[Sammelthread] Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
Sammelthread Asrock X370 Taichi / Fatal1ty X370 Professional Gaming
attachment.php
X370 Taichi
-Herstellerlink- -Handbuch- -Preisvergleich-
attachment.php
attachment.php
Inhaltsverzeichnis:
  • Spezifikationen
  • Links & Reviews
  • UEFI History
  • Q&A
  • Ram & Kühler Kompabilitäts-Liste
  • OC
Technische Daten / Spezifikationen:
Gemeinsame Technische Spezifikationen:
  • CPU:
    AMD AM4 Socket Ryzen Series (Summit Ridge)
  • Chipsatz:
    AMD X370 Promontory
  • Memory:
    Supports DDR4 3200+ (OC)
  • Expansion-Slots:
    2 PCIe 3.0 x16 (16/0 - 8/8), 1 PCIe 2.0 x16, 2 PCIe 2.0 x1, 1 M.2 (Key E - belegt mit WiFI-BT-Modul)
  • Storage:
    10 Sata3, 1 UltraM.2 (PCIe Gen3 x4 & Sata3), 1 M.2 (PCIe Gen2 x4)
  • USB:
    2 USB 3.1 (Type-A, Type-C), 10 USB 3.0 (4 Front, 6 Rear)
  • Network :
    1 Intel Gigabit Lan (10|100|1000 Mb/s - Intel I211AT), 1 Intel 802.11ac (IEEE 802.11a/b/g/n/ac, Dual-Band (2,4|5Ghz))
  • Audio:
    7.1 Channel HD Audio (Realtek ALC 1220)
  • Others:
    1 PS/2 Maose/Keyboard-Port (with Y-Cable Support), 1 Clear CMOS Switch
X370 Taichi:
  • Audio-Software:
    Purity Sound 4
  • Vollständige Spezifikationen:
    Code:
    Einzigartige Features
        ASRock USB 3.1
        - ASRock USB 3.1 Type-A Port (10 Gb/s)
        - ASRock USB 3.1 Type-C Port (10 Gb/s)
        ASRock Super Alloy
        - XXL Aluminum Alloy Heatsink
        - Premium 60A Power Choke
        - Premium Memory Alloy Choke (Reduces 70% core loss compared to iron powder choke)
        - Dual-Stack MOSFET (DSM)
        - Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
        - I/O Armor
        - Matte Black PCB
        - High Density Glass Fabric PCB
        - 2oz Copper PCB
        Intel® 802.11ac WiFi
        ASRock Steel Slots
        ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
        ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
        ASRock Live Update & APP Shop
    CPU
        - Supports AMD AM4 Socket Ryzen Series CPUs (Summit Ridge)
        - IR Digital PWM
        - 16 Power Phase design
        - Supports 300W EX OC
        - Supports ASRock Hyper BCLK Engine II
    Chipsatz
        - AMD Promontory X370
     Arbeitsspeicher
        - Dual Channel DDR4 Memory Technology
        - 4 x DDR4 DIMM Slots
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC and non-ECC, un-buffered memory*
        - Max. capacity of system memory: 64GB**
        - 15μ Gold Contact in DIMM Slots
        *Please refer to Memory Support List on ASRock's website for more information.
        Please refer to below table for DDR4 UDIMM maximum frequency support.
