Keinen Support mehr was Bios oder Software angeht von Abit fürs Board da Discontinued!
*Hoffe dieser Thread entspricht denn Regeln ein Ordentlicher Sammelthread zu sein*
Abit NF-M2 nView
Inhalt:
1.)Specification
2.)Unterstützte CPUs
3.)BIOS (OC-Einstellungen)
4.)"Besonderheiten/Problemlösung"
5.)Memory Compatibility
6.)Links&Downloads
**SammelThread**
Ein Paar Impressionen zum Board von MFloX
6.)Links&Downloads
**SammelThread**
1.)
Specification :
CPU
* Designed for AMD® Socket AM2 Processors with 2000M T/s system bus using Hyper Transport Technology
* AMD® Cool 'n' Quiet Technology
Chipset
* NVIDIA® 6150/NF430 Chipset
Memory
* 4 X 240-pin DIMM sockets support max. memory capacity 8GB
* Supports Dual Channel DDR2 800 un-buffered ECC / Non-ECC memory
Graphics
* Integrated GeForce®6150 Graphics
* Support DirectX 9.0, Shader Model 3.0, nView™
LAN
* NVIDIA Gigabit Ethernet
Audio
* On board 7.1 CH HD Audio CODEC
* Auto Jack Sensing and optical S/P DIF In/Out
Expansion Slots
* 1 x PCI-E X16, 1 x PCI-E X1, 2 x PCI
Internal I/O
* 1 x Floppy Port supports up to 2.88M B
* 2 x Ultra DMA 133/100/66/33 IDE Connector
* 2 x USB2.0 header (support 4 ports)
* 4 x SATA 3Gb/s connector
* 1 x IEEE1394 header
Back Panel I/O
* 1 x PS/2 Keyboard, 1 x PS/2 Mouse
* 7.1 CH HD Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround)
* 4 x USB2.0, 1 x RJ-45 LAN Connector, 1 x 1394
* 1 x DVI, 1 x D-Sub, 1 x S/P DIF In, 1 x S/P DIF Out
Serial ATA
* 4 x SATA (RAID) 3G b/s
* Supports SATA RAID 0/1/0+1/5
Form Factor
* mATX form factor 245 x 245m m
* PCB Color: Blue
RoHS
* 100% lead-free process and RoHS compliant
abit Engineered
* abit SoftMenu™ Technology
* abit Silent OTES™ Technology (Patent No. M273189)
Wird der Phenom unterstützt?
Abit is working on BIOS updates at this point. I did ask for one for the NF-M2, no answer from Taiwan yet
3.)BIOS (OC-Einstellungen):
- Vcore: 1,20V - 2,00V !! (per RMClock auch undervolten möglich --> 0,55V bis 1,25V)
- CPU-Multi in 0,5 Schritten: 4 - 11 (X2 4200+ EE)
- DDR-Voltage: 1,75V bis 2,5V !!
- DDR Reference Voltage: -2% / + 2% / -4% / + 0,0%
- Chipset Core (NB) Voltage: 1,20V - 1,60V
- SB Core AUX Voltage: 1,5V - 1,74V
- Hyper Transport Voltage: 1,2V - 1,4V
- Referenztakt (HT-FSB): 200 - 400 MHz
- K8 <-> NB HT Speed: Multi von 1 - 5
- NB <-> SB HT Speed: Multi von 1 - 5
- PCIE Clock: 100 - 145 MHz
- DDR Clock: 400 / 533 / 667 / 800 MHz
- RAM-Timings: alles wichtige inkl. CR 1T/2T
4.)"Besonderheiten/Problemlösung" :
Vcore Schwankung:
Das Board Übervolted ein wenig so das man statt 1,35V im Bios 1,30V Einstellen muß um 1,325V-1,350V zu bekommen.
Wird NCQ Unterstützt :
Ja wird Unterstützt und ist Ein und Abschaltbar .Man benötigt die nVidia eigenen Treiber (nForce SATA/IDE-Treiber)
Werden die EE CPUs Unterstützt :
Ja alle EEs werden Ordnungs gemäß vom Bios erkannt.
Lösung für die CPU Lüftersteuerung wenn ein 3Pin Lüfter vorhanden ist :
Der 4pin CPU-Lüfteranschluss kann nur mit 4pin Lüfter korrekt umgehen bzw. diese Regeln. Deshalb muss man den CPU-Lüfter an den 3pin "System"-Lüfteranschluss anschließen und im BIOS (oder unter Windows mit dem Tool von Abit) unter "PC Health Status" bei "Reference Temp" von SYSTEM auf CPU wechseln, dann erkennt das Board auch korrekt, dass es sich nun um den CPU-Lüfter und nicht um einen System-Lüfter handelt. Dann noch die Zieltemperaturen (z.B. 42°C), die Toleranz (z.B. 5°C) und Start- und Stop-Kontrolle (z.B. 60%/40%) nach belieben festlegen. Nun sollte der Lüfter spätesten wenn Windows geladen ist deutlich herunterregeln.
Einschalt Problem:
Bei einigen Amis wollte das Board nicht Starten nachdem Einschalten.Hierzu Rät Abit Grundsätzlich vor dem Einschalten einen CMOS Reset durchzuführen.
