[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Mein NT ist schon so alt das eh schon bald sinn macht nen neues zu kaufen. Glaub habe mein NT 2013 gekauft
Gute Netzteile halten so lange. Meins hat auch 10 Jahre auf dem Buckel. War ne gute Wahl damals, und war das Geld wert^^
Das NT hat auch einiges mitgemacht. Habe da lange zeit immer SLI drauf laufen lassen. Zwei Titan X (Maxwell) mit 450watt und ner intel 3700k cpu@4,8ghz und RAM OC. Hatte damals bei Crysis 1 über 1100watt aus der Steckdose gezogen aber ist nicht aus gegangen. Glaub war auch angegeben mit 1000Watt@24/7 betrieb und Peak 1150watt wo es dann abschaltet.
wird aber mal zeit für was neues und will eh den Rechner umbauen.
1000Watt Corsair RM1000e ist bestellt 😉👍🏻
Nimm das HX1000i lieber 🙃
Muss man da nicht zum umschalten von Multirail zu Single und Icue am laufen haben?
Oder ist da Standardmässig Single Rail Aktiv?
Ich hab das damals nicht gewusst und muss die Rotze jetzt immer mitlaufen lassen bei meinem HX1200i.
Dafür kann ich mir zwar Verbrauch usw.anzeigen lassen aber darauf könnte ich auch verzichten.
Seasonic ist auch das beste. Aber die Silverstone NTs sind auch mega wie man ja bei meinem Strider 1000 sieht.
Habe mir nun halt das RM1000e bestellt weil es im Test sehr gut abgeschnitten hatte. Für Corsair bekommt man auch gute Kabel und für 134€ finde ich das NT mega Gut.
Früher habe ich ja auch immer SLI genutzt aber die Zeiten sind ja vorbei daher sollt das NT überhaupt keine Probleme mit meinem System haben.
Werde die 4090 auch @ UV bei 2700Mhz laufen lassen weil es eh kaum was bringt da alles rauszuquetschen.
Ist halt was anderes als früher mit den Beiden Titan die man von 1060Mhz auf 1500Mhz übertakten konnte
Mich würden auch die Temperaturen Deiner 4090 interessieren.
Bei 27C° Wasser habe ich bei Metro Exodus Enhanced Edition auf Extrem @5760x3240
Die Werte der Karte kann man ja oben links sehen
Einfach brutal wie die Karte das durchzieht..... Diese Auflösung + Extreme settings und DLSS....
Bei Stocktakt 2775@1,05V habe ich 42C° anliegen und bei 2820@1,0V ist es 41C° auf der GPU.
Gestern war die Temperatur etwas schlechter aber da hatte ich auch etwas mehr Luft im Kreislauf
Bei 440Watt hatte ich glaub ich nen Delta von 16C° Wasser zu GPU Temperatur
Ich denke, ein Delta von 20° C dürften normal sein.
Habe ich nie gehabt. Wurde ja auch schon zu RTX3000 gesagt aber so einen hohen Delta habe ich nie gehabt. Das liegt aber auch mit sicherheit daran das ich nen sehr hohen durchfluss habe.
Meine RTX3080Ti@400Watt@Liquid Ultra hatte nen Delta von 12C° bei 220L/h
Aktuell habe ich nur 184L/h weil ich noch zuviel Luft in den Radiatoren habe.