        Ryzen Series CPUs:
        UDIMM Memory Slot    Frequency(MHZ)
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
        SR    SR    SR    SR    2133-2400
        SR/DR    DR    SR/DR    DR    1866-2133
        SR: Single rank DIMM, 1Rx4 or 1Rx8 on DIMM module label
        DR: Dual rank DIMM, 2Rx4 or 2Rx8 on DIMM module label
        **Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
    BIOS
        - 128Mb AMI UEFI Legal BIOS with GUI support
        - Supports "Plug and Play"
        - ACPI 5.1 compliance wake up events
        - Supports jumperfree
        - SMBIOS 2.3 support
        - CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
    Grafik
        - n/a
    Audio
        - 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
        - Premium Blu-ray Audio support
        - Supports Surge Protection
        - Supports Purity Sound™ 4
        - Nichicon Fine Gold Series Audio Caps
        - 120dB SNR DAC with Differential Amplifier
        - TI NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
        - Pure Power-In
        - Direct Drive Technology
        - PCB isolate shielding
        - Impedance Sensing on Line Out port
        - Individual PCB Layers for R/L Audio Channel
        - Gold Audio Jacks
        - 15μ Gold Audio Connector
        - Supports DTS Connect
    LAN
        - Gigabit LAN 10/100/1000 Mb/s
        - GigaLAN Intel® I211AT
        - Supports Wake-On-LAN
        - Supports Lightning/ESD Protection
        - Supports Energy Efficient Ethernet 802.3az
        - Supports PXE
    Drahtloses LAN
        - Intel® 802.11ac WiFi Module (Free Bundle)
        - Supports IEEE 802.11a/b/g/n/ac
        - Supports Dual-Band (2.4/5 GHz)
        - Supports high speed wireless connections up to 433Mbps
        - Supports Bluetooth 4.2 / 3.0 + High speed class II
    Steckplätze
        - 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE3))*
        - 1 x PCI Express 2.0 x16 Slot (PCIE5 @ x4 mode)**
        - 2 x PCI Express 2.0 x1 Slots
        - Supports AMD Quad CrossFireX™ and CrossFireX™
        - Supports NVIDIA® Quad SLI™ and SLI™
        - 1 x Vertical M.2 Socket (Key E) with the bundled WiFi-802.11ac module (on the rear I/O)
        - 15μ Gold Contact in VGA PCIe Slot (PCIE2)
        *Supports NVMe SSD as boot disks
        **If PCIE5 slot is occupied, M2_2 will be disabled
    Storage
        - 8 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
        - 2 x SATA3 6.0 Gb/s Connectors by ASMedia ASM1061, support NCQ, AHCI and Hot Plug
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)
        - 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 PCI Express module up to Gen2 x4 (20 Gb/s)*
        *If M2_2 is occupied, PCIE5 slot will be disabled
        Supports ASRock U.2 Kit
    Anschluss
        - 1 x Power LED and Speaker Header
        - 1 x AMD Fan LED Header
        - 2 x RGB LED Headers*
        - 1 x CPU Fan Connector (4-pin)**
        - 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
        - 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
        - 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)*****
        - 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
        - 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
        - 1 x Front Panel Audio Connector (15μ Gold Audio Connector)
        - 1 x AMD LED Fan USB Header
        - 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
        - 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
        - 1 x Dr. Debug with LED
        *Supports up to 12V/3A, 36W LED Strip
        **The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
        ***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        ****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
        *****CPU_FAN1, CHA_FAN1, CHA_FAN2 can auto detect if 3-pin or 4-pin fan is in use.
    Blende
        - 2 x Antenna Ports
        - 1 x PS/2 Mouse/Keyboard Port
        - 1 x Optical SPDIF Out Port
        - 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
        - 6 x USB 3.0 Ports (Supports ESD Protection)
        - 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
        - 1 x Clear CMOS Switch
        - HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
    Software und UEFI
        Software
        - ASRock A-Tuning
        - ASRock RGB LED
        - ASRock APP Charger
        - ASRock XFast LAN*
        UEFI
        - ASRock Full HD UEFI
        - ASRock Instant Flash
        - ASRock Internet Flash
        - ASRock Crashless BIOS
        - ASRock Easy RAID Installer
        *These utilities can be downloaded from ASRock Live Update & APP Shop.
    Support-CD
        - Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
    Produktzubehör
        - Quick Installation Guide, Support CD, I/O Shield
        - 4 x SATA Data Cables
        - 1 x ASRock SLI_HB_Bridge_2S Card
        - 2 x ASRock WiFi 2.4/5 GHz Antennas
        - 2 x Screws for M.2 Sockets
    Hardware überwachung
        - Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
        - Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
    Formfaktor
        - ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
    Betriebssystem
        - Microsoft® Windows® 10 64-bit*
        *For the updated Windows® 10 driver, please visit ASRock's website for details.
