[Sammelthread] Der "Kopfhörerlaberthread" Nummer 1
@Louisiana
Du hattest ja schon die ganze Zeit mit ihm geliebäugelt :-)
Weist du schon welche Version es bei dir wird ?
Den Spring hast du ja schon in KTE, heißt die einzige vernünftige Version um den Monk zu befriedigen wäre ebenfalls Bliss KTE :d
Aber nebenbei für mich ist es immer noch mein absoluter wunschlos glücklich Stack !
It's great to hear from you and thank you so much for your long-term support. The photo of your Conductor and headphones looks amazing!
Thank you too for approving the look of the Prime. We took a risk here, combining our usual functional futuristic design with classical audio design elements.
The Prime has no volume control at all. The control only turns it on and off and selects its inputs. It is a universal control that can be used on multiple Burson products in a stack configuration.
The idea behind the Prime is actually very simple. The Conductor Voyager's volume control is already very good, but when it comes to audio circuit design, the shorter and simpler the signal path, the better.
We've also gone quite a bit further with the power supply. The Voyager uses 5 MCPS, while the Prime has 10 MCPS, together with a new two-level internal layout. This gives the different stages cleaner and more independent power.
The Prime is also a true dual-mono, mirror-symmetrical design, so there's even less interaction between the left and right channels. In listening terms, this should come through as better separation, imaging, soundstage and transparency.
We also pushed the MOSFET amplification stage deeper into Class-A. Together with the stronger power supply, this gives the Prime better control, dynamics, fine detail and texture. : )
Cheers,
Alex
Von Burson zum Thema Prime. Eigentlich hatte ich gefragt, ob sie auch einen Conductor Prime planen :d
Das fässt es wohl sehr gut zusammen. Hätte ich Platz und den Willen mir nen DAC anzuschaffen würde ich gaaaanz vlt ernsthaft drüber nachdenken mir den Prime zu holen, aber weder das eine noch das andere ist gegeben. Gut ich könnte auch einfach den Prime auf den Conductor Voyager packen und den nur als DAC nutzen, aber irgendwo ist auch mal Ende im Gelände :d
Moin,
lange ist es her, seit ich hier schrieb. Meinen Endgamekopfhörer habe ich zum Schluss doch nie gekauft, blieb beim Lautsprecher und ließ das Thema lange liegen. Jetzt ist es wieder soweit und ich habe mich nochmal kurz auf dem Markt umgesehen und hoffe mir noch einige ZMF und DCA's anhören zu können, um eine finale Entscheidung treffen zu können.
Da der im Raum Hannover nirgendwo zur Probe gehört werden kann, hatte ich einen Heddphone D1 bestellt, der vielerorts gelobt wird und auch wenn der hervorragend klingt, fehlte das gewisse "etwas", was z.B. Hifiman/Sennheiser HD800S und Stax liefern, der D1 für mich und meine Partnerin jedoch leider nicht, schade. Schaut gut aus, ist leicht und auf unseren Köpfen sehr bequem.
Gibt es im Raum Hannover oder Umgebung mit max. 2H Fahrtzeit Geschäfte, wo man sich unter Umständen DCA oder ZMF anhören kann, welche nicht in der offiziellen Händlerliste aufgeführt sind?
PS: Noch ganz wichtig. Kennt jemand eine Möglichkeit (ohne endlos langem Kabel, wireless) einen kabelgebundenen Kopfhörer mit 10 Band EQ an die PS5/PC anzubinden mit möglichst wenig Verzögerung? Ich besitze einen Qudelix 5K als Empfänger. Andernfalls sehe ich mich gezwungen den Audeze Maxwell 2 Xbox Variante (soll mit PS5 kompatibel sein) als Zweithörer für Gaming zu besorgen?
@Terra123
In Hannover gibt es Hifi Klubben, vielleicht lohnt sich ja ein Abstecher dorthin.
Du hattest glaube ich erst was erwähnt von der Abstimmung Richtung Harman zu suchen, DCA Stealth hatte ich mal da, der geht in die Richtung.
Ansonsten ZMF wird denke ich sehr schwierig überhaupt jemanden zu finden der die im Sortiment hat.