Der CMOS-Reset Jumper kann locker sitzen, so dass der Jumper nicht richtig sitzt und keinen Kontakt zu den Füßchen hat.Ein Austausch wäre hier zu bevorzugen.
PC Bootet nicht:
Da bei vielen Probleme waren in bezug auf : Kein Booten nach dem Bios verlassen.
Soll heißen man kommt in Bios kann auch alles Einstellen doch nachdem verlassen des Bios Bootet das Sys dennoch nicht.
Einfach die Ram Spannung mal von Auto bzw Standard auf 1,9V - 1,95V stellen.
Da grade der Ram viele Probleme macht auch wenn er für 1,8V betrieb vorgesehen ist.
5.)
Memory Compatibility :
Ram User Tests
ROT = Schlecht Grün = Alles OK
Mit dem original BIOS 9/1/06, mag das Board nicht jeden Ram.
Ram User Tests
OCZ 2x512Meg 240-Pin DDR2 OCZ2P6671GK möchte manchmal nich Windows Booten oder es gibt auch kein Post von sich
-Corsair XMS2-8500 DDR2 1066 C5 einwandfrei.
-Crucial Ballistix 1GB (2 x 512MB) DDR2 667 (PC2 5300) einwandfrei.
-GEIL 2GB Kit PC2-6400U CL4-4-4-12 (DDR2-800) (GX22GB6400UDC) einwandfrei.
-Corsair XMS2 1GB Kit PC2-5400U CL4-4-4-12 (DDR2-675) (TWIN2X1024-5400C4) einwandfrei.
-TwinMos Twister 2x256MB CL4 einwandfrei.
-Aeneon, DDR2 667 CL5 (AET760UD00-30DA98Z) einwandfrei.
-MDT 2x512MB DDR2 667 CL4 einwandfrei.
-Cellshock DIMM Kit 2048MB PC2-6400U CL4-4-4-12 einwandfrei
-G.Skill F2-6400CL5D-2GBNQ DDR2 800er CL5-5-5-15 einwandfrei
4x 1GB Crucial Value DDR2-533 CL4 mit Micron D9GMH einwandfrei
6.)
Links&Downloads :
Hersteller Link :
Klick mich bin ein Link
Bios :
BIOS ID:11 Klick mich bin ein Link
BIOS ID: 12 Klick mich bin ein LinkFirst Relaese
BiosID: 13 Klick mich bin ein Link1. Fixing RAID Hard Disk Boot Priority function issue
2. Fixing ABITEQ,Beep when S3 Resume issue
3. Fixing BIOS,CPU Warning Temperature issue
4. Fixing BIOS,PC Health not match Design Guide issue
5. Fixing "POST screen broken after ACPI,S1 Wake Up when USB Mouse was inserted" issue
6. Fixing BIOS,USB Keyboard Support-BIOS Function issue
7. Fixing BIOS "Restore On AC Power Loss" / "Last State Function" fail issue
8. Fixing BIOS,String abnormal when use DOMEX DMX3194 SCSICard
9. Fixing dPCIe,ARECA ARC1210 no boot ROM Abnormal On PCIEXP
10. Moving IRQ7 option
11. Moving Current DRAM Status "MHz" string.
12. Fixing USB KB Support-BIOS function fail on RAID ROM
13. Fixing BIOS,1394 disabled function fail issue
14. Fixing BIOS,Boot priority USB-ZIP string
15. Fixing BIOS User define FID change to default when S3 resume.
16. Update Agesa 2.06.11 version support Rev G cpu.
Bios ID: 14 Klick mich bin ein Link1. Fixing WHQL,DTM pre-test failed for Windows Vista Logo.
2. Update code to AMD AGESA Version 2.08.00.
Bios ID: 15 Klick mich bin ein LinkBeta bios 14 b01
1. Fixing BIOS, the SATA string & date.
2. Fixing BIOS, the "HyperTransport" string.
3. Fixing BIOS, can't adjust 1/2 multiplier for AMD Rev F CPU.
4. Update code to AMD AGESA Version 2.08.03
Bios ID: 16 Klick mich bin ein Link1. Support Sempron LE series CPU.
2. BIOS compiled date: 09/03/2007.
Treiber :
- Update CPU Micro code to support Athlon 4X50 series and Sempron X2 CPU.
- BIOS compiled date: 07/14/2008.
FTP von Abit :
Deutsches Handbuch als PDF :
Deutsches Faq auf der Abit Seite :
Review :
Bilder vom Board :
Mod-Bios Sammlung :
Verbrauchs Werte Beispiel von che new :
Erste Benches von che new und Eindruck :
AM2 Threads :
AM2 X2 OC Thread von Mondrial :
OC Thread von checkpot :
AM2 Sammelthread von [TLR]Snoopy :
Übersicht aktueller AM2 Mainboards von FischOderAal :
Board bei Geizhals :
che new : für seinen Test und ersten Eindrücken vom Board.
So das wars erstmal alles weitere was fehlen sollte wird Hinzugefügt.Da mein Board+CPU noch nicht da sind kann ich auch noch nichts dazu sagen.
Doch oben im Review wurde sich sehr Positive geäußert über das Board.
Olli
Für eins, was kaum gelaufen ist, super funktioniert, ja nicht mal verstaubt ist und mit sämtlichem Zubehör (müßt ich alles noch im Karton haben).
