Vigor167 und ASUS RT-AX5400 an 1&1 250k Leitung PPPoE Abbruch
Sm0kY88
nähe Bamberg
Servus,
Hat von euch evtl wer ne idee.. und zwar hab ich einen Vigor167 an der TEA Dose und den ASUS Router dahinter der die PPPoE einwahl macht.
Vlan7 im Vigor aktiv und im Asus nichts ... hab ich aber schon getauscht zum test leider ohne besserung
DSL Sync im Vigor steht Tage lang ( Line Uptime 21d)
Leider hab ich trotzdem 3-5 mal am Tag Abbrüche hier mal ein LOG vom ASUS wenn das passiert ..Bin langsam ratlos.. 1&1 meinte ich soll den Vigor die PPPoE einwahl machen lassen... da sind wir dann wieder bei Doppel NAT
Code:
Apr 29 19:56:40 kernel: br0: received packet on eth3 with own address as source address (addr:08:bf:b8:4a:0b:b0, vlan:0)
Apr 29 19:56:51 pppd[9209]: No response to 10 echo-requests
Apr 29 19:56:51 pppd[9209]: Serial link appears to be disconnected.
Apr 29 19:56:51 pppd[9209]: Connect time 399.8 minutes.
Apr 29 19:56:51 pppd[9209]: Sent 312939751 bytes, received 919297082 bytes.
Apr 29 19:56:51 lldpd[2335]: removal request for address of 62.XXXX.134%31, but no knowledge of it
Apr 29 19:56:51 dnsmasq[11836]: read /etc/hosts - 22 names
Apr 29 19:56:51 dnsmasq[11836]: using nameserver 10.10.10.249#53
Apr 29 19:56:52 WAN(0)_Connection: Fail to connect with some issues.
Apr 29 19:56:57 pppd[9209]: Connection terminated.
Apr 29 19:56:57 pppd[9209]: Sent PADT
Apr 29 19:56:57 pppd[9209]: Modem hangup
Apr 29 19:57:07 kernel: br0: received packet on eth3 with own address as source address (addr:08:bf:b8:4a:0b:b0, vlan:0)
Apr 29 19:57:07 pppd[9209]: PPP session is 29 (0x1d)
Apr 29 19:57:07 pppd[9209]: Connected to 10:0e:7e:c7:0a:6f via interface eth4
Apr 29 19:57:07 pppd[9209]: Using interface ppp0
Apr 29 19:57:07 pppd[9209]: Connect: ppp0 <--> eth4
Apr 29 19:57:07 pppd[9209]: Remote message: [UI-SBR:280064,42445;UI-LINEID:1UND1.DEU.DTAG.ECWXU;]
Apr 29 19:57:07 pppd[9209]: PAP authentication succeeded
Apr 29 19:57:07 pppd[9209]: peer from calling number 10:0E:7E:C7:0A:6F authorized
Apr 29 19:57:08 lldpd[2335]: removal request for address of 87.XXXXX78%34, but no knowledge of it
Apr 29 19:57:08 pppd[9209]: local  IP address 87.xxxxxxx.178
Apr 29 19:57:08 pppd[9209]: remote IP address 62.xxxxxxx.134
Apr 29 19:57:08 lldpd[2335]: removal request for address of 62.XXXXXX134%34, but no knowledge of it
Apr 29 19:57:08 lldpd[2335]: removal request for address of 87.XXXXX.178%34, but no knowledge of it
Apr 29 19:57:08 custom_script: Running /jffs/scripts/firewall-start (args: ppp0)
Apr 29 19:57:08 dnsmasq[11836]: read /etc/hosts - 22 names
Apr 29 19:57:08 dnsmasq[11836]: using nameserver 10.10.10.249#53
Apr 29 19:57:08 wan: finish adding multi routes
Apr 29 19:57:09 vpndirector: Routing xxxxxxx from 10.10.10.202 to any through wgc1
Apr 29 19:57:09 dnsmasq[11836]: read /etc/hosts - 22 names
Apr 29 19:57:09 dnsmasq[11836]: using nameserver 10.10.10.249#53
Apr 29 19:57:09 lldpd[2335]: removal request for address of 172XXXXXX25%32, but no knowledge of it
Apr 29 19:57:09 WireGuard: Stopping client 1.
