[Sammelthread] Offizieller AMD RX 9070 (XT) Overclocking und Modding Thread
Does anyone know what the extra hotspot measurement relates to? Just another sensor position in the die?
Weird they both have max and average..sort of like 2 diff sensors altogether
Sicher?
Ein Hotspot ist ja bereits ein Maximalwert.
Anyone using more clock tool instead of adrenaline?
Yes : )
The tuning profiles are a real help.
Is anyone running the nitro+ in here? Id be interested to know if you run into issues when adjusting tdc limits...depending on multiplier sometimes i will get a hard crash...grey screen/blue lines...have replicated this only by modding the tdc with the script.nothing else,no OC in adrenaline
Just wondering if using same card what values do you use
Ok have been messing around...1.29 x seems to be the max the card will allow? Didnt know that was possible? Max amps is 500
1.29x330A max for card = new max of 425.7
1.30 and above it does not like and will result in hard lock up with shut off needed to reboot...
Whats the situation with everyones hotspot deltas in here? How good can they get? Did a couple of runs at 500w 30c between core and hotspot 1..and 35c between that other hotspot temp.
Core at 34 hotspot 64 and max hotspot 69c
Thats with alphacool core block and LM
I have the Pulse and at around 500-530 watts according to WireView, these are my temperatures for a short run of Cyberpunk with 4K path tracing and no upscaling. I have the Bykski block and liquid metal, all fans are at around 1,200 RPM so it's about the same
Finally Team RED ... (mmhh, but green LED) 😅
Hab jetzt eine Sapphire 9070 Pure mit Samsung VRAM.
Absolut genial und der VRAM ist wesentlich kühler!
Momentan erst mal mit -10% und -50mV
Will mal schauen was ich noch wie einstellen muss.
Vermisse das OSD vom MSI AB :/
ANDso probably not much can be done about it....i really dont want to open up the card again...just yet anyway!
ok some more runs in today....still on the loop...water temps got to 27c
best so far....
went with things a bit differently...no UV yet...just added 100mv to gfx in the script,also added 25mv soc /100mv vram and 15mv vddci and just let her rip haha
with -30uv
enough for a couple more spots.....dont know if lower temps are really gonna help me now?
maybe some more messing with VIDs,also my potato of a CPU probably aint helping things 😆
Have a 9800x3d/x670e sitting on the shelf that i really need to transplant...just gotta sort out a waterblock for it
@Grindcore may I ask for a timespy result? No TS extreme, just the plain old timespy?
All my figures here are based on it, and since Hardwareluxx never retested RDNA 2 and ommits the results in nowadays tests... I'd like to know how far the points have risen.
Was für UV fahrt ihr so und gebt ihr +Clockspeed oder auf 0 lassen? Bei mir ist es selbst bei -20 mV oft abegestürzt (bzw. Wattman reset teils auch einfach nur nach Neustart) aber seit mein Board in RMA war hatte ich nicht einen einzigen Rücksetzer. PT -15 % und 2800 MHz sind momentan eingestellt. Ich habe eine Nitro+ die leider trotz allem noch sehr heiß ist, weit über 80° Speicher. Der Core ist angeblich nur 60° warm beim Zocken.
momentan nur -10% PL und -50mV
Speicher bei max. 68°C
Sapphire 9070 Pure
Es gibt keine Möglichkeit den Takt "absolut" zu begrenzen, oder?
Nur dynamisch, right?
Gestern beim EzBench direkt mal Treiber gestorben. Hatte ich vor Jahren vielleicht das letzte Mal bei Team grün.
All my figures here are based on it, and since Hardwareluxx never retested RDNA 2 and ommits the results in today's tests... I'd like to know how far the points have risen.
Yes will do when I get a chance! The next couple of days
So maybe need to pull the reigns in abit? 😅😥
Ist this your card on Reddit?
Oh :(,
is this your card?
Likely only the connector is damaged, the card has to be repaired (new connector) also a new connection for power supply is needed.
The wires are likely to not have taken any damage, but the connector needs to be exchanged.
This connector lowered surface area for connection by quite a bit, compared to good working and safe "old" connectors on a pin by pin basis.
Additionally current limits were raised and no leveling mechanism is mandatory. Also those contact surfaces are made out of cheap metal, no mandatory plating.
No gold, no silver, not even tin. BAD oversight in my opinion. And... usually those contacts are crimped on the cable, but by hand? By machine? Does anyone check those connections for resistance?
So... yeah, bad connection / higher resistance than the other pins and bam, some pins get hot.
Oxidation of surfaces meant to transport high currents (or frequencies) will hapen over time. Even in-air moisture influences this.
