[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
:kotz: bei mir ist jedes OC tool verpönt.. BIOS! - Da weis man was man hat!
damit kann man auch nicht übertakten, ist ein reines Diagnose Tool.
Hallo, hab heute mein Mars bekommen und hab mal ne Frage wegen IRQ sharing, da sich die
Handbücher ja darüber ausschweigen.
Möchte gerne wissen, welcher PCI slot für meine X-fi der geeignetste ist und mit möglichst wenigen, oder besser gar keinen, onboard Komponenten shared.
Bedanke mich schon mal für eure Antworten.
Und C1E funktioniert auch mit manuel eingestellten Vcore? (z.B. 1.4?) und im idle dann halt 1,15 oder?
ICh weis, dass wir das schon mal hatten, würde aber noch gerne ein paar andere Feedbacks haben.
ja funktioniert, kannst z.B. auch einen festen Multi einstellen und im Idle geht der Multi trotzdem noch runter ;)
dann empfehl ich dir doch unten im Aegis Panel mal auf OC (rot) zu klicken... und dann erklär er mir warum man den FSB etc verstellen kann, und was hinten der apply knopf zu suchen hat? ;)
diese Funktion ist erst in Version 1.0.2.15 enthalten, hatte noch die alte drauf ;)
Habe dass Board nun auch.
Blicke nicht ganz durch, kaum ändere ich irgend eine EInstellung, startet die KIstet nicht, sondern peept nur noch vor sich hin. Egal was ich ändere !? Schon nur wenn ich den Onboard Sound deaktiviere oder das DISK Laufwerk ausschalte
irgendeine defekte Hardware? Setup Defaults geladen? Werden die SPD´s der Speicher nicht richtig ausgelesen?
Nun funzt alles Patriot Ram raus und OCZ rein und das problem war weg.. sind wohl doch nicht viel wert...
hast mal probiert die Timings manuell einzustellen?
Nein ich habe die RAMS nun draussen, der eine Riegel scheint kommplet zu spinnen ! MIt den OCZ haben wir nun keine Probs... es läuft sauber.
Ich habe nun dass Board auch noch für meine Kiste mit dem Q6600 er und 4 Gigs OCZ Platinium 800er. freue mich schon auf den Einbau.
na dann kannst ja den Ram trotzdem auf Fehler überprüfen und notfalls in die RMA schicken ;)
Stimmt hat ja Lebenslang Garantie.............
Hi
Habe das Board nun auch. Und gleich paar Probleme.
Bin grad am testen mit meinem neuen Foxconn Mars und ner Kokü.
CPU ist ein E8200 (unter wakü auf Maximus Extreme FSB 545)
Jetzt habe ich gerade die Kokü mal drauf gebaut.
Nun habe ich das Problem das alles was über 480FSB geht nach kurzer Zeit freezt.
Liegt das nun an der Kälte oder gibt es da paar Tricks bei der Einstellung?
Bios habe ich das neuste von der Foxconn HP drauf gemacht.
500x6 bootet nicht. Scheint das das Board da schon zumacht?
Dann nochmal den E1200 unter Kokü probiert. 390FSB ohne Probleme, 400FSB sofort freez (unter wakü auf Maximus Extreme FSB 430 zum Benchen)
Jemand ein Tipp für mich?
also ich kann mit den Standardwerten gleich 500Mhz stable fahren. Hast du in Windows mal versucht den FSB hochzutakten oder friert der da auch gleich ein?
Mit 500FSB will er nicht starten.Und im Win mit SetFsb friert er auch bei 500 ein, 480 gehn. CPU macht auf anderen Board 545 mit.
Das komische ist, das das beim E1200 auch so ist nur bei 400FSB da gehen 390 ohne Probleme 400 friert ein.
das ist wirklich komisch...Hast du die Timings deiner Rams manuell eingestellt? Anosonsten bleibt halt nur noch Spannung der NB und CPU PLL etc zu erhöhen und zu testen ob das dann geht.
Timings sind auf SPD. Manuell bringt auch nix. Spannungen habe ich auch schon angehoben.
Kann doch nicht sein das die CPU´s darauf viel schlechter laufen, als auf meinem Asus Maximus Extreme X38
also dann kommt ja nicht mehr viel in Frage. Hast du die Möglichkeit mal ohne Kokü nen hohen FSB zu testen?
Mit Lukü das selbe wie mit Kokü. Überhaupt kein Unterschied.
Habe am Wochenende mein Mars in Betrieb genommen und folgendes Problem für das ich eine Lösung brauche:
Jedesmal wenn ich den Rechner ausschalte bleibt er beim nächsten booten nach dem erkennen der Laufwerke hängen. Bios Postscreen und aus. Danach Warmstart und alles klappt wunderbar. Hatte erst meine schaltbare Steckerleiste im Verdacht, wars aber nicht.
Auch wenn ich den Rechner nicht vom Netz trenne bleibt er nach dem Ausschalten beim ersten Versuch hängen.
Bios Versionen P11 und G30 getestet.
Das ganze mit Q6600 G0, Corsair NT, Gainward 8800GT, alles auf Standard, kein oc.
Wäre für nen Rat dankbar.
hatte ich auch bei mir waren wohl die 2 12volt Stecker auf dem Board locker , einmal raus und wieder eingesteckt und dann gings wieder ohne Probs.
Hat von euch jemand auch das problem dass sich die onboard soundkarte nich installieren lässt?
Versteh nicht warum es bei mir nocht funktioniert...treiber der cd versucht, aktuellen von der QF homepage doch es geht nicht.
Nichtmal ne richtige Fehlermeldung, nur treiber konnte nicht installiert werden!?
Audio ist aber im Bios aktiviert?
jup is natürlich aktiv...windows erkennt die soundkarte ja auch, aber die installation schlägt immer fehl.
So hab auch ein problem und zwar wenn ich den pc gestartet habe und dann nachdfem win vista 64 hochgefahren is neustarte und ins bios will, kann ich nicht!er bootet einfach weiter. Mehrmals ausprobiert mehrmals nicht funktioiert.
Gleiches Prob wenn ich restart drücke.
Tastur is aber angeschlossen, da ich mit strg alt entf neustarten kann.
Bios is das neuste P09
niemand nen hilfreichen tipp zu meinem soundproblem? :( google und forensuche war bisher leider erfolglos...
Ähnliche Themen