Apr 29 19:57:10 vpndirector: Routing xxxxx from 10.10.10.202 to any through wgc1
Apr 29 19:57:10 wireguard: Forcing 10.10.10.202 to use DNS server 46XXXXX134 for WGC1
Apr 29 19:57:10 wireguard: Forcing 10.10.10.202 to use DNS server 192XXXX.158 for WGC1
Apr 29 19:57:10 wireguard: Forcing 10.10.10.202 to use DNS server 2a07:XXXXXXX:cd45::1 for WGC1
Apr 29 19:57:10 wireguard: Forcing 10.10.10.202 to use DNS server 2001:XXXXXXXXXXcd45::1 for WGC1
Apr 29 19:57:10 WireGuard: Starting client 1.
Apr 29 19:57:10 dnsmasq[11836]: read /etc/hosts - 22 names
Apr 29 19:57:10 dnsmasq[11836]: using nameserver 10.10.10.249#53
Apr 29 19:57:10 lldpd[2335]: removal request for address of 10.6.0.1%33, but no knowledge of it
Apr 29 19:57:10 WireGuard: Stopping server.
Apr 29 19:57:10 rc_service: ip-up 23314:notify_rc stop_samba
Apr 29 19:57:10 custom_script: Running /jffs/scripts/service-event (args: stop samba)
Apr 29 19:57:10 wsdd2[11870]: terminating.
Apr 29 19:57:10 Samba_Server: smb daemon is stopped
Apr 29 19:57:11 WAN(0)_Connection: WAN was restored
Mit der 7590AX hatte ich solche probleme nicht
Hab jetzt zum testen mal den Vigor die PPPoE einwahl machen lassen hier scheint wirklich kein Abbruch zu sein
Evtl hat jemand schon mal sowas gehabt und ne idee was mir helfen könnte.
Der pppd empfängt halt öfter keine Antwort auf seine Echo-Requests und terminiert dann die PPPoE Verbindung. Gibts dazu irgendwelche Einstellungen ? Auf das Linux was auf dem Asus läuft wirst du ja aktuell nicht direkt zugreifen können, oder ? Dann könntest diese Echo-Requests mal deaktivieren, normal macht das der LAC Richtung deines Routers schon, also ist es unnötig wenn dein Router es auch macht.
Könntest bei der Gelegenheit auch schauen, ob sich LLDP auf dem WAN-Interface deaktivieren lässt, das ist unnötig.
Hab auf dem Asus hab ich AsusWRT marlin laufen somit komm ich da per ssh drauf hab davon aber nicht gerade viel plan
LLDP hab ich nichts gesehen .. jetzt gerade im Router Mode zeigt er andere sachen an als im "Modem Mode"
Hier mal ein Screen von den Asus WAN Settings
Ja, da haben wir ja schon den Verursacher: deaktiviere mal die "Internet Detection".
Bin mir gerade nicht sicher ob ich das die Tage schon getestet hatte aber glaube da wars auch der fall werde das aber die Tage noch mal inkl neuem Kabel von Vigor zum Asus testen
im Vigor ist das aber scheinbar auch aktiv oder ist das was anderes?
Heute komm ich nicht mehr zum testen
Ne, ARP Detect ist was Anderes als der PPP Keepalive. Anderes Protokoll auf anderer Protokollebene.
So hab heute mittag wieder auf PPPoE inkl neuem Lan Kabel umgestellt am Asus und hatte um 19:53 uhr wieder eine Trennung "Internet Detection" Deaktiviert
DSL Sync steht 9 Stunden ohne abbruch
Das war somit nicht der Fehler :/ Leider
Was sagt das Log diesmal ? Können auch 2 unabhängige Fehler sein.
