[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
kannst du mal bitte den Everest Benchmark durchlaufen lassen? Hab 8gb noch nicht in Action gesehen :)
Hab bei Foxconn mal angefragt:
Es ist nur die Rev. 1.0 im Handel. ;)
Was gut is muss man auch nich verbessern!^^
Bei dem Vcore menü gibt es ja noch ein paar andere werte siehe bild.
was kann bzw sollte man den beim übertakten evtl erhöen? Also NB und CPU is klar, so hab ichs bisher immer gemacht aber der Rest macht mich etwas verwirrt:hmm:
welches Bild? :shot:
also ich hab auch ne ganze Zeit damit verbracht die ganzen Einstellungen auszutesten, allerdings hat das in der Stabilität überhaupt keinen Unterschied gemacht. Den größten Einfluss haben NB und FSB Voltage...
hoppla des bild hab ich gemeint, aber wenn die anderen spannungen nix bringen.:bigok:
kannst ja mal ausprobieren ob sich das beim Quad anders verhält.
Hi!
Ist der zweite PCIe Anschluss nun eigentlich 16x oder nur 4x?
Die Aussagen sind widersprüchlich. :confused:
Moin!
Hab nun mein Mars auch verbaut, war bis eben auch super zufrieden. Aber irgendwie war grad bei einem Boot von Vista auf einmal immer, wenn ein Sound kam, ein ekelhafter Quieksen der Boxen zu hören...und das nicht gerade leise.
Nach nem Reboot wars wieder weg, ich hoffe irgendwie mal, dass das ne einmalige Sache war.
Hab sonst irgendwie keinen Plan, was das sein könnte....
es ist ein PCIx 16x
der aber nur 4x angebunden is
also 4x
@loneclone
a des prob hab ich auch oder ein ähnliches. hast du auch geräusche, wenn du ne mp3 abspielst?
wenn ja kann ich dich beruhigen, es liegt am grakatreiber
Es liegt am GrakaTreiber?!?
Naja, also ich hatte ne alte Aureon 5.1 Fun drin, hab die aber jetzt mal rausgeschmissen und muss sagen, dass der Onboard-Sound erträglich ist...und die komischen Geräusche sind auch weg.
Nu werd ich mich mal an OCen machen. Temps sehen schonmal super aus, mal schauen, wie hoch ich meinen Q6600 geprügelt bekomme.
€dit: Hab da jetzt nochmal ne Frage: Wie kann ich das EIST vollständig ausschalten? Immer wenn ich es im Bios deaktiviere, geht es unter Vista immer noch...ich will aber ständige Vollpower. *grml*
Genau das wurde in einem der Mars Tests auch bemängelt. Man hatte das einem Bug im BIOS zugeschrieben. Vielleicht ist es ja in einem neueren BIOS schon gefixt.
also EIST einfach ausschalten, was du noch machen kannst ist C1E zu deaktivieren...
Bei mir gehts.
@kurbel
in deiner Signatur sehe ich auch ein Abit IP35-E, bei dem man im BIOS die VCore nicht untervolten kann. Ein User in Computerbase behauptet, dass es mit CrytalCPU in Windows ginge. Kannst du das bestätigen?
Kannst du ungefähr abschätzen, wie groß die Unterschiede zwischen Mars und IP35 sind (Temperaturen, Performance)? Das setzt natürlich voraus, dass man beide Boards mit den selben Komponenten bestückt hat.
also mit Tools wie RMClock etc kannst du immer unter Windows Undervolten, das hat nichts mit dem Board zu tun.
Das Abit ist schon länger Schrott, hab auch keinen Vergleich gemacht. Könnte es eigentlich mal aus der Signatur löschen^^
also die P35 Boards von MSI haben im BIOS auch alle die Default- VCore als Minimum. Habe im MSI- Forum wegen Undervolting unter Windows nachgefragt. Offenbar geht es bei MSI aber nicht.
Weiß jemand, ob der CPU- Kühler Xigmatek S1283 auf das Mars passt?
ja lag echt am grakatreiber!^^
hab mir schon sorgen gemacht, das was mit meinem Board nicht okay is, aber bevor mans einschickt erstmal testen--> Windows Vista Premium 64 neuinstalliert, und einen treiber nach den anderen installiert und dann getest. Zuerst dachte ich es läge am Realtektreiber. Tja puste kuchen wie sich am ende herausgestellt hat wars dann die forceware. Hab dann verschiedene ausprobiert und hab dann die genommen wos am wenigsten aufgefallen is.^^
ja allerdings, aber nuja is nun mal so.
Mein verstärker hat sich sowieso verabschiedet und über die popel Speaker vom tft.:shot:
jop. gut das er welche hat sonst wärs ziemlich ruih!^^
naja statt der 4gb speicher kauf ich mir etz nen verstärker. es is zum heulen.:haha:
Ähnliche Themen
