[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Halte es auch für möglich, weil alle Kontakte etwas Spiel haben. Man müsste es halt mehrfach testen. Abstöpseln tut dem Stecker aber nicht gut.
Und am besten dielektrisches Fett verwenden.
Das selbe Kabel für beide NTs verwendet?
Ja ist das gleiche Modell, Seasonic TX 1600 ATX3.0. Hatte ja mit den bisherigen Kabeln keine Probleme und wollte eben schauen, wo die "Schwachstelle" liegt.
lange nicht mehr verfolgt, da ich ja selbst nun auch eine 4090 habe, aber gerade konnte ich ohne probleme eine 4090 fe (lagernd) über nvidia kaufen, wurde dabei aber nicht auf nbb.de, weitergeleitet, neu?
Proshop, oder?
So war es damals bei mir
Wie lange warst du weg? :fresse:
keine ahnung, 4090 monate :d, mir war so, das es weiterhin schwer war eine zu bekommen, da sie weiterhin ja auch recht hoch, also über 2k gehandelt wurden/werden und ich immer noch davon aus ging, das nbb der partner sei, einfach so gestern mal spaßeshalber gemacht und war erstaunt :d
Klingt korrekt, schwer verfügbar ist sie seit Ewigkeiten schon nicht mehr und NBB ist sogar noch etwas länger raus. Willkommen zurück vom Mond 🤘
Oder lagst du im Koma? 😂
Poste doch mal genau deine Werte, ich schaue dann morgen bei mir. Ich hab auch dieses Netzteil und eine 4090 Frostbite Ultra. Auf der 12VHVPWR hab ich aber definitiv immer über 12 V
ich war schwanger mit meiner 4090 karte :d
ihr ferkel...^^
:ROFLMAO:
Also vom "alten" Netzteil weiß ich noch, dass er bei knapp 500W auf bis zu 11.920V gedropped ist. Idle Spannung lag so bei 12,065V bei dem alten Netzteil. Das "neue" Netzteil (gleiches Modell) hat eine Idle Spannung von ~12,150V und der niedrigste Wert bei 450W lag bisher bei 12,045V, soweit ich mich gestern entsinnen kann.
Gray Zone Warfare nimmt die 4090 ganz schön auseinander
Ohne DLSS keine Chance in 4K mit Epic Settings.
Die 5090 muss her. :fresse:
Woran kann das liegen, dass ich meine 4090 Frostbite Ultra nicht mehr mit dem 120 % Powertarget (sind dann 600W) betreiben kann? Afterburner und auch das Inno3D Tool lassen zwar die Einstellung des PL zu, aber am Ende bleibt die Karte bei max 430 Watt. Bios vor einer Weile ging das problemlos auch bis 600 Watt.
Furmark1/2, jeweils auf die FPS geachtet, damit diese nicht im Framelimit liegen; Administratorechte usw. auch vergeben.
Das 12v2x6 ist das neue? Warum? Die Netzteile haben doch alle den 16 Poligen Anschluss. Ist das 2x8 polige besser? Bessere Stromverteilung oder wie darf ich das verstehen?
Einfach gesagt: mehr Zuverlässigkeit. Im Vergleich zum ursprünglichen 12VHPWR-Stecker hat der neue 12V-2x6-Stecker etwas (0,1 mm) kürzere Abtaststifte, während die Leiteranschlüsse 0,15 mm länger sind.
Ich muss zugeben ich habe das mit diesen Kabeln überhaupt nicht mehr verfolgt. Habe seither das 12VHPWR Kabel von be quiet. Aber das hat ja auf der Netzteilseite 2x12 Pins. Wieder was dazu gelernt.
