[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Nicht, dass ich mir große Hoffnungen mache:
30% kann aber muss nicht das mechanische Minimum sein.
Manche Lüfter brauchen z.b. 30% um zu starten; können dann aber weiter runter geregelt werden bevor Sie komplett aufhören.
Soweit mir bekannt hat das Programm FanControl einen Assistenten der Start und Stop in Prozent anaylsieren kann.
Und in den Optionen ein Modul zum überschreiben der Kontrolle der Lüfter vom GPU bios zu FanControl.
Viel Glück beim Testen
Das funktioniert leider nicht bezüglich weniger als 30%. Dabei geht es um den Erhalt des ZeroFanMode bei angepasster Lüfterkurve.
Starten würde der Lüfter laut FanControl sogar schon bei 9%.
Die Lüfter der KFA2 laufen halt bis 34grad GPU Temperatur nach und starten wieder ab 50Grad.
Das abkühlen nachdem Gameing auf 34Grad dauert schon ne Weile insbesondere im Sommer.
Asus TUF und die MSI Suprim sind da deutlich besser und leiser bei minimaler Drehzahl. (Dafür fiepen die Dinger immer)
Meine KF2 läuft beim Gaming maximal mit 35% Lüfter…..der Unterschied zwischen minimal Drehzahl und Gaming ist sehr gering.
jemand die neusten Treiber mal getestet? Gibt es bei euch Probleme mit 576.40 oder 576.52 ?
Bei mir läuft der 572.70 ganz gut!
folgendes „Problem“:
Ich möchte meine Karte - Gigabyte Gaming OC - von Wasser auf den originalen Luftkühler zurück bauen.
Werde mir einen neuen Rechner bauen, und hab einfach nicht mehr die Lust auf das mehr an Aufwand für eine Wasserkühlung.
Weiß hier jemand, welche Wärmeleitpads ich brauche, für den Umbau?
Gibt es generell was zu beachten?
Ich hab schon seit der GTX260 Karten unter Wasser gesetzt, aber eben noch nie eine wieder zurück gebaut. 🤣
Hast du nicht eventuell noch die originalen Pads zum nachmessen? Ich lasse die immer einfach am Kühler kleben, wenn das Teil in die Verpackung wandert.
Könntest das Problem ansonsten umschiffen, in dem du statt Pads Thermal Putty benutzt.
Hab mal nachgesehen, auf dem org. Kühler ist fast noch alles drauf:
Eine Schraube habe ich verloren, aber da sollte sich was finden lassen:
Ich bin fast am überlegen, ob ich die mit WaKü Umbau verkaufe, und mir eine neue kauf - irgendwie habe ich so gar keine Muse mehr, zu basteln.
Was letsde Prais? :fresse:
Warum baust du nicht einfach zurück?
Falls du keine Lust darauf hast oder dir das nicht zumutest, dann lass es doch jemanden für dich machen.
Neue weiche Pads ala TP-3 von Arctic oder Putty plus ein PTM/PCM-Pad für die GPU und du hast ausgesorgt. Alleweil besser als alles direkt ab Fabrik.
Oder suchst du nach Argumenten um eine 5000er zu kaufen?
:d
Ich habe gestern zu dem Thema gegoogelt, und da hieß es zusammengefasst, wenn man nicht exakt die Stärke der WLPs verwendet, welche der Hersteller gewählt hat, käme es zu Hitzeproblemen, von daher:
Bin ich dir für den Tipp sehr dankbar :)
:d
Nein, ich habe noch einen i7 8700k verbaut, und wollte schon längstens upgraden, aber eben das Gedöns mit entleeren usw. hält mich davon ab.
Wäre der unter Luft, oder AiO, dann wäre das schon längst passiert.
Ich habe WaKü PCs seit 2009 gebaut, angefangen mit dem Klassiker, dem TJ07, das ich sogar noch besitze, zu den Zeiten habe ich mal schnell zwischendurch alles umgebaut, aber heutzutage fehlt einfach die Lust.
