treibstoff
Hab nach einiger Recherche die erste Version von ATT im Beta-Forum entdeckt.
http://forums.guru3d.com/showpost.php?p=2048984&postcount=1
Unter Vista 32bit läuft es bisher problemlos, bin allerdings noch am Testen.
Wäre schön wenn die 64bit-Besitzer das testen könnten, dass wäre nämlich ein Grund für mich auf meine eigentlich gekaufte 64 bit Version umzusteigen ...
Grüße
Readme :
1.2.6.XXX
[*] Updated existing translation files
[+] Added Polish translation
[*] Updated Advances Tweaks databases
[F] Fixed procedure to collect monitroing sources from ATT in "MotherBoard Sources" FlashOSD Plugin.
[F] Fixed current 3D profile detection in non CCC compatible mode
[*] Updated Monitoring Graphs module to support external plugins. This excellent idea was first implemented in RivaTuner by
Unwinder. ATT and RT plugins are incompatible.
[+] Added example Monitoring Graphs plugin "Memory Monitor". Which can monitor global memory statuses like Memory Load %,
Physical memory Available,Page File usage, Virtual memory usage. Source code included.
[+] Added monitoring pluginsd "HDD Temperature". Allows to monitor temperature of HDD disks via S.M.A.R.T.
[*] Updated plugins SDK to support new monitoring graphs plugins
[*] Minor GUI updates
[*] Updated Driver level Overclocking support for RV560/RV570 boards.
[+] Added test support for voltage regulation on X1950XTX boards
[*] Added monitoring plugin "X1xxx Voltages" to provide monitoring sources for GPU/Mem voltages.
[*] Updated installation interface
[+] Added new configuration option. "Disable using OverDrive in "Driver Level" overclocking mode". This option can be useful
if your video board has support for OverDrive, but ATT unable to overlock using "Driver Level" mode. Can be changed in
atitray.ini or at installtion process.
[*] Updated Overdrive 3 support detection procedure.
[*] Updated Core Names database. Added infotmation about RV610/M74/M72/M76/RV630 chips.
[*] Updated registry handling function under CCC compatibly mode
[*] Added test support for Vista 32bit. Not all of functions will work under Vista at this time.
[-] Removed Audio recorder and Volume control functionality from ATT. Incompatible with Vista.
Grüße
Readme :
1.2.6.XXX