    Zertifizierungen
        - FCC, CE
        - ErP/EuP ready (ErP/EuP ready power supply is required)
  • Audio-Software:
    Creative Sound Blaster Cinema 3
  • Network zusätzlich:
    1 Aquantia 5 Gigabit Lan (10|100|1000|2500|5000 Mb/s - Aquantia AQC108)
  • Onboard:
    1 COM Port Header, 1 TPM Header, 1 Power Switch, 1 Reset Switch
    Code:
    Gaming Armor
        Power
        - Hi-Density Power Connectors (24 pin and 8 pin)
        Memory
        VGA Card
        Internet
        - AQUANTIA 5G LAN
        - Intel® LAN
        Cooling
        - Heat Pipe Design
        Audio
        - Creative Sound Blaster™ Cinema 3
        ASRock USB 3.1
        ASRock Super Alloy
        - I/O Armor
        - Matte Black PCB
        - 2oz Copper PCB
        AQUANTIA 5G LAN
        ASRock Steel Slots
        ASRock Ultra USB Power
    CPU
        - IR Digital PWM
    Chipsatz
    Arbeitsspeicher
        - Supports DDR4 3200+(OC)/2933(OC)/2667/2400/2133 ECC & non-ECC, un-buffered memory*
        Ryzen Series CPUs:
        A1    A2    B1    B2
        -    SR    -    -    2667
        -    DR    -    -    2667
        -    SR    -    SR    2667
        -    DR    -    DR    2400-2667
    BIOS
    Grafik
        - n/a
    Audio
        - Pure Power-In
        - PCB Isolate Shielding
        - RGB LED
        - Gold Audio Jacks
        - Supports Creative Sound Blaster™ Cinema 3
    LAN
        1 x 5 Gigabit LAN 100/1000/2500/5000 Mb/s (AQUANTIA AQC108):
        - Supports PXE
        1 x Intel® Gigabit LAN 10/100/1000 Mb/s (1 x Intel® I211AT):
        - Supports PXE
    Drahtloses LAN
    Steckplätze
    Storage
        - 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)*
    Anschluss
        - 1 x COM Port Header
        - 1 x TPM Header
        - 1 x Power Switch with LED
        - 1 x Reset Switch with LED
    Blende
        - 2 x Antenna Ports
        - 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)*
        - 6 x USB 3.0 Ports (Supports ESD Protection)**
        - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
        *Ultra USB Power is supported on USB3_5_6 ports.
        ACPI wake-up function is not supported on USB3_5_6 ports.
        **1 x Fatal1ty Mouse Port (USB 3.0) is included
    Software und UEFI
        Software
        - ASRock F-Stream
        - ASRock RGB LED
        - ASRock Key Master
        - ASRock XFast LAN*
        UEFI
    Support-CD
    Produktzubehör
    Formfaktor
    Betriebssystem
    Zertifizierungen
        - FCC, CE
Links & Reviews:
Allgemeine Links
X370 Taichi:
UEFI History:
X370 Taichi:
Link Asrock
  • 2.00
    Update AGESA to 1.0.0.4a, Precision Boost - Adjusts clock speeds in 25MHz increments in BIOS setup
  • 2.20
    Update Agesa Version string "SummitPI-AM4 1.0.0.4a
  • 2.30
    Enhance OC setting for advanced Overclocker
  • 2.40
    Update AGESA to 1.0.0.6
  • 3.00
    Update AGESA to 1.0.0.6a
  • 3.10
    Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature. Windows update is available for version P3.00 or later.
  • 3.20
    With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
  • 3.30
    Bridge BIOS
  • 4.40
    Update AGESA for future coming processors.
    * Before updating this BIOS, please update the BIOS to P3.30 firstly
  • 4.60
    Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a.
    (Einwurf: Wenn nicht das 4.40 schon drauf ist)
  • 4.70
    Enhance compatibility for Raven CPU with Intel WiFi.
