[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
Leider kein Tip. Bei mir hats ohne Probleme funktioniert.
Nachdem meine X-fi unter XP64 nicht ordentlich laufen wollte hab ich sie rausgeworfen, den
onboard sound im Bios aktiviert. Dann kommt der übliche Windows Hinweis ob man nach Treibern suchen soll. Abgebrochen und die Realtek Treiber 1.86 installiert. Nach dem nächsten Neustart lief alles.
Dafür hab ich immer noch das Problem beim starten.
1.86 find ich bei realtek nimmer auf der site :( ich versuche es mit dem 1.87 aber immerwieder spuckt er mir am ende diese Fehlermeldung aus:
EDIT1: zieh gerade den 1.86, mal sehen obs damit funktioniert.
EDIT2: funktioniert auch nicht...kommt genau die gleiche Fehlermeldung
Sorry, habe vergessen zu erwähnen, das mein sys nach Aktivierung des onboard sounds noch folgendes über Windows update heruntergeladen hat: "Microsoft UAA Bus Driver for High Definition Audio". Taucht danach im Gerätemanager unter "System" auf.
PS. Nach einspielen des G29 Bios sind meine Startprobleme verschwunden.
klingt ja schonmal gut ;)
Werd dann wohl auch noch das G29 Bios ausprobieren...
Welche startprobleme?
das hier :
Habe am Wochenende mein Mars in Betrieb genommen und folgendes Problem für das ich eine Lösung brauche:
Jedesmal wenn ich den Rechner ausschalte bleibt er beim nächsten booten nach dem erkennen der Laufwerke hängen. Bios Postscreen und aus. Danach Warmstart und alles klappt wunderbar. Hatte erst meine schaltbare Steckerleiste im Verdacht, wars aber nicht.
Auch wenn ich den Rechner nicht vom Netz trenne bleibt er nach dem Ausschalten beim ersten Versuch hängen.
Bios Versionen P11 und G30 getestet.
Das ganze mit Q6600 G0, Corsair NT, Gainward 8800GT, alles auf Standard, kein oc.
Wäre für nen Rat dankbar.
Aso!
hat jmd auch mein problem?
Neues Bios ist draußen P11
Soll ich des dann nehmen oder des G30?
das P11 ist neuer als das G30, wobei das Releasedatum auch schon der 2.1.08 war. Wundert mich warum das jetzt erst online ist..
dann nehm ich des p11
wo sieht man auf der HP von QF den das release datum?
Hab nix gefunden, vielleicht auch ienfach nur blind
na zumindest wurde das Bios am 2.1. erstellt und ist somit neuer als das G30...
Also neuestes Bios(p11) is drauf und mein neustart+ins bios gehen problem is verschwunden.
Aber etz aber noch ne frage und zwar zeigt mir everest(4.2 und auch die neuste Beta) ne NB-Spannung von 1.7 an. obwohl im bios 1,25 eingestellt sin.
Und dann noch eine Frage kann sein das die Spannung der NB beim P09 Bois standardmäßig auf 1,5V war? Oder hab ich mir des eingebildet?
das mit Everest ist mir auch schon aufgefallen, das Aegis Panel zeigt aber die im Bios eingestellte Spannung an.
Beim P9 Bios guck ich vllt. nachher mal nach, wenn ich das Board wieder drin hab...
Des wäre net bei mir freezt der rechner, wenn ich das neuste Panel starten will zumindest wenn ich ihn auf min 3GHz(sin stable) betreibe
Musste jetzt das G30 drauf machen, da mein QX9650 vom P11 nicht richtig erkannt wurde, bzw immer nur ein 9x Multi im Win angezeigt wurde.
Ja bei mir zeigt Aegis auch 1,26 an.
hab etz mal nach der frage cpu.... statt auf ok auf cancel gedrückt
hallo zusammen
wenn man eure post so durchliest überlege ich mir echt anstelle des DFI DK P35 ein Foxconn Mars zuzulegen.
Passt denn ein Thermalright IFX-14 auf das Board, und zwar zum Gehäuse hintern hin und nicht quer zum NT?!
Danke für Eure Antworten. :bigok:
Sorry kann dir leider nicht helfen.waküler!^^
Hab aber ein Problem und zwar hab ich soundprobleme unter vista 64 nachdem ich den nvidia treiber installiert hab egal ob beta oder original. habt ihr des auch bzw was kann ich dagegen machen?
@martensch:
ich hab nur den Sythe Ninja mal verbaut gehabt...
Ja, der Ninja ist kleiner als der IFX 14.
Ich habe schon den Scythe Infinity (Mugen), den Thermalright Ultra 120 Extreme und den Thermalright HR-01 Plus auf dem Mars getestet. Passen alle.
Hallo leute, hoffe noch heute meinen MARS zu haben , beste bios fur QX9650 G29 ? oder etwas anderes...
Danke sehr...
G30. Dann wird er erst richtig erkannt und es gehen alle Teiler.
Mit dem Neusten Offiziellen P11 hatte ich da ziemliche Schwierigkeiten.
Bios bekommste bei Quantum Force.
offenbar hat also niemand einen Thermalright IFX-14 auf dem MARS am laufen... Schade, denn ich sollte schon wissen, ob er drauf passt!
Eine andere Frage, sind die OC-Funktionen ebenfalls so umfangreich wie beim DFI Lanparty DK P35-T2RS? thanks
Das nötigste kannste einstellen. Ich kann aber mehr auf meinen Asus Blitz Formula / Asus Maximus Extreme einstellen.
Das Bios ist gewöhnungsbedürftig. Aber soll doch gute Performance haben.
Habe mir eigentlich nur zum Benchen geholt. :drool:
@martensch:
das DFI hat mehr Einstellungen, ob das nun aber ein Vorteil ist sei mal dahingestellt...
@martensch:
Das DFI ist bekannt dafür, dass man extrem viel einstellen kann, was die sache dann auch kompliziert machen kann!
Zum Benchen scheint das MARS extrem beliebt zu sein. Och mann ich weiss nicht welches Board ich mir anschaffen soll...
Ähnliche Themen
