[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
na ich wär ganz klar fürs mars beim dfi gibts doch ein paar probs, was man so in deren st liest
sagen wirs mal so, die im sammelthread beschriebenen probleme, haben mich dazu bewegt mich nochmals umzuschauen... :hmm: aber schlauer bin ich trotzdem noch nicht geworden!!
naja muss jetzt sowieso noch für 4 wochen ins militär, dann siehts dann vielleicht schon wieder anders aus... :bigok:
stimmt vielleicht brauchst dann gar nix mehr!^^:shot:
Na kauf ihn test ihn und wenn er nicht draufpasst zurück schicken. is ja nix wo man nicht mehr zurückgeben könnte und die rückversandkosten, muss der shop zahlen da warenwet über 40 euro.
weil des board würd ich schon nehmen dann muss halt zu not ein anderer kühler her gibt ja viele gut alternativen, die mit dem ifx14 mithalten können.
schau mal bei cbase die lüfter tests an
@martensch:
oder frag mal bei einem Shop an, ob die das für dich testen können. Wenn es passt kannst ja dort gleich bestellen ;)
Dass man bei dem P35- Board die CPU untervolten kann und auch C1E/EIST bei manueller Vcore funktioniert, macht es einzigartig. Ich spiele mit dem Gedanken es zu kaufen.
Nur bin ich über einen Link gestolpert: Dort haben sich bei einem Testexemplar (!!!) des Foxconn Mars einige SMD- Bestandteile gelöst (und FSB 450 blieb schon hängen). Man spricht von einem Transportschaden. Ich bin da skeptisch. Es ist doch eigenartig, dass bei einem Transportschaden nur solch winzig kleine Teilchen betroffen sind. Ein Qualitätsproblem ist da wahrscheinlicher. Dass bei einigen Foxconn Mars FSB 500 nicht ging, hab ich auch schon mehrfach gelesen.
http://www.tomshardware.com/de/fotostrecken/Foxconn-Mars-lost-parts-big,0101-51424-0-2-3-1-jpg-.htm
steth doch da da das ersatz board hat dann 500mhz geschafft.
wo hast du des gelesen, das die boards nicht 500MHz schaffen?.
Links würden mich da interessieren
ein hoher FSB hängt zudem auch mehr von der CPU ab.
Eine allgemeine Aussage, dass das Mars die 500 FSB nicht schafft, habe ich natürlich nicht gelesen. Es kam aber bei dem einen oder anderen User mal vor. So auch z. B. in diesem Thread ab Post #136.
Aber ihr habt natürlich Recht, dass meistens eine Einstellungssache und kein Hardwarefehler vorliegt. Ich habe beim Computerversand MIX mal angefragt, ob dieser Fehler (Post #186) aufgetreten bzw. Reklamationen eingegangen sind. Fehler dieser Art sind dort nicht bekannt.
Hat eigentlich schon jemand eine zweite Rev.?
Gibts überhaupt schon ne 2. Rev?
Ich denk des sin dann ausnahmen, wenn die boards so schlecht gehen sollten und wahrscheinlich iwas falsch eingestellt.
@kurbel inwiefern spielt da die cpu ne rolle? auch wenn man den multi senkt?
in erster Linie muss die CPU auch einen hohen FSB mitmachen, sonst nützt einem das beste Board nichts. Bestes Beispiel sind die Quads, die schaffen alle keinen hohen FSB ;)
Mir ist da noch was aufgefallen:
im Sammelthread Foxconn P35A-S regelt der CPU-FAN einen 4 PIN Lüfter unter PWM nicht richtig runter (ab Post #24 des folgenden Links):
http://www.forumdeluxx.de/forum/showthread.php?t=429698
Dieses Board hat wohl die gleiche Lüftersteuerung wie das Mars. Hat schon jemand mit dem Mars einen 4- PIN Lüfter am CPU- Fananschluß mit minimaler Drehzahl betreiben können (im Idle nach Kaltstart)?
Vermutlich laufen 3 PIN- Lüfter am 4- PIN- Anschluss immer 100%, weil man nicht auf Voltage umstellen kann, oder?
hallo
spiele nun auch mit dem gedanken das mars zu kaufen
schwanke grad zwischen dfi und dem foxconn
hat jemand 8gb auf dem mars laufen?
geht der trcd wert über 42 ??
Moin moin!
Ich werd wohl ab morgen auch das erste Mal ein Foxconn in der Hand halten.
Hoffe mal, dass ich damit um einiges zufriedener bin als mit dem Striker, das ich momentan noch habe.
Nochmal zu der Frage, ob der IFX-14 passt....hat den jemand inzwischen verbaut? Wär zu schade, wenn ich den auch verkaufen müsste...
Naja, ich bin aber noch frohen Mutes, die Heatpipe Konstruktion auf dem Striker ist ja auch nicht gerade klein.
Für alle, die es dann interessiert, ob er passt oder nicht, ich kann dann wohl morgen oder übermorgen die Antort geben. ;)
@Tobias&Lord:
kann ich für euch heut Nachmittag testen ;)
Vllt. machst du ja heute noch ein Schnäppchen wie ich im Marktplatz gesehen hab...
Wenn ich überlege wieviel ich für das Board bezahlt hab :shot:
ja meine das lanparty dk :)
kann man beim mars den trcd wert über 42 setzen so in richtung 52/55 ??
und vollbestückung mit 8gb würden mich interessieren
vdroop gibts ja hier nicht oder?
oder einen cold boot bug ?
ich glaub du meinst tRFC, den kann man bis 78 im Bios einstellen
hab nur 6gb hier, aber die funktionieren (auch OC)
doch den gibts
kann ich dir nicht sagen
lies Dir mal ersten beiden seiten durch. da wurde das diskutiert.
Habe 8GB TakeMS auf meinem Mars. Laufen ohne Probleme, mit Standardtimings DDR800.
Falls du mit "cold boot bug" das zweimalige Starten im übertakteten Zustand meinst, ja der
ist vorhanden. Fallen aber nicht ins Gewicht die paar Sekunden.
Ähnliche Themen
