[Sammelthread] Foxconn Mars (Intel P35)
MARS
Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Supports Intel® next generation 45nm Multi-Core processors
1333/1066/800 MHz (FSB)
Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
2 x PCIe x16, 2 x PCIe x1, 3 x PCI
ATA x 1, 1394a x2, SATA II x 6, eSATA x 1
7.1 channel Audio, Realtek® ALC888
GbE LAN, Realtek® RTL8111B
12 USB 2.0 ports
http://geizhals.at/deutschland/a286616.html
SPECIFICATION
Processor: Intel® Core™2 Quad, Core™2 Extreme, Core™2 Duo, Pentium® Dual-Core, Pentium® D, Pentium® 4, Celeron® processors, Socket T (LGA775)
Chipset: Intel® P35 + ICH9R
Front Side Bus: 1333 / 1066 / 800 MHz (FSB)
Memory: Dual channel DDR2 1066(oc)/800/667 x 4 DIMMs, Max. 8GB
VGA on Die: Discreted
Expansion Slots: 2 x PCIe x16, 2 x PCIe x1, 3 x PCI
IDE: ATA 133 x 1
Serial ATA(SATA)/RAID: 6 x SATAII + 1 x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology and Intel® Rapid Recover Technology
Audio: 7.1 channel Audio with Realtek® ALC888 (HDA)
LAN: GbE LAN with Realtek® RTL8111B
IEEE1394: 2 x1394a, TI TSB43AB22APDT
Back Panel I/O Ports: 1 set 7.1 channel Audio jacks (6 jacks)
1x PS/2 keyboard port
1x PS/2 mouse port
1x S/PDIF Out Coaxial
1x S/PDIF Out Optical
1x IEEE1394 port
1x eSATA
6x USB 2.0 ports
1x RJ45 LAN port
Internal I/O Connectors: ATX 24-Pin power connector
8-pin ATX 12V power connector
CPU/System/NB/CASE1/CASE2 FAN connectors
1x CD-in connector
1x Front Audio header
1x Floppy connector
1x IRDA
1x Speaker Heatpipe (NB, SB and MOS)
1x Front Panel connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x IDE connector
1x COM header
1x on-board power_LED
1x IEEE1394 connector supports additional one port
3x on-board Switches(Power on, Reset and CLR-CMOS)
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader 7.07, Direct X 9.0c, Norton 2006
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12” x 9.6”)
LINKS:
http://www.quantum-force.net/default.aspx
http://www.quantum-force.net/Products/P000000001/
http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?ID=en-us0000338
TESTS UND ANDERE BERCICHTE
http://www.hardware-mag.de/hardware.php?id=484
http://www.xtremesystems.org/forums/showthread.php?t=162306&highlight=mars
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=153
http://forums.vr-zone.com/showthread.php?t=195427
http://www.coolaler.com/forum/showthread.php?t=167420
MOTHERBOARD MANUAL
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001438
BIOS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000003
DRIVERS
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=MARS&TypeID=en-us0000004
Registering on the Quantum Force website!
As a member you can enjoy some of the following benefits...
- Access to Beta BIOS and other downloads for Quantum Force products
- Post your technical queries and comments on our forum
- Submit your own system to our "Power Wall" and see how your OC skills compete against others!
- Easy entry to exclusive competitions
- Latest product and promotion news via our newsletter
- Exclusive video content, tutorials and interviews
To learn more about Quantum Force, our aims and beliefs, read the QF Manifesto:-
http://www.quantum-force.net/manifesto.aspx
EIST bezieht sich nur auf die CPU Spannung. Um wieviel das jetzt genau abgesenkt wird habe ich ehrlich gesagt noch nicht genau betrachtet, mir war nur wichtig das es auch im übertakteten Zustand funktioniert... :haha:
Performance-Einbrüche können nur bei Benchmarks auftreten wenn während der Ladevorgänge (3DMark z.B.) die Taktraten wieder abgesenkt werden und ggf. ein paar Frames wegfallen. Das muss aber nicht sein bzw. ist irrelevant.
bin auch am überlegen mir das Mars zu holen, aber passt jetzt der Mugen drauf oder nicht?
Bin aus der Aussage nicht wirklich schlau geworden:heul:
Also der Scythe Mugen passt, wenn man das eine mit Foxconn beschriftete Blättchen von der Heatpipe entfernt. Man kann nur die untere Lüfterklammer nicht einrasten.
Der Mine sollte also passen.
Die Aussage war von mir :d. Ein paar Post darunter wurde das mit dem Blättchen nochmal genauer erkärt.
Der Mugen passt. Nur kann man die Lüfterklemme auf der einen Seite unten nicht einrasten, so wie bei den Gigabyte P35-Boards mit den großen Heatpipes, siehe auch hier.
achso , dann steht dem Mars ja nix mehr im weg:bigok:
Edit: stimmt das eigentlich, dass man mit dem X38 besser Quads ocen kann als mit dem P35:stupid:
Indirekt behaupte ich einfach mal jain kommt drauf an wie viel phasen die ham und meistens ham die mehr Phasen. Allerdings is auch hier die Devise mehr is gleich besser, is gibt durchaus P35 Baords, die mithalten können.
zB das Formula AUSUS hat 12 wenn ich mich nicht täusche, dies hat zurfole/soll zur folge haben, dass die Spannungsschwankungen geringer ausfallen--> Stabiler saft für den Prozi.
Hoff ich konnte helfen.
Wenn de das Mars hast; teste testen und dann posten:bigok:
Leon
Shamino übertaktete mit dem MARS einen Yorkfield auf 6GHz. Ich glaube schon, dass die 6 Phasen reichen. ;)
Die 6Ghz sind nie gefallen da zu der Zeit EIST noch aktiviert war (lies sich nicht deaktivieren),
hat shamino selbst schon irgendwo geschrieben....
