[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Der typische 0815 Nutzer nimmt das halt so hin. Ist halt so, ist normal. Hatte eine GTX 280 aus 2008 auch.
naja wir wissen das die Hersteller zwar Spulenfiepen physikalisch nicht komplett verhindern können, aber eben sehrwohl technisch mit optimaler Wicklung der Spule und ordentlichem ausgiessen der Spule, das ganze Problem auf ein absolutes Minimum reduzieren könnten. Was müssten sie dafür tun ? nicht viel ausser von ihren Zulieferern eben nur noch solche Spulen in besster Qualität verlangen und auf die 1-5 Euro Marge (wahrscheinlich eh viel zu viel) pro Karte verzichten die das ganze dann vom Zulieferer eben teurer wird. (Dasselbe Spiel gilt für manche Lüfter auf den Grakas, die einfach nur unter aller Sau sind weil der Hersteller halt noch ein paar Euro Marge pro Karte rausquetschen will)
Das man das bei ner 100 Euro Karte macht und meinetwegen auch noch bei ner 500 Euro Karte , ok kann ich irgendwo aus Herstellersicht noch nachvollziehen, aber bei Karten über 1000 bzw gar wie bei der 4090 aber min 1600-2000 Euro da ist das einfach nur ne Frechheit.
Und da ich obwohl ich das alles weiss, ich wieder besserens Wissens trotzdem 1700+ für so eine Karte raushaue und dann noch selbst drann rumbastle und nochmal 100+ Euro in einen Lüftermod versenke, naja als wenn oder was würde jeder halbwegs normale Mensch ausserhalb unserer kleinen hardwareverrückten Community so jemanden wie mich/uns bezeichnen :confused:
richtig als Trottel :fresse2: :banana:
aber so ist es halt mit der Sucht nach Hardware, mann kann nicht anders :d
Kannste ja machen, seh ich für mich anders. Und die Marge ist als Grund wohl kaum haltbar. Denn gerade bei einer 1900€ Karte könnten sie das ohne Probleme auf den Preis draufschlagen.
Stand wohl einfach nicht im Lastenheft.
Gibt es mittlerweile ein 12VHPWR Kabel im 90 Grad Winkel? Auf den Adapter von Cablemod will ich gerne verzichten. Und es muss auf beiden Seiten den 16 Pin Stecker haben.
Edit:
Bei Amazon habe ich das hier gefunden. Nur sicher bin ich mir da auch nicht.
LINKUP – AVA Linken Winkel 600W PCIE5.0 12VHPWR (16-polig/12+4) 16 AWG ummanteltes Hochstrom-Netzteilkabel – 70 cm – (Weiß) Kompatibel mit allen RTX4000- und RTX3000-FE-GPUs https://amzn.eu/d/7EzzcCz
So ein Kabel gibt es bei Cablemod (oder willst du auch kein Kabel von denen?)
Seasonic hat inzwischen auch 90grad Kabel, aber halt mit dem NT-Anschluss auf der anderen Seite.
Hm bei Cablemod finde ich nur 16 Pin zu PCIe Kabel.
Also ein Verlängerungskabel? Stehe auf dem Schlauch. Bei CM kannst du dir doch für jedes NT das Kabel modden, warum brauchst du auf 16Pin? Im Notfall schreib dem CM Support an, dass die dir sagen ob sie das haben (gibt auch ein Cablemod Reddit wo die aktiv sind).
https://eustore.cablemod.com/configurator/ und hier kannst du dein NT direkt auswählen falls verfügbar.
Weil es ein PCIe 5 Netzteil ist und der 16 Pin Anschluss auch am Netzteil ist.
Und ich habe gerade mal auf die schnelle im Konfigurator geguckt. Erstens ist 60€ ein heftiger Preis und als 90 Grad scheint es das auch nicht zu geben.
Edit:
Habs in 90 Grad gefunden aber 54€ ist mir ehrlich gesagt zu teuer.
Weiß auch nicht genau was der Grund dafür ist, wenns nicht die Marge ist. Denn eigentlich sollte man meinen dass man sich als Marke absetzen will. Zumindest wenn man als "Premium" gelten will. Warum gerade diese Marken dann nicht auch auf Nebengeräusche achten, verstehe ich nicht. Man stelle sich vor man könnte sich immer drauf verlassen dass z.B. Asus oder MSI auf Nebengeräusche und Verarbeitungsqualität achten. Da würde kaum einer mehr was anderes kaufen. Aber gut. Vielleicht sinds dann doch die paar Cent die den Unterschied machen (ist oft so, weil es sich bei den Stückzahlen eben doch rechnet).
