going into the future justifies dumb things e.g. railtank
UI/HUD
- BF4 customization is unmatched
- Ask @NickelBF
Player count
- 70-80 (5 man squads needs to come back)
- Could play it safe with 64 and 5 man squads
Gamemodes
- Portal (make ur comp modes there, DICE pick one and support it)
- CQL (big conquest thing)
- Rush
- BT
- TDM and Dom (one playlist or alternating)
Jets
- Modified BF4
- Stealth and Attack Jets
- Attack jet can turn as fast as stealth jet if perfect speed of 313 is maintained
- Stealth jet can reach max turn rate with speed within 308-315 range (easier)
- 25mm cannon on SJ can be buffed a bit
- Stealth jet should be F22 (comparable hitbox and no VTOL)
- Faster lock onto AJ than SJ
- Look into different lock mechanics for each jet (e.g. no direction indicator for AJ)
- Slightly nerfed BF3
- SJ in CQ, AJ in Rush
Helis
- BF4
- Fix TV bug
- Fuck the havoc off
- Make Z11 and AH6 more equal
- Replace thermal with BF3 thermal
- Gunner doesn't get direction markers for stingers without proxy scan upgrade
Transports
- Anything but BF2042 don't make them stupid OP.
Tanks
- BF4 as baseline
- Fix APS
- Make Abrams look behind itself
- Removing staff shell, guided shell
- AA shouldn't be a death star (no thermals, nerf zuni dmg vs infy)
Boats
- Add them
- No reps
- Reduce mobility hit
AT/AA
- SRAW
- Stinger and Igla, but no igla bugging
- Igla is faster but you can't Igla something that is below radar
- BF4 SMAW and RPG
Misc
- 60 tick
- BF1 netcode/make sure hitreg works at release
- Scoreboard on release
- Squad management
- Platoons
- Server browser
- Streamer mode/anti stream sniping measures
- Good statistics page
- NO AI
- Proper anticheat
- Functional report system (some cheaters played for 2+ years)
- Good hand cannon
- No forced anti aliasing
- Basic config files on release but nothing INSANELY advantageous
- If a setting is so advantageous it should be in the settings for everyone.
- NO LIVE SERVICE - BRING BACK PREMIUM AND DLC
- Add an integrated Battlelog into the menus
- Inbuilt ranked ladder and leaderboards
- Skins should not change hitboxes our outlines
- Death comms
- Cosmetics associated with skillful tasks
- Specatator mode and battlerecorder (demos)
- BF3 ambient sound, BF2042 directional sound
- Crossplay (if there is a competitive mode, then no xplay)