Code:
May  4 08:51:01 pppd[2923]: LCP terminated by peer
May  4 08:51:01 pppd[2923]: Connect time 778.0 minutes.
May  4 08:51:01 pppd[2923]: Sent 515213294 bytes, received 2927539422 bytes.
May  4 08:51:01 lldpd[2335]: removal request for address of 62.xxxxxxx.134%65, but no knowledge of it
May  4 08:51:01 pppd[2923]: Modem hangup
May  4 08:51:01 pppd[2923]: Connection terminated.
May  4 08:51:01 pppd[2923]: Failed to disconnect PPPoE socket: 114 Operation already in progress
May  4 08:51:01 pppd[2923]: Sent PADT
May  4 08:51:01 dnsmasq[29025]: read /etc/hosts - 22 names
May  4 08:51:01 dnsmasq[29025]: using nameserver 10.10.10.249#53
May  4 08:51:02 WAN(0)_Connection: Fail to connect with some issues.
Sync steht jetzt 23 stunden
LCP Terminated by peer ist eine Sache des Anbieter BNGs, wende dich damit doch mal an 1&1.
Ist nur die frage ob die da überhaupt was machen weil wenn der Vigor direkt die PPPoE macht scheint es ja perfekt zu laufen -.-
Mit dem PPPoE hat das nix zu tun, das ist der PPP Teil der da wohl Probleme macht. Müsste man jetzt genau am WAN sniffen wie die Aushandlung abläuft und was dann schief läuft.
Ich hab das mal so an 1&1 geschickt bin mit denen wegen dem Fall eh in eMail kontakt .. ich halte dich auf dem Laufenden
Was macht denn der Vigor wähgrend dem Asus das DSL fehlt?
Eventuell gibt eine Protokollierung an dieser Stelle noch zusätzliche Anhaltspunkte. https://draytek.com/download_de/Firmwares-Modem/Vigor167/DSL-Debug-Log erstellen.pdf
Vielleicht erkenst du da ja deinen Anschluss wieder. https://telekomhilft.telekom.de/t5/...nects-nach-Upgrade-auf-250Mbit-s/td-p/6015721
Danke erst mal für die Link´s
Der Vigor hat laut WebGui nichts gemacht beim Abbruch .. hab jetzt mal am PC nen Log am laufen da gehts schon ohne abbruch ganz schön ab :d
Gibts evtl ne neuere/andere fw fuer den vigor? Ich weiss, er macht nur pppoe passthrough. Ein Versuch waere es evtl dennoch wert. Geht relativ schnell. Mach das nur nicht zu oft wegen ASSIA
Neuste ist drauf aber ich kann 2 verschieden Modem Versionen wählen da hab ich jetzt mal die Ältere drin
Warum sind in deinen Bilden von den WAN-Einstellungen eigentlich in beiden Geräten Zugangsdaten eingegeben? Wählen sich die Geräte beide beim Provider ein, oder ist im Vigor der Pass-through Schalter eigentlich eingeschaltet?
Das wäre jetzt als Erstes zu klären, das erklärt nämlich den LCP Disconnect von der Gegenstelle.
Das Bild vom Donnerstag war wo der Vigor den PPPoE zugang gemacht hat .. hier lief es dann ohne abbrüche
Jetzt wo der Vigor auf Modem Betrieb steht kann ich gar keine Zugangsdaten eingeben siehe Bilder Gestern
Kurzes Update:
Ich hab ja im Asus"Internet Detection" Deaktiviert Heut nacht um 3 uhr ist dann scheinbar der Sync abgebrochen und mein Asus hat das nicht gemerkt... Fazit inet komplett weg musste dann wieder auf PPP Echo umstellen
Dann stell die Schwellwerte großzügiger ein. Reconnect nur bei 20 oder 30 nicht empfangenen Echos etc.
Habs auf 25 Stehen gehabt .... ändert nix an den Abbrüchen nur die länge bis der Reconnect kommt dauert länger... ich versteh es langsam echt nicht wo da der Wurm ist
Kannst den Router nicht testweise mal durch einen anderen ersetzen?
