shir@fedora:~/amdgpu_top$ ./target/release/amdgpu_top -d
amdgpu_top v0.10.5 (git-cf1ee1c)
#0 DevicePath {
render: "/dev/dri/renderD128",
card: "/dev/dri/card1",
accel: "",
pci: "0000:03:00.0",
sysfs_path: "/sys/bus/pci/devices/0000:03:00.0",
device_id: Some(
0x7550,
revision_id: Some(
0xC0,
device_name: "AMD Radeon RX 9070 XT",
device_type: AMDGPU,
drm version: 3.63.0
Device Name : [AMD Radeon RX 9070 XT]
PCI (domain:bus:dev.func): 0000:03:00.0
DeviceID.RevID : 0x7550.0xC0
gfx_target_version : gfx1201
GPU Type : dGPU
Family : GC 12.0.0
ASIC Name : GFX1201
Chip Class: GFX12
Shader Engine (SE) : 4
Shader Array (SA/SH) per SE: 2
CU per SA : 8
Total Compute Unit : 64
RenderBackendPlus (RB+) : 16 (128 ROPs)
Peak Pixel Fill-Rate : 322 GP/s
GPU Clock: 500-2520 MHz
Peak FP32: 41287 GFLOPS
VRAM Type : GDDR6
VRAM Bit Width: 256-bit
VRAM Vendor : hynix
Memory Clock : 96-1258 MHz
Peak Memory BW: 644 GB/s
ResizableBAR : Enabled
VRAM : usage 1019 MiB, total 16304 MiB (usable 15776 MiB)
CPU-Visible VRAM : usage 1019 MiB, total 16304 MiB (usable 15776 MiB)
GTT : usage 32 MiB, total 15931 MiB (usable 15916 MiB)
Edge Temp. : 39 C (Current), 110 C (Critical), 115 C (Emergency)
Junction Temp. : 42 C (Current), 110 C (Critical), 115 C (Emergency)
Memory Temp. : 60 C (Current), 108 C (Critical), 113 C (Emergency)
Power (Average) : 14 W
Power Cap. : 330 W (0-340 W)
Power Cap. (Default): 330 W
Fan RPM (Max) : 3200 RPM
Fan RPM (Current) : 0 RPM
PCIe Link Speed (DPM, Min-Max): Gen5x16 - Gen5x16
PCIe Link Speed (GPU, Max) : Gen5x16
PCIe Link Speed (System, Max) : Gen5x16
Supported Power Profiles: ["BOOTUP_DEFAULT", "3D_FULL_SCREEN", "POWER_SAVING", "VIDEO", "VR", "COMPUTE", "CUSTOM", "WINDOW_3D"]
L1 Cache (per CU) : 32 KiB
GL1 Cache (per SA/SH): 256 KiB
L2 Cache : 8192 KiB (32 Banks)
L3 Cache : 64 MiB
Hardware IP info:
GFX count: 1, ver: 12.0, queues: 1
COMPUTE count: 1, ver: 12.0, queues: 4
DMA count: 2, ver: 7.0, queues: 2
VCN_DEC count: 1, ver: 5.0, queues: 0
VCN_ENC count: 1, ver: 5.0, queues: 1
VCN_JPEG count: 1, ver: 5.0, queues: 1
IP Discovery table:
die_id: 0
MP1 num: 1, ver: 14.0.3
THM num: 1, ver: 14.0.2
SMUIO num: 1, ver: 14.0.2
FUSE num: 1, ver: 14.0.2
CLKA num: 9, ver: 14.0.2
PWR num: 1, ver: 9.0.0
GC num: 1, ver: 12.0.1
UVD num: 1, ver: 5.0.0
MMHUB num: 1, ver: 4.1.0
ATHUB num: 1, ver: 4.1.0
DBGU_NBIO num: 1, ver: 3.0.0
DFX num: 1, ver: 5.0.0
OSSSYS num: 1, ver: 7.0.0
HDP num: 1, ver: 7.0.0
SDMA0 num: 1, ver: 7.0.1
SDMA1 num: 1, ver: 7.0.1
DF num: 1, ver: 4.15.1
DFX_DAP num: 1, ver: 2.0.0
PCIE num: 1, ver: 6.1.0
LSDMA num: 1, ver: 7.0.1
NBIF num: 1, ver: 6.3.1
SYSTEMHUB num: 1, ver: 2.3.0
UMC num: 8, ver: 8.14.0
MP0 num: 1, ver: 14.0.3
DMU num: 1, ver: 4.1.0
DIO num: 1, ver: 127.127.63
Unknown(273) num: 1, ver: 1.0.3
DAZ num: 1, ver: 127.127.63
Unknown(282) num: 1, ver: 14.0.2
Unknown(286) num: 1, ver: 5.0.0
Unknown(293) num: 1, ver: 1.0.0
Firmware info:
GFX_ME feature: 29, ver: 0xADC
GFX_PFP feature: 29, ver: 0xB18
GFX_RLC feature: 1000, ver: 0xBE7DA0
GFX_MEC feature: 29, ver: 0xBF4
SMC feature: 0, ver: 0x684600
SDMA feature: 1081031494, ver: 0x6F3B46
SOS feature: 3803924, ver: 0x3A0B14
ASD feature: 553648366, ver: 0x210000EE
VCN feature: 0, ver: 0x9107031
DMCUB feature: 0, ver: 0x10E00
Video caps (WIDTHxHEIGHT):
MPEG2 : N/A (Decode), N/A (Encode)
MPEG4 : N/A (Decode), N/A (Encode)
VC1 : N/A (Decode), N/A (Encode)
MPEG4_AVC : 4096x4096 (Decode), 4096x4096 (Encode)
HEVC : 8192x4352 (Decode), 8192x4352 (Encode)
JPEG : 16384x16384 (Decode), N/A (Encode)
VP9 : 8192x4352 (Decode), N/A (Encode)
AV1 : 8192x4352 (Decode), 8192x4352 (Encode)
VBIOS info:
name : [GV-R9070XTGAMING OC-16GD/F1/1114]
pn : [113-R907XTGOL-F1]
ver_str: [023.008.000.068.000001]
date : [2024/12/03 20:16]
pp_feature_mask: [
PP_SCLK_DPM_MASK,
PP_MCLK_DPM_MASK,
PP_PCIE_DPM_MASK,
PP_SCLK_DEEP_SLEEP_MASK,
PP_POWER_CONTAINMENT_MASK,
PP_UVD_HANDSHAKE_MASK,
PP_SMC_VOLTAGE_CONTROL_MASK,
PP_VBI_TIME_SUPPORT_MASK,
PP_ULV_MASK,
PP_ENABLE_GFX_CG_THRU_SMU,
PP_CLOCK_STRETCH_MASK,
PP_OD_FUZZY_FAN_CONTROL_MASK,
PP_SOCCLK_DPM_MASK,
PP_DCEFCLK_DPM_MASK,
PP_OVERDRIVE_MASK,
PP_GFXOFF_MASK,
PP_ACG_MASK,
PP_STUTTER_MODE,
PP_AVFS_MASK,
GPU Metrics Version: v1.3