@BigWorm48
bei Klubben und Art&Voice war ich bereits. Es gibt noch einen weiteren größeren Händler, aber auch die führen keine ZMF und kennen sie meines Wissens auch nicht.
evtl. nehme ich die Möglichkeit sie zu leihen in Anspruch, oder fahre doch runter und vetbinde es mit einem kleinen Mini-Urlaub 😅
Stealth hatte ich noch nicht gehört, viele DCA gehen in diese Richtung, nur geschlossene Hörer mag ich nicht. Habe mir trotzdem den Audeze Maxwell 2 bestellt mqngels Alternativen und bin gespannt.
Sonst gab es den HE1000 Unveiled sehr häufig als Rückläufer.
Nun hab ich das Geld für so einen zusammen und es kommen keine Rückläufer rein .
Hilft nix ausser weiter zu warten.
@Thunderburne
Auf KA gibts einen für 1,8K VB oder mit geringen optischen Mangel für 1,5K, beim zweiten wäre ich allerdings vorsichtig.
Für was wurden die Vorgänger am Ende rausgehauen? War das nicht immer deutlich unter 1000?
Da würde ich noch ein wenig warten, derzeit sind Over Ears eh auf Grund der Temperaturen schwierig zu tragen.
Der HEK Stealth wurde ein Jahr nach Release von ~2,4k€ auf ~1,4k€ runtergesetzt. Ca ein halbes Jahr bevor die Unveiled als Nachfolger rauskamen. Aktuell gibts den <1k€. Der Unveiled ist im Oktober glaub ich 2 Jahre auf dem Markt. Die Frage ist halt wann Hifiman das nächste Produkt-Upgrade plant...
Ich hab den hier in De bin mir nicht ganz sicher für 1919Euro als Rückläufer gesehen einige male sogar.
Ich werde noch ein wenig warten 1900 rum würde er mir auf jeden Fall Wert sein .
Der ist ja mal bei 3000 gestartet wen ich mich nicht irre zu release.
@Sound 3122: Ich habe meinen TA-66 heute mal aus dem Schrank geholt, bei meinem brummt nichts. Angeschlossen habe ich den HD600 und den Arya.
Ich werde ich aber verkaufen, falls du Interesse hast...
Grüße
Ralf
Ein Arya Unveiled flattert demnächst bei uns rein, im Hochton ist der deutlich runder als HE1000SE/Arya/Organic laut Messungen. Ich hoffe der sagt ihr zu. Habe nur Sorge, dass die Kopfhörer ungewollt beschädigt werden könnten. Ringe und Armbanduhr sollte man vor dem Hantieren wohl lieber ausziehen :unsure:
Morgen trifft noch der Audeze Maxwell 2 ein, bin gespannt.
Bei mir gab es nur ein kleines Upgrade vom Arya Organic zum HE1000 Stealth. Für den HE1000SE hat es leider (noch) nicht gereicht. Bilder folgen dann nach Ankunft. :)
Bei mir gab's auch was kleines gestern. Schöne Fotos nach dem Urlaub.
Die Audeze Maxwell 2 sind eingetroffen. Machen einen hochwertigen Eindruck, allerdings lässt die Verstellung am Kopfband zu wünschen übrig und es wird sehr schnell warm unter den Pads, ich weiß nicht, ob ich diese mehrere Stunden lang tragen möchte bei 22-24C° Raumtemperatur.
Das Profil Immersive ist mir persönlich zu angriffslustig, ich nutze lieber das Profil Audeze (Standard). Sehr guter Klang, ausgewogen, detailliert. Bei extremen basslastigen Songs etwas dröhnend. Da er ausschließlich für Gaming gedacht ist, wird mich das vermutlich kaum stören. evtl. lässt sich dies durch Bassreduktion entschärfen.
Aber ich denke ich verfolge die Variante mit USB Dongle als Bluetooth Sender per AptX Adaptive und einem Fiio BTR oder Qudelix 5K als Empfänger mit normalem Kopfhörer und teste auch diese Variante, falls es kompatibel sein sollte. Der Maxwell 2 liefert zwar weit bessere Audioqualität als ich es aus dem Gamingbereich jemals erwartet hätte, aber Komfort und Hitzeentwicklung machen mir beide zu schaffen. Hat jemand zufällig einen Tipp für einen guten Sender zur Nutzung an der PS5/PC?
Wohl das beste Profil.
Für besseren Tragekomfort:
Kein Plan wie gut diese hier sind wegen Wärme