    (Einwurf: Wenn nicht das 4.40 oder höher schon drauf ist)
  • 4.80
    Update PinnaclePI-AM4_1.0.0.4
Link Asrock
  • 2.00
  • 2.20
  • 2.30
  • 2.40
  • 3.00
  • 3.10
  • 3.30
    Bridge BIOS
  • 4.40
  • 4.60
  • 4.70
  • 4.80
Q&A:
Allgemeingültige Q&A:
  • Spannungsversorgung Bios
    It is our BIOS extra setting instead of a bug.
    Normally, users could only modify CPU internal voltage.
    But on this model, we mounted with extra PWM IC to let users control CPU external voltage.
    In BIOS \ OC Tweaker \ CPU Configuration \ CPU Voltage, this option is to adjust CPU internal voltage.
    In BIOS \ OC Tweaker \ Voltage Configuration \ Fixed (Offset) Voltage, this option is to adjust CPU external voltage.
    Note: If users set CPU internal voltage and CPU external voltage at the same time, CPU voltage would only change based on CPU external voltage setting.
    Quelle
  • Offizelle AMD Ram-Support Liste Agesia 1.0.0.6 (06-2017)
X370 Taichi:
  • folgt, sobald was gesammelt wird
CPU-Kühler & Ram Kompabilitäts-Liste
X370 Taichi:
Ram:
CPU-Kühler:
Ram:
CPU-Kühler:
OC:
  • AMD Ryzen Processor and AMD Ryzen Master Over-clocking User’s Guide
  • Overclockers Ryzen Overclocking Guide
  • AMD Ryzen (Zen) "Summit Ridge" Socket AM4 OC Thread
  • AMDs Community Update #4: Let's Talk DRAM! (RamSpecs)
  • P-State Values:
    Code:
    Values for P State Overclocking -
    FID (Clock Speed) 90 - 3600mhz, 91 = 3625, 92 = 3650, 93 = 3675, 94 = 3700, 95 = 3725, 96 = 3750, 97 = 3775, 98 = 3800, 99 = 3825,
    9a = 3850, 9b = 3875, 9c = 3900, 9d = 3925, 9e = 3950, 9f = 3975
    a0 = 4000, a1 = 4025 (my max sweetspot OC), a2 = 4050, a3 = 4075, a4 = 4100, a5 = 4125, a6 = 4150, a7 = 4175, a8 = 4200 = a9 = 4225, aa = 4250, ab = 4275, ac = 4300, ad = ugh you win the lottery.
    Values for DID (Increment adjustment adjuster and or bclk adjustments, not too sure what it does TBH, as I found an overclock that I was already comfortable with and have not spent much time with this yet, though looking at it more closely, here are the values) - 8 = 25 mhz increments, 9 =22.2196, a = 20 b = 18.18, c = 16.667, d (final recommendation) = 15.384mhz - 3943mhz cap).
    Values for VID Voltage Control = 30 = 1.25v, 2f = 1.256v, 2e, 1.2562v, 2d = 1.268, 2c = 1.275v, 2b = 1.2812v, 2a = 1.287v, 29 = 1.293v, 28 = 1.3v, 27 = 1.3062v, 26 = 1.3125v, 25 = 1.318v, 24 = 1.325v, 23 = 1.3312v, 22 = 1.3375v, 21 = 1.343v, 20 = 1.35v, 1f = 1.356v, 1e = 1.3625v, 1d = 1.368v, 1c = 1.375v, 1b = 1.3812v, 1a = 1.3875v, 19 = 1.3937v, 18 = 1.4v, 17 = 1.406v, 16 = 1.4125v, 15 = 1.418v, 14 = 1.425v, 13 = 1.4321v, 12 = 1.4375v, 11 = 1.443v, 10 = 1.45v, *next set is from f - a, 9 - 9 (1.45 - 1.55v), though be very careful overclocking in this voltage range*.
