[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
in hwi64 nennt der entwickler es "gpu rail voltages". das ist die neueste beta 8.0.1xxx, sieht aber in den anderen versionen ebenso aus (y)meine 16pin voltage geht 'runter bis auf 11.963, die pcie voltage ist aber dauerhaft unter 12V seh ich grade :eek: sollte ich mal gucken...? bequiet 1200W mit deren kabel here. aber die pcie voltage dürfte egal sein (bezogen auf steckerbrand)? nur auf nr. sicher :)
Ich sage mir seit dem Vorfall Vorsicht ist besser als Nachsicht
Und das die Werte soviel besser sind mit dem original Kabel von bequiet hätte ich nicht gedacht
Meine pci voltage ist quasi immer identisch mit meiner 16pin voltage
Ich bin laut HWInfo mit dem Fasgear Kabel Idle bei 12,1-12,2V :<
Und ich meine das minimum unter Last ist auch nicht großartig unter 12V aber muss ich nochmal checken :d
Ich hab es hier und anderswo schon x mal gesagt Leute, nutzt die Originalkabel der Netzteilhersteller und sonst nix. Dieser ganze Adapterkrempel ist totaler Mumpitz.
Naja mein Netzteil ist von 2018, alleine dafür würden mich hier einige vermutlich schon steinigen wollen :d
Naja, Netzteil ist ja nicht so wild. Ist ja dein Strom, den du bezahlst. Aber nur Gold-Effizienz...mmh...
*Mistgabelspitzgeräusche* ;)
Netzteil ist uns hier egal. Wenn es funktioniert, dann sollte man es solange weiterverwenden, bis es den Geist aufgibt oder zu schwach ist. Oder man einen aktuellen Anschluss benötigt.
  • Danke
Reaktionen: hwk
Meins ist jetzt auch 4 Jahre alt und das davor hatte ich glaube ich 6 Jahre genutzt. Am Ende zahlt es sich aus Qualität zu kaufen.
Die Mistgabel oh nein... :d
Dann bin ich ja beruhigt, dass ich hier nicht verfolgt werde deshalb :P
850W... 700W... wer bietet weniger mit einer 4090? :fresse2:
Kann auf jeden Fall mehr Jahre bieten. 11 Jahre ist mein treues DP Pro 10 750W jetzt.
Damals hat es mit 780 Ti SLI auch regelmäßig um die 800 Watt gestemmt
Minimum 12,0V am 16PIN-Stecker bei 680W peak (Furmark @4K + 2x MSAA) - damit kann ich leben...
War jedoch mit dem unschönen "Quadropus" von NV. Mit dem Corsair (2 Zuleitungen) hab ich 11,8V
ich denke alles ab >11,95 bei weit über 520 watt + ist safe im rahmen
Trotzdem wahnsinn was für große unterschiede unter den Kabeln herschert von 11,8-12V ist ja alles dabei unter last
Wobei ich auch sagen muss mein BeQuiet hat schon ATX 3.0
Mit meinem Corsair 1200W komme ich unter Last nicht unter 12,056V.
Bei keinen der Werte die man auslesen kann bin ich unter 12V getestet bei 430-470 W.
Orginal Corsair Kabel.
An welchen Wert wird sich jetzt eigentlich orientiert bei Schiene habe ich so 12,125V Ingame
Beim Netzteil die 12v kann ich mir auch noch anzeigen lassen.
Wa ist denn die FBVDD Spannung? die anderen Spannungen sind mir klar, einmal Slot und einmal Kabel.
Also bei 600 W Powerlimit @ max. OC + 1,1V @ Speedway Belastungstest bei über 500 Watt Leistungsaufnahme schwankt
es laut Aida bei 11,798-11,813V. Um geringer die Leistungsaufnahme ist umso mehr Spannung liegt drauf.
Idle dann 12,2V. Bei meinem UV Setting 0,975V @ 2700/11000MHZ liege ich bei 12 V beim Gaming.
Das Kabel steckt korrekt drinne seit Dezember 2022 wo ich nochmal neues Board/CPU gekauft habe.
Hab mal bei Corsair angefragt ,weil habe selber kein richtig Plan zu dem Thema.
Bisher ist alles inordnung , aber betreibe meine Karte @ UV und bin auch teilweise im FPS limit.
Deswegen betreibe meine Hardware eher schonend um bessere Temps und daraus resultierend geringere Lautstärke zu erreichen.
@ Stock finde ich macht mir die Karte zu viel Abwärme die nicht sein muss.