Nichts desto trotz hast recht, 6 Phasen reichen vollkommen!
noch eine Frage hab ich wird das Board von Speedfan unterstützt?
im schnitt takten die p35 boards eigetlich eher besser als die x38er, zumindest was den fsb betrifft.
gerüchten zufolge könnte das problem bei den x38ern aber in erster linie am ddr3 controller liegen.
im prinzip dürfte es also zwischen den chipsätzen (x38 ddr2 u. p35) keinen großen unterschied geben.
ich möcht mal noch gern in die runde fragen betreffend komischen PCI / PCI-E problemen die ich die letzte zeit hab:
meine Creative Xi-Fi Extreme Audio PCI-E 1x lief nie sauber auf dem brett ... immer komisches knacksen in der wiedergabe (hab ich mit allen treibern gehabt) - nun hab ich ne normale PCI Soundblaster drinne, die knackst auch nur auf dem ersten PCI neben dem PCI-E 16x nicht.. auf allen anderen PCI Slots benimmt sich die auch komisch! nun lauf ich auf der Realtek Onboard .. naja, ist halt schon ein unterschied
sehr oft fliegt mir auch die RDP Session auf die büx raus (mstsc) Microsoft Remote Desktop zugriff. Meldung ist dann ein Encryptionproblem - nun der Realtex GigaBit port ist ja auch an dem PCI bus gelinkt.. versuche die tage noch mit einer professionellen intel NIC. Die netzwerkverbindung sonst is i.O hab ich gecheckt. bin selber netzwerktechniker...
ich hab die Chipsettreiber für P35 noch im verdacht - mein Kollege hatte die Xi-Fi auf seinem Gigabyte P35-DS4 auch mal drinne da knackst sie auch! aber auf meinem alten EVGA 650i Ultra (Nvidia) läuft die richtig toll - auch nach den tests mit den beiden P35 boards... HW problem schliess ich daher aus bei der karte...
habt ihr auch irgendwelche komischen phänomene mit soundkarten oder dergleichen? welche chipset driver habt ihr genommen, die von der CD oder die neuesten von der Intel Seite? - > deinstallieren hab ich mal versucht aber das wird schwierig, in add/remove software ist nix von den treibern... ich hätt die gerne mal gewechselt zum eingrenzen...
@tronicson: Ich habe eine Creative X-Fi Elite Pro und keinerlei Probleme. Kein Knacksen oder sonstige Störgeräusche. Chipsatztreiber habe ich die neuesten genommen.
ja danke für den tipp - werd mal das image ziehn oder sonst mal mit meiner kubuntu cd starten.. hab da noch so was rumliegen was direkt und allein von der CD ein OS hochschiesst...
@ Wilhelm_II: d.h. die 8.4.0.xxxx gelle...? Ok die Elite Pro ist ja eine normal PCI - auf dem ersten PCI läuft bei mir die Soundblaser auch OK - nur halt auf dem PCI-E 1x lief die XiFi unbefriedigend
Ja, genau sowas ist hinter dem Link auch versteckt! ;)
Ob Ubuntu oder Kubuntu ist eigentlich egal, der Kernel ist der gleiche!
Würde mich mal Interessieren, ob das Knacken dann weg ist, und ob es irgendwelche Probleme mit dem Bord gibt.
Chris
Nächste Woche kommt bei Foxconn ne neue Leiferung rein!:banana::banana::banana::banana::banana::banana::banana::banana:
Bei Foxconn...? :confused:
Foxconn Deutschland mein ich!*schähm*^^
Wollt' schon sagen, kam mir etwas komisch vor :haha:
hab meins gestern auch bekommen,leider waren die pins für Frontpanel und noch andre gebogen :( Hab sie natürlich wieder grad gebogen kann aber erst am we testen obs geht und wies ist :d
Juhu test test test test.ich werd dich dann auch mit fragen löchern!^^
Schön wäre wenn es geht auch ein stromverbrauchstest,also ganzes sys, und wie viel eist und C1e bringt, sofern du dafür die mittel hast :d:d:d:d:d
so es laüft :d aber oc und so mach ich erst später muss erst mal den Rest auf die Reihe griegen . Kann man bei euch auch nicht den Cpu Lüfter über das Aegis Panel steuern ? Welche Lüfteranschlüsse sind den steurbar?Man hat ja insgesamt 5
Edit: Braucht man um den Cpu Lüfter zu steuern einen 4 Pin Lüfter?
Normalerweise müsste man die Lüfter auch über das Aegis Panel steuern können. Man muss auf "Mode: By Temperatur" klicken, dann kann man Temperatur und Prozentwerte ändern.
Man kann 3 der 5 Lüfteranschlüsse steuern, den CPUFan, den SYSFan und den NBFan.
Hab allerdings noch nichts getestet, da ich eine extra Lüftersteurung habe.
jo die andren gehen nur der cpu Lüfter will nicht :( braucht man anscheinend nen 4 Pin Lüfter.
Sobald ich meine Lüfter leise habe bring ich meinen q6600 an seine Grenzen :d
Hat jemand einen E8500 am laufen und kann den 9,5er Multi testen?
Oder weiß jemand so, ob halbe Multis gehen?
Könnteste dann mal messen wieviel Strom der zieht?
also
IDLE
LAST
Mit/ohne OC
Und was mich vorallem interresiert C1E enable/disabled
undervolting!^^
Würd mich brennend interresiern!^^
@pafi1:
Upps, stimmt! Dennoch Danke!
nee sry hab kein Mesgerät da
kann man zum Ocen das Aegis Panel nutzen oder soll mans doch besser übers Bios machn?
Ähnliche Themen