  • Ryzen Timing Checker
  • AMD Memory OC Showdown: Frequency vs. Memory Timings
  • Ryzen DRAM Calculator
Ergbenisse:
(Blau = Taichi | Rot = Prof Gamnig)
  • Ryzen Modell | Quelle | Geschwindigkeit | Spannung | LLC | Bios
  • R7 1700 | immortuos | 3,9Ghz | 1,35V| 3 | 2.00
  • R5 1600 | darkpope| 3,85Ghz| 1,28V | 3 | 2.40
  • R7 1800X | jc110 | 4,05Ghz| 1,3925V | 3 | 2.40
  • R7 1700 | Nimrais | 3,50 Ghz| 1,2V | 3 | 2.40
  • R7 1700x | HW-Mann | 4,075 Ghz| 1,488V | ? | 3.00
  • R7 1600x | 4Stroke | 4,09 Ghz| ca. 1,4V | ? | 3.20
  • R7 1600x | reinhardrudi | 4,0Ghz | 1,376V| 3 | 3.20
  • R7 1600x | 4Stroke | 3,9 Ghz | 1,256V | ? | 3.10
to be continued
Das habe ich seit dem Wechsel von 2700x auf 3700x auf dem Desktop mit dem Biostar X570GT8. Das werden die schnellen Aenderungen der Zustaende des Prozessors sein. Dad koennte mit dem Update Einzug gehalten haben. Das werden die Spulen sein. Ist nicht weiter schlimm.
Danke für die Rückmeldung. Werde jetzt das BIOS 5.91 ausproblieren.
Jetzt sogar am Tage kann ich wieder dieses zirpen hören. Hört sich so an, als ob etwas auf dem Mainboard schmoren würde.
So. 5.91 ist drauf. Leider wieder diese gezirpe. Ist sogar ganz leise aus dem geschlossenen System rauszuhören.
@JZ. Kann dieses zirpen so mal bei dem ein oder anderen Board vorkommen, oder ist dies eher selten bzw. ist mein Board kurz vorm Ende?
Kann ich wieder das 5.80 bios einfach so vom USB Stick zurück flashen?
@nobrainer: Zurückflashen sollte bis zu 5.60 sollte problemlos gehen.
@JZ_: Habe gerade das 3.73 TestBios für mein X470 Taichi getestet und nach kurzem Testen muss ich sagen das es gut aussieht, leider geht mit dem Bios meine M.2 SATA SSD(neueste Firmware) wieder nicht und ich musste wieder auf 3.60 zurückflashen.
Ist bekannt ob der SATA Support von dem M.2 Slot mit AGESA 1.0.0.4 entfernt wurde? Habe leider keine andere M.2 SATA SSD da zum testen.
@CrazyCookie: Dann versuche ich es auf 5.60 (Auslieferungsbios) zurückzuflashen.
Zirpt dein X47ü auch von unter dem CPU Kühler (Spannungswandler?) her?
Werde meines wohl zurückgeben müssen. Wird zwischendurch immer lauter und hört sich gar nicht gut an.
@nobrainer
Kann ein Einzelfall sein oder liegt es am Netzteil ?
@CrazyCoockie
Muss ich prüfen lassen. Ich habe keine M2 SATA da. Sag mir mal deine Marke von der SSD und welchen Slot du verwendest. Richtig wäre der M2 Slot in der Ecke ganz unten.
@nobrainer: mein X470 Taichi ist mit meinem 3900X mucksmäuschenstill, auch mit den 1.0.0.4 Testbiosen. Wenn mein M.2 SATA Problem nicht wäre würde ich sofort das aktuelle Testbios mit 1.0.0.4B draufklatschen und nie wieder zurückblicken, so gut empfinde ich die neuen Biose.
Versuch doch mal ob die Einstellung für Power Supply Idle Control einen Einfluss auf dein Cpusockelzirpen hat. Du kannst sie unter Advanced -> AMD CBS -> CPU Common Options finden.
@JZ_: Es ist eine Western Digital WDS200T2B0B mit 2TB mit aktuellster Firmware und ich benutzte den oberen Slot, also Ultra M.2 Slot der direkt von der CPU kommt. Der untere Unterstützt laut Handbuch kein SATA.
Als ich die SSD gekauft habe wollte ich die sogar im unteren Slot betreiben weil der einfacher zugänglich ist, aber leider ging die dort nicht. Falls der SATA Support wirklich offziell im AGESA entfernt worden ist, werde ich mir einfach eine M.2 NVMe SSD kaufen.
