[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
Also bei 4ghz also 1ghz mehr als stock, brauch ich keine Erhöhung der NB Spannung. Sobald ich aber graka noch viel mehr OC braucht SB mehr Spannung sonst gibts Abstürze ;>
hi,
hab seit heute nun auch mein mars drin und nur noch probleme!!
1. mein XP will nich mehr rebooten, TFT bleibt dann schwarz (unter Vista gehts)
2. wenn ich ein PS/2 Gerät anstecke (Maus und Tastatur) werden meine USB Geräte nicht mehr erkannt und die PS/2 Geräte gehn auch nicht
Neustes Bios P11 ist drauf
Everest (4.5) geht auch nicht :(
jemand ne Idee ??
@1: Hab noch gar kein XP auf dem Board probiert.
@2: wer braucht denn noch ps2 Geräte? USB wird sogar in allen Bootmenus unterstützt.
Vll ist das Board kaputt? Ists Neuware?
ja soll Neuware sein !
Ist von der Cebit
Ich habs mir auch nicht ausgesucht das meine Maus nur PS2 hat :(
Werde es per Adapter versuchen *daumendrück*
@TobiasAlt
habe meine XP- Installation von meinem alten P35 Gigabyteboard übernommen, mit der das Mars problemlos startet. Kann jeden Modus einstellen (IDE, AHCI. RAID), weil alle Treiber drauf sind.
Bei einer "normalen" XP- Installation geht nur der IDE Modus. Ist bei dir vielleicht im BIOS AHCI oder RAID eingestellt?
PS/2 geht ohne Probleme mit dem Mars unter XP.
Dass der Bildschirm schwarz bleibt, hatte ich mal unter Vista. Das lag an den Standard Grafiktreibern. Oftmals hilft schon ein kurzes Abziehen des Bildschirmsteckers. Verbindet man den Bildschirmstecker erneut, ist das Bild wieder da.
mmh, ist Bios ist IDE eingestellt
Werde es heut mal testen, evtl. liegt es an der Maus/Tasturkombi die das Mars nicht mag
hab mir aus der Arbeit eine 0815 PS/2 Maus & Tastatur zum testen geliehen
später dazu mehr
Funktionieren Ruhezustand und Standby mit dem Board?
Schwanke zur Zeit noch zwischen dem Mars und dem Abit IX-38 QuadGT.
S3 funktioniert – Erwecken per Power Button und Maus Doppelklick.
Beim S4 kann man ja das Netzteil auch ausstellen. Das Erwecken geht dann per Powerknopf aber nicht per Mausdoppelklick. Das Erwecken aus S3 u. S4 per Zeitvorwahl habe ich noch nicht getestet. Die BIOS- Option ist aber vorhanden (getestet nur mit BIOS G30).
Sehr schön - danke für die ausführliche Antwort
von den Einstellmöglichkeiten her konnte ich kein Unterschied zwischen G30 u. P12 feststellen. Die Spannungen sind gleich hoch angesetzt. Das P12 ist aber aktueller und ein finales BIOS.
Werde auch noch andere BIOSe als das G30 testen:
Hatte meine E4400 @ 3 Ghz @1,42V (RAM: @1000Mhz @2,19V). Systemstabilitätstest lief einwandfrei und Temperaturen erstaunlich gering. Dennoch – wenn ein Computerspiel einige Zeit lief, fing es im Rechner plötzlich für 2-3 Sekunden an schnell zu „klacken“, das Bild fror ein und der Rechner stürzte ab. Ich hab keine Ahnung, was es sein kann.:confused:
Edit:
Es liegt wohl an der VCore und nicht am BIOS. Habe über Ägis Panel 1,425V eingestellt und alles rennt! Beachtlich auch die Kühlung: Der Xigmatek kühlt bei voller Drehzahl und Volllast die CPU auf 42°C (Temp. Case) herunter. Die NB hat gerade mal 37°C.
Hatte dieselben Einstellungen auf einem anderen P35 Board (Kühler AC Alpine 7). Nach nicht einmal einer Minute war die CPU über 60°C!
Hallo, ich habe das Board auch neu, aber so meine Probleme wo ich dringend Hilfe bräuchte... Bin mir nicht so richtig sicher ob ich folgendes verkehrt mache:
Mit dem Ram gibt es folgendes Problem dass er scheinbar nicht erkannt wird. Ich habe G-Skill DDRII2GB PC2-8000 2.0v-2.1V, davon 2 Stück.. auf welche Bänke stecke ich den Kram? 1+3? Der Ram läuft im anderen PC ohne Probleme.. Das Board ist schon getauscht, vorher Gigabyte, hab schon die Befürchtung der Prozz ist kaputt. Wie man den testet frage ich gerade in dem Beitrag http://www.forumdeluxx.de/forum/showthread.php?t=481574
2. Frage
Muss ich Strom an den "Exclusive Graphics Power Connector anschließen" oder bietet er praktisch einen Stromausgang für die Graka..?
Oh Mann ich bin am verweifeln, so blöd habe ich mich bei keinem der 20 PCs vorher angestellt.. HILFE!!
Danke
Mit dem Ram gibts keinerlei Probleme.