Andererseits:
Da ich sowieso ein neue Gehäuse möchte, und von Intel auf AMD (Sockel AM5) wechsel, wäre der einmalige Umbau auch nicht wirklich dramatisch.
Positiv:
Hab gerade die Schraube beim Staubsaugen gefunden :bigok:
Edit:
Die TP-3 Pads gibt es in 3 Größen, da stellt sich mir natürlich wieder die Frage, welche ich brauche -> 0,5 schließe ich mal aus, bleibt 1mm oder 1.5mm...
Ich verstehe den Sinn nicht, die Karte auf Luft zurück bauen zu wollen, wenn man keine Lust zum Basteln hat. Ich käme nie auf die Idee mein 4090FE wieder auf Luft zu bauen, solange ich die selber in meinem wassergekühltem PC nutze. Läuft stabil, extrem leise und kühl. Das ist doch der Sinn bei einer (meiner) Wasserkühlung.
Luftkühlung kommt für mich nicht in Frage.
@A6 Eine RTX4090 läuft doch unter Luft kühl und leise. Unter anderem bin ich deshalb bei der GPU von Wasser auf Luft zurück. :bigok:
@Louisiana
Falls du 2mm oder 2,5mm Pads brauchst, kann man dafür problemlos auch 1/1,5mm mit 1mm stapeln. Es gibt auch Leute die bevorzugen Putty, welches aber nicht zwingend besser sein muss. Vor allem ist es teurer und ich persönlich mag das gekleckere mit dem Zeugs nicht. Detailliertere Infos zu WLPads/Putty/PTM gibts bei igors.lab
Zudem kann man die alten Pads der Spulen wiederverwenden. Dazu mit zwei Kreditkarten das Pad breitseits vorsichtig etwas quetschen, dann kommt es wieder etwas in die Höhe und kann für sekundäre Kühleinsätze wie die Spulen oder die Backplate genutzt werden. RAM und SpWas würde ich aber unbedingt neu machen, wenn es für lange so bleiben soll.
Übrigens die Pads auf der Backplate könnten sogar etwas dicker sein. Vielleicht passen da die alten, welche ersetzt werden besser. Auch an anderen Stellen sind die Originalpads zu dünn.
Habe meine 4090 vor knapp 1 Woche nun auch erfolgreich verkauft, Käufer war selbstredend ein Chinese, Lieferadresse war in Deutschland eine Import/Export Firma, wie sollte es auch anders sein? 😏
Aber es lief alles extrem glatt und ohne jegliche Probleme: Geld kam von Ebay auf das Bankkonto, Versand angestoßen, fertig.
Knapp 1.900€
Ling-Ling, Mai-Ling und Pan Tao zahlen aber inzwischen nicht mehr so gut wie noch vor zwei, drei Monaten. Zudem hat mein Käufer inzwischen seinen Text bei Kleinanzeigen abgeändert :LOL:
Krass diese Situation. Dann kann man sich ungefähr vorstellen, wie groß der Druck für die Chinesen sein wird, ihre eigene und konkurrenzfähige AI-Hardware zu entwickeln und herzustellen. Entweder sie schaffen sich bald einen Ausgleich, oder sie holen es sich. Ist alles nur eine Preisfrage.
Ich überlege gerade meine 4090 über Ebay zu verkaufen, aber bin mir irgendwie unsicher. Ist halt echt viel Geld und Betrug wäre schon sehr bitter. Was meint ihr?
@ssj3rd Wie lief das bei dir?
Schließe mich mal an, hat jemand Erfahrungen wie gut die 4090 mit Wakü weggehen? Hab kein Bock das zurück zu bauen.
Habe meine jetzt auch bei ebay reingesetzt. In den letzten Wochen gingen die 4090 verschiedener Hersteller immer so um die 1800-2100€ weg.
Wenn die von Chinesen gekauft wird, machen die das ja eh selber? :d
Ähnliche Themen