@JZ
Dann ist es wohl eher ein Einzelfall. Mein Netzteil bleibt absolut still.
Hat denn das X470 Taichi bessere Spannungswandler oder ist es mit dem X370 Taichi gleichzusetzen. Bin nämlich sonst vom Taichi überzeugt. Die Spannungskühler sind gerade mal nur hauchwarm. Hat man später evtl. durch den kleineren Bioschip irgendwelche Nachteile?
Versuch mal deine Lüftersteuerung(Lüfter) testweise auf DC zu stellen - bei mir ist das Zirpen dann weg. Irgendwie vertägt sich die Lügersteuerung nicht mit meinen Silent Wings 3 Lüftern im PWM Modus
Klingt komisch ist aber so. Lüfter alle getestet und sind silent - aber speziell wenn am Chassis Fan 3 Anschluss ein Lüfter angeschlossen ist, ensteht bei PWM Steuerung lautes zirpen (Spulenfiepen Geräusch)
x470 Taichi mit 3700x
Dark Rock 4 Pro
4 x Silent Wings 3 High Speed
@show
Das ist ja ein Ding... werde das mal die Tage testen und vielen Dank für deine Info :)
Extrem ist es beim ersten ersten Boot am Tag - also wenn die Lüftersteuerung erste mal greift
@CrazyCookie
Hast du mal den unteren M2 Slot für SATA-SSD probiert, nicht der mit dem Kühlblech ?
Ich habe mal eine eMail Richtung TW geschrieben :)
Seit letztem Jahr hab ich den unteren Slot nicht mehr probiert. Vielleicht probier ich den heute nochmal. Ist halt viel Arbeit die Grafikkarte dafür extra auszubauen um an die SSD zu kommen.
Edit: So habe jetzt irgendeine Samsung M.2 SATA SSD aus dem Laptop ausgebaut und in den unteren Slot gesteckt und die wird nicht erkannt(mit Bios 3.60). So hab ich mir das Grafikkarte ausbauen erspart :d.
Wenn ich noch was testen soll sag Bescheid.
Dann probiere ich mal DC. Hab aber nur 3 Pol Gehäuselüfter. (Silent Wings 2).
Habe gestern abend nochmals das 5.60 und 5.80 Bios verglichen. Beim 5.60 ist das Zirpen deutlich leiser als bei 5.80. Deshalb habe ich es erst nach dem Biosupdate gehört. Ganz komisch.
Moin an alle,
ich bin ganz neu hier und habe seit 3 Tagen den 3900X auf dem X370 Taichi (Test-BIOS 5.91 von JZ) am laufen und bin sehr gut zufrieden.
Daher erst mal ein "RIESENGROSSES DANKESCHÖN" an JZ electronic.
@JZ_ Ist die 5.93 noch stabiler?
Grüße,
Marcel
@JZ_ Danke für die schnelle Antwort!
Ich hatte so viele Probleme mit dem RAM und diesem ganzen AGESA-Wahnsinn!
Hat die neue SMU Auswirkung auf den Speicher-Controler? Ich bin so froh, das ich nun mit 3600 MHz und 1800 Fabric fahre (HX436C17PB3AK4/32 und 5.91).
5.93 aufspielen oder erst beim 5.91 bleiben?
Grüße,
Marcel
Dann lass es doch so, wenn du damit zufrieden bist, denn jedes AGESA Update bzw. SMU Firmware bringt anderes Timinig mit sich ;)
Spiel dich ein bisschen mit der VDDG und der SoC Spannung du kannst sicher auch 3733MHz und 1866 auf der IF fahren. Bei meinem System wird erst 1900 auf der IF schwierig.
Moin an alle,
vielen Dank für eure Antworten.
Ich konnte es nicht lassen und habe die neue 5.93 aufgespielt. Leider noch richtig Zeit, alles zu testen. Cinebench und prime95 (ca. 25 min.) machen keine Probleme.