Wenn ich ein Netzteil hätte was auch schon den 12VHPWR Anschluss besitzt, würde ich ein Kabel kaufen, was den überarbeiteten 12V-6x2 Anschluss auf beiden Seiten hat, sofern verfügbar. Das von mir verlinkte Seasonic Kabel hat das. Zukünftige GPUs werden höchstwahrscheinlich auch auf diesen Anschluss setzten. Ob es sicherer ist ein Kabel zu kaufen, was auf der GPU Seite den alten 12VHPWR hat und auf Netzteil Seite 2x8Pin, wage ich zu bezweifeln, denn ein Kabel was 2x8 Pin auf 12V-2x6 hat, gibt es derzeit gar nicht, zumindest nicht von Seasonic. Damit müsste man mit so einem Kabel, zumindest auf der GPU Seite, mit dem "unsichereren" 12VHPR Stecker leben was für mich nach heutigem Kenntnisstand nicht in Frage kommen würde, wenn es bereits eine verbesserte Version gibt, die auch zukünftig der Standard sein wird. Die meisten "Unfälle" passieren auf GPU Seite, daher würde ich sehen, dass ich hier den neusten Standard verwende, wenn ich jetzt ein Kabel kaufen würde.
Liegt auch daran, dass an der Netzteilseite nichts genormt ist und dort jeder macht was er will.
Das ist auch wieder so ein Thema was ziemlich nervig und auch eigentlich total überflüssig ist. Man sollte da echt mal ne Norm schaffen.
Ich suche halt ein ordentlich Kabel. Aber es gibt scheinbar kein vernünftiges ausser die Standard Kabel die einfach nur scheiße aussehen.
Denke auch das bei der 5090 nochmal ne ganz andere Version der Stromversorgung kommt.
Wenn es so weiter geht, kommt eh bald noch ne neue Version, denn auch der jetztige "neue" Stecker ist nicht perfekt. Ich kaufe solange gar nix von dem Müll, läuft ja auch so. Die nächste Gen wird sich ja zeigen was man braucht, oder was nicht. ^^
Das stimmt, am besten ist aktuell gar nix zu kaufen, wenn das bereits vorhandene erwiesenermaßen läuft ^^. Zumindest wenn man vor hat, in den nächsten 1-3 Jahren nochmal aufzurüsten. Meine Aussage bezog sich auf die Annahme, dass man unbedingt jetzt ein neues Kabel braucht, weil man mit der mitgelieferten Krake nicht arbeiten kann/will. Es ist aber schon davon auszugehen, dass der aktuelle Standard erstmal so bleiben wird, zumindest bei den kommenden Nvidia Karten. Was AMD macht muss man abwarten. Wahrscheinlich weiterhin 2x8Pin auf GPU Seite,wenn wirklich nur Midrange Karten kommen, die maximal mit der 4090 konkurrieren können.
Wo ist denn das Problem? Man kauft jetzt einfach für 20 und n paar zerquetschte Euro das Kabel dass man braucht und wenn etwas neues rauskommt eben das für einen ähnlich zu vernachlässigenden Preis. Das 90° Kabel von Seasonic hat mich 24 gekostet, das normale glaube ich 12€ oder so. Jeweils in weiß. Hab beide hier und beide funktionieren problemlos. Genau wie das Fasgear was ich vorher hatte. Wenn man was hat, was funktioniert braucht man natürlich nix neues kaufen.
Jetzt ehrlich Jungs? Gibt doch hier in keinem Szenario ein Problem. Lasst mit einer 4090 nur die Finger von irgendwelchen Adaptern und alles ist paletti.
Das Seasonic Kabel passt dann halt auch nur bei Seasonic Netzteilen. Bringt mir also nichts.
Es geht darum Kabel von Netzteilherstellern zu kaufen und nicht irgend welche Adapter oder so. Und inzwischen sollten die meisten großen Netzteil Marken eins haben oder man kann Seasonic nutzen (Asus etc)
und bei den Preisen braucht man sich nun wirklich nicht über geänderte Standards ärgern. Kauft man halt n neues Kabel, wenn man unbedingt den neusten Standard haben will. Mir ist sowas wumpe, das "alte" Kabel funktioniert bestens.
Ich habe mal Rücksprache mit BeQuiet gehalten wegen den ständigen 16Pin Volt schwankungen die viele haben und das teils mit den Selben NT
Als Antwort kam das ATX 3.0 eine schwankung von +-5% haben darf sprich im idle sind bis zu 12,6V im grünen bereich und unter Last sind sogar 11,4V noch im grünen Bereich
Bei 11,4V glaube ich eher Brennt die 4090 Lichterloh :ROFLMAO:
Also sollten wir uns alle keinen Kopf machen ob nun 12V oder 11,9V unter last anliegen
Ähnliche Themen
Antworten
7K
Aufrufe
586K