Habe 8GB davon auf dem Mars laufen. Werden korrekt erkannt. Soweit ich das mitbekommen
habe, hat TobiasAlt das gleiche Sys mit 8GB und es läuft ebenfalls.
Für Dualchannel müssen die gleichfarbigen slots bestückt werden.
"Exclusive graphics power connector" muss nicht angeschlossen werden, es sei denn du hast ein crossfire system.
24pol. ATX uns 8pol 12V sollten angeschlossen sein.
Falls du nur 20pol. und 4pol. am Netzteil hast so anschliessen wie im Handbuch beschrieben.
"cmos clear" könnte nicht schaden, um erstmal alles auf Standard zurückzusetzen.
Welche CPU? Welches Bios?
Erstmal sorry das ich in diesem Forum doppelt gespostet habe - es war meine pure Verweifelung..
Ich hab nun noch einen Celeron gekauft, damit läuft das System, Bios Update auf P11 und CPU gewechselt auf e8200 und es läuft nicht.. Muss ich P12 drauf machen?? Bei Foxconn steht bei P12 was mit CPU Wechsel Problem gelöst..
p12:"Fix bios boot will hang at C1h , after change CPU"
Meint ihr danach läuft der E8200 oder ist das Teil eventuell schrott?
PS Wo gibt es eigentlich die "G" Bios zum downloaden?` Danke
Hallo Zusammen
Kann mir bitte jemand die auf dem Bild markierten Abstände messen? Lochabstand bei NB und SB resp die Breite des mosfet coolers...
Vielen lieben Dank :hail:
gibts auf der hersteller seite wenn du ein login hast
Hinzugefügter Post:
kann mir mal jemand seine 24/7 ocing settings geben?
besonders würden mich die spannungen interessieren
atm fahr ich 9*333 werde aber natürlich noch mehr testen
...ausbauen wollte ich mein Board eigentlich nicht - solange es läuft.
Aber vielleicht kannst du beim technischen Support von Foxconn mal nachfragen (am Besten gleich in englisch). Bei technischen Fragen antworten die Ingenieure selbst.
Du kannst es auch mal im Mars Forum (über Quantum Force) versuchen. Dort sind sicherlich einige Hardcore OCer, die das Board ohne Gehäuse betreiben.
danke, bei foxconn habe ich schon nachgefragt, vor ca. einer woche und noch nie eine antwort erhalten... ich versuchs mal im quantum force forum, vielleich klappts da... ;)
Hinzugefügter Post:
da tummeln sich nicht gerade viele leute, könnte also auch noch länger gehen, bis ich ne antwort erhalte... :hmm:
also, wenn trotzdem jemand messen möchte... :wink:
sagt mal schwankt bei euch die vcore auch so stark ??
wollte gestern etwas ocen anfangen aber habe heftige vcore droops :(
bis 0,05v !
hab ich was falsch eingestellt ??
hab testweise 8*400 eingestellt mit einer vcore von 1,3125v im bios, cpu läuft nicht stable :(
für 9*333 brauch ich grad mal 1,12v auf meinem p5b dlx
die gleichen settings bekomme ich nicht mal mit eigengestellten 1,250v im bios stable !
liegt an der vollbestückung oder am ram teiler (@1000 mhz) ?
auf dem p5b dlx konnte ich ich nur 1:1 laufen lassen, also 333 mhz auf dem ram :(
für settings und tipps wäre ich dankbar
...aber daran gedacht, dass C1E funktioniert hast du, oder?
Hast du zwischen eingestellter VCore im BIOS und der in Windows unter Volllast angezeigten VCore (Everest) eine Differenz von 0,05V?
Ein Spannungsabfall so um 0,02V wäre vielleicht durch die fehlende Loadline Calibration (LLC) zu erklären.
Bei mir liegt bei 9x333 die VCore Differenz so um 0,02V:
Im BIOS muss ich für die VCore etwa 0,15V (1,4375V) mehr einstellen, als ich das von meinem Gigabyte Board gewohnt war. Dadurch, dass C1E funktioniert, bewegt sich die angezeigte Spannung zwischen 1,32V – 1,43V im Idle. (mit mehreren Zwischenschritten). Unter Volllast ist die angezeigte VCore dann 1,42V.
Bei der VDIMM liest das BIOS bei mir eine Defaultspannung von 1,89V aus, die auch in Everest angezeigt wird. Diese ist im Vergleich zu 1,82V (Gigabyte) recht hoch.
na der Droop ist ein bischen heftig, meiner liegt bei 0,016V.
Wüsste jetzt aber auch nicht warum das bei dir so groß ist :(
also atm läuft 8*425 stable *grins*
und das mit 8gb
hab einige settings nun anders als hier im forum gepostet und siehe da es geht nun
so gestern noch etwas weiter getestet
8*425 mit 5/6 Speicherteiler (102xMHz)
Vcore 1,2875
weniger Vcore bzw. mehr FSB/CPU Takt heute Abend :)
jetzt läuft es wie es laufen soll, vcore erhöht sich unter last :)
kann mir mal einer nen link zu dem foxupdater tool geben ich find da nix^^ dann mach ich mal des neue bios drauf
Ähnliche Themen