Das ist echt viel, mit den 2x8 pin Anschlüssen liegt es bei 30€. Der Aufpreis ist krass. Oder rechnest du inkl. Verssand (der leider auch viel zu hoch ist).
Wie steht ihr zu der Problematik mit den geschmolzenen Stromanschlüssen in Verbindung mit den Cablemod Kabeln? Ich bin auf Reddit unterwegs und da vergeht kein Tag, ohne dass jemand seine geschmolzenen Cablemod Kabel samt geschmolzener 4090 postet.
@KopfWand Die Probleme gibt es scheinbar nur bei den V1.0 Adaptern. Kabel sind scheinbar gar nicht betroffen, von tatsächlichen User Fehlern mal abgesehen. Ich hab aber ganz andere Probleme mit denen, hab gerade nen Rant in deren Support Reddit gepostet :poop:
https://www.reddit.com/r/cablemod/comments/1760k1g/90_degree_cable_very_poor_order_experience/
Kann natürlich sein, dass wenn man jetzt bestellt man nicht so lange wartet, aber die behaupten ihre Factory hatte nen großen Backlog weil für die 90° Stecker irgendwelche Teile fehlen.
Warum kauft man denn noch bei Cablemod? Scheint ja mittlerweile ein Problemverein zu sein
Mittlerweile ist relativ ich hab im Frühjahr den V1 Adapter gekauft da sah alles schick aus und es gab exakt 0 Alternativen für 90° Kabel. Inzwischen hat ja sogar Seasonic eins und ich würde aus heutiger Sicht einfach das nehmen. Die zweite Order für das Kabel hab ich nur gemacht, weil es dafür nen Voucher gab.
Ne ist ohne Versand. Mit Versand sind es bestimmt 70€
Dann hole ich mir halt noch ein Wireview.
70€ wäre mir auch zu wild.
Endlich gekommen der Schnapper aus Holland.
Knapp 1669 Euro … für ne Ultra denke ich ganz gut. Jetzt kostet Sie dort auch 2049.
Schöne Karte ;)
Hoffe du hast eine mit guten Toleranzen :d
Beste Grüße
Hast du da einen Link? Wusste nicht, dass Seasonic das 90° Kabel endlich mal herausgebracht hat.
Beste Karte die man für den Alltag eigentlich kaufen kann und dann zu dem Preis . Müsste ja die sein mit 24 Phasen und den tendenziell leiseren Spulen bzw. die hohen schwarzen Klötze .
Hab sie auch. Bisher die leiseste was Spulenfiepen angeht die ich hatte. Dazu voll bestücktes PCB. Ich hab aber doch bisschen mehr bezahlt, aber war es mir Wert.
Beste Grüße
Das Seasonic 90° Kabel sieht irgendwie komisch und gar nicht wertig aus. Die Originalkabel sind nicht so gesleevt oder?
Sieht auf dem Bild genauso aus wie das Kabel mit dem geraden Stecker das ich von denen habe. Denke da wurde nur der Stecker getauscht.
Habe mal das 90° Seasonic Kabel in weiß bestellt, die Krake wird nun schlussendlich doch mal abgelöst.
Seit wann gibt’s das Teil eigentlich im Handel?
Hatte immer mal wieder Ausschau gehalten nach der Ankündigung im Dezember 22, aber bisher nichts entdeckt und plötzlich voila.
Keine Ahnung, ich hatte das zufällig gesehen weil sich im Cablemod Reddit jemand anders ausgekotzt hat, dass es inzwischen Kabel von Seasonic direkt gibt und Cablemod es in 3 Monaten nicht hinkriegt mal ein nicht-defektes Produkt zu liefern. Wenn ich nicht schon so viel sunk cost bei Cablemod hätte, würde ich mir jetzt auch das von Seasonic kaufen.
Lange kann es aber noch nicht sein, ich hatte vor 3 Monaten nämlich auch nochmal geschaut ob es ne Alternative gibt.
Da musste ich jetzt schmunzeln. Natürlich geht das auch nach einem Jahr noch. Wollen die jetzt jedes Jahr einen "Artikel" dazu bringen? Je nachdem wie schlecht der Besitzer gesteckt hat, konnte das natürlich auch ne etwas längere Zeit gut gehen.
Einfach wie bei jedem anderen Stecker auch schauen, dass es richtig sitzt, dann passiert auch nix.