Allerdings habe ich die Timings von 16-16-16-32 auf 16-18-18-36 hochstellen müssen.
@CrazyCookie
Aktuell VDDG 0,95 und SoC auf 1.1 V. Wie hoch gehst du, wenn du beim Fabric 1.900 fährst?
Wie hoch ziehst du deine Ballistix? 2x 16 GB sind Dualrank oder? Bei der 1000'er-Reihe soll Vorteile gegeben haben - ist das bei den 3000 genauso?
Ich habe bei meinen HyperX explizit auf den Samsung B-Die geachtet. Oder ist das auch nur noch eine Legende, da die Chips, glaube ich, nicht mehr produziert werden?
Viele Fragen für einen Wiedereinsteiger - denn ich war ca. 20 Jahre raus.
Wenn ich es in deiner History richtig sehe, könnten wir ja auch über Matrox Millennium/Mystique oder Diamond's Monster schwelgen. Das waren noch Zeiten - Jumper setzen noch und nöcher!
Grüße,
Marcel
Anwort aus TW nach meiner Anfrage bzgl. M2 SATA
We did not face this symptom when testing in our lab.
If possible, please provide the motherboard name, SATA M.2 model and BIOS version for us.
Then we are able to do further check.
Habe jetzt deine M2 SATA Type zur Prüfung weitergeleitet :)
Kommt P5.91 oder gar P5.93 auch noch für das X370 Professional Gaming?
@CrazyCookie
Wenn ich es in deiner History richtig sehe, könnten wir ja auch über Matrox Millennium/Mystique oder Diamond's Monster schwelgen. Das waren noch Zeiten - Jumper setzen noch und nöcher.
Ich betreibe meine 3000er Ballistix im 24/7 Betrieb auf 3733 CL16-19-16-16-36 mit 1,37V. Ja meine Ballistix sind Dualrank. Ja Dualrank bringt auch bei der Ryzen 3000 leichte Vorteile, du hast aber den Vorteil auch weil du 2 Single Ranked Module pro Channel betreibst, das kommt aufs gleiche raus.
Samsung B-Dies sind super, die schaffen hohen Takt mit niedrigen Timings wenn du denen die Spannung gibst die sie dafür wollen(1,4-1,45V ist für B-Die 24/7 kein Problem wenn die Riegel nicht zu warm werden).
Bist du dir sicher dass bei dir die Fabric limitiert? Vielleicht musst du nur deine ProcODT senken. Ich betreibe meinen RAM mit ProcODT auf 32Ohm.
Und mit der VDDG würde ich gefühlsmäßig nicht über 1050mV gehen, zuviel VDDG kann sich auch negativ auf die Stabilität auswirken. Ich fahre bei 1866 IF mit 0,975V VDDG. Mehr ist nicht immer besser, kann auch sein das deine Fabric weniger Spannung mag.
Ohh Jaaaaa, Jumper setzen war noch was. Damals war OC noch einfach. Einfach 2-3 Jumper setzen und die CPU lief auf dem Wunschtakt. Jetzt muss man an unzähligen kleinen Stellschrauben im Bios rumspielen bis man ein zufriedenstellenden Ergebnis hat, das Biosrumgespiele hat aber auch seinen Reiz wenn man sich reinfuchsen will.
@JZ_: danke für die Info, mal gucken was Taiwan dann zurückmeldet :)
Es hat funktioniert, danke dir!!!
Die "Fabrik" wütet jetzt stabil auf 1866 Akkordarbeit. VDDP 0,9V
Die B-dies auf 1,45V @ 3733 16-16-16-32
:banana:
ProcODT habe ich auf 40 Ohm gelassen, wie der Ryzen RAM Calculator vorschlägt.
Die beste Leistung erziele ich im 4250 All Core OC mit 1,35 Vcore. Im Single-Core-bench leidet er ein wenig.
Jetzt hoffe ich nur, dass du deine M2 SATA zum laufen bekommst.
