[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
oh ha... Das nenn ich standhaftes hpbby, Aber geld ist doch zu schade :( *WachIchDickRüttelmuss*
Kann dich beruhigen. Foto stammt vom Herbst, als ich meine persönliche 4090 ausgewählt habe (Story dazu irgendwo ein paar hundert Seiten weiter vorne).
@Tannenzapfen Welche Karte ist es für dich geworden?
Eine Asus TUF OC. Allerdings nicht die auf dem Bild, sondern eine weitere. Die erste Karte war anfangs zwar ruhig, aber nach einer Änderung meiner Gehäusebelüftung nahm ich eine bestimmte Tonfrequenz wahr, die mich leicht störte. Habe mir, weil ich ansonsten mit der TUF OC sehr zufrieden war, eine weitere bestellt. Diese war dann so gut wie ruhig und erfüllt ihren Dienst bis heute.
Wenn man den beendet geht der gleich wieder auf, weißt du einen Weg RTSS zu beenden ohne den Ab schließen zu müssen?
3DMark Windows 2.27.8160 — August 17, 2023​
This is a minor update. Benchmark scores are not affected.​
Fixed​
  • Fixed an issue where Solar Bay results would not award score-based achievements.
  • Added a workaround for Solar Bay failing to load when Riva Tuner Statistics Sever (RTSS.exe) is running.
Nur leider besteht der workaround darin, zu verhindern, dass der RTSS sich in den Benchmark einhaken kann.
Wie sieht es denn aktuell mit dem be quiet 12VHPWR Adapter aus, ist der halbwegs safe? Den könnte ich halt nativ einstecken ohne triple 8er.
Hab einen verbaut und bin zufrieden. Gute Lösung, teilweise aber starres Kabel. Mit Gefühl aber gut zu biegen. Kontakte passen exakt.
Das 1.07V VDDC Limit lässt sich damit wohl aufheben ?!
Eventuell will es ja jemand testen.
Erst Mining dann Corona und jetzt KI, RIP GPU Markt und Gaming PC. :fresse:
Ich hatte hier mal darüber geschrieben (die KI soll in Zukunft ca. 90% der Verwaltung (durch Menschen) ersetzen)...
Ist echt Wahnsinn, was mit KI jetzt schon möglich ist. Nur wir hier in DE hinken anderen Ländern um Jahre zurück
Grundsätzlich ja.
Man sollte aber immer eine Sichtprüfung unternehmen und sich den Stecker genau anschauen.
Ja klar, wenn der nicht bündig abschließt, dann würde ich dem Ganzen schon nicht trauen. Hab die ganze Zeit dieses hässliche der FE beiliegende triple Kabel genutzt. 0 Probleme, aber die Karte sieht auch nicht viel mehr als 150w.
Hatte letztens schon geschrieben nimm den wenn du ein be quiet PSU hast. Wenn du soviel Angst hast, verkauf den PC und hol dir ne Konsole. :d
:d
Ich hab in erster Linie keine Lust bez. evtl. Ausfallzeit und gerade wenn die Karte nun wieder im Kreislauf landet erst recht nicht.
Baue den gleich um:
Was für ein wertiger Brocken das ist. Top!
Hm, mit der alten TUF kam ich mit dem 1.000W-BIOS, ohne Hard-Mod nicht mal annähernd an 900W
Auch Benches fielen damit nicht so hoch aus, wie mit dem 666W-BIOS
Hast du mal den Link zu dem BIOS? Habe 2 verschiedene 1.000W-BIOSe
Oder die neuen TUFs/Strix reagieren nun anders aus das BIOS
Die neueren Karten haben doch ein Limit bei 1.07V, mit diesem neuen NVFlash Mod lässt sich jetzt wieder ein 1.10V BIOS auf diese Karten Flashen.
Weiß ich... ;)
Es ging darum, dass er ohne einen Hard-Mod mehr als 900W ziehen kann. Das war bei mir nicht möglich
Mit nur 30mV soviel mehr ziehen. Müsste ich bei Gelegenheit mal testen
Die genaue Quelle des BIOS hab ich nicht gefunden
btw:
Inklusive dem BIOS von techpowerup hab ich nun 3x 1.000W-BIOS mit verschiedenem Inhalt
Was nicht heißt, dass die Versionsnummer "95.02.18.80.83" anders sein muss (ist man ja von ASUS schon gewohnt)
Die werden wenn es korrekt läuft als B Ware verkauft.
Ich Frage mich immer, was mit den Zurückgekommen Grafikkarten beim Händler passiert. Werden die vom Hersteller umgetauscht? Dann wäre es ja kein Wunder, das die Preise nicht fallen.
Caseking, Alternate, Cyberport, Notebooksbilliger usw. haben dafür einen Outlet Bereich
Ja oder Sie gehen 1 zu 1 wieder in den regulären Verkauf
Das dürfte wohl die häufigste Variante sein. Bei Händlern, die auch konfigurierbare Komplettsysteme anbieten, werden solche Komponenten ggf. auch in solchen eingesetzt, sofern keine Mängel vorliegen.