Nochmals vielen Dank und Grüße,
Marcel
@CrazyCookie
M2 SATA ist gefixt und anderes mehr ;)
JZ Board
Download im Laufe des Tages :d
- - - Updated - - -
BIOS wird später online gestellt :)
Komme zurzeit zu nichts. Bin nur noch mit BIOSe beschäftigt, aber ich habe noch so einen blöden Nebenjob und muss meine Brötchen verdienen :)
- - - Updated - - -
...ist jetzt online :)
@JZ_: Danke :) werd das Bios gleich heute noch testen.
Edit: Habs getestet und für Gut befunden. SSD funktioniert damit, Boost ist OK, nur die default SoC Spannung find ich mit 1,2V ein bisschen hoch, würde mich mit 1,1 Volt wohler fühlen. CLDO_VDDP ist ab Werk auch unnatürlich hoch. Habe beide Spannungen nachträglich auf ein für mich erträglicheres Niveau reduziert.
Ansonsten ist es ein Top Bios werd aber noch ein bisschen rumtesten bevor ich meine CPU zwecks Effizienz wieder in den 65 Watt Eco Modus schicke. Den Modus kann ich jedem nur empfehlen, spart bei mir über 60 Watt an der Steckdose gemessen für nur wenig Leistungsverlust unter Volllast.
Anbei ein Bild wie der 65 Watt Eco Modus bei mir Performt. (Die Anpassung der CLDO_VDDP hatte ich zum Screenshotzeitpunkt noch nicht durchgeführt).
@all: Was mich interessieren würde ist wie hoch eure 3900X im Normalbetrieb ohne PBO/ECO Mode während Cinebench R20 takten. Meiner läuft im Schnitt so bei 4050-4075 nachdem er bei so 4100 begonnen hat. Das kommt mir etwas wenig vor. Oder muss für guten Boost ein aktuelles Windows + AMD Treiber haben? Ich benutze ja noch das gute alte Windows 10 1511 weil Windows Updates einfach ewig dauern und ich noch keine Zeit hatte mein USB-Stick Windows zu aktualisieren.
Hab das Taichi zwar inzwischen an meine Freundin weitergereicht, aber gestern bei ihr auch mal das P5.93 geflasht.
Läuft soweit gut, Boot ist deutlich schneller, Boost 100~150 mhz Höher.
Über das Problem mit den Defaults bin ich auch gestolpert, sollte aber ja bereits gefixt sein :)
SOC Spannung: Da gibts noch n kleines Problem scheint mir. Ob da per default 1.2v drauf liegen bin ich nicht sicher, RyzenMaster zeigt aber dauerhaft 1.2v an. HWinfo hingegen zeigt das an was ich im Bios einstelle :hmm:
Lüfterdrezahl: für den Lüfter am CPU Lüfter-Anschluß wurden kurzfristig immer mal kurz Drehzahlwerte im 10k Bereich (54,000rpm) angezeigt. Bin mir ziemlich sicher, das war mit 5.80 nicht der Fall. Lüfter ist auch nicht über Y-Kabel angeschlossen oä.
Das Gezirpe kann ich übrigens auch bestätigen (5.80 und 5.93 gleichermaßen betroffen). Scheint mir aber was mit der CPU-Spannungsversorgung zu tun zu haben, ändert sich zumindest zeitgleich mit Lastveränderung auf den Kernen.
Der "Hack" mit den Lüftern (PWM>DC) hat leider nicht geholfen
Bin mir nicht sicher ob das erst mit Umstieg auf 3000er Ryzen kam. Ist hier aber auch nicht so laut, evtl war es schon immer vorhanden und ich habs nur nicht gehört weil PC unterm Tisch.
Freundin hat ihn jetzt aufm Tisch stehen (und aktuell offen^^) da fällt das mehr auf :d
Wenn du willst dass Ryzenmaster eine andere SoC Spannung anzeigt musst du die SoC Spannung bei "SoC/Uncore OC Voltage(VID)" einstellen. Ist schon etwas verwirrend geworden, glaub jetzt gibts im Bios schon 4 Punkte wo man die SoC Spannung einstellen kann.
Hast du das Zirpen auch wenn du den Windows Balanced Energiesparplan laufen hast?
