[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Gibt es eine rtx4090, die nicht nur einen 12VHPWR StromversorgungsStecker auf der Leiterplatte hat, sondern zwei 12VHPWR oder zwei..drei.. klassische 8pin Stecker?
Wenn der Platz auf der Leiterplatte nicht vorhanden ist, wird es schwierig mit modden der Stromanbindung. Da bleibt nur die StromversorgungsStecker garnicht mehr auf der Leiterplatte zu haben, und statt dessen ein NT-Kabel (mit 3-4 8pin NT-Steckern) direkt auf der Grafikkarten Leiterplatte ein zu löten.
im leben nicht. das glaubt doch kein schwein
Warum sollte nicht auch Asus auf Kritik reagieren?
Bei der LC kann man dann wohl sicher sein schon die Revision zu bekommen, denke ich mal....
Besonders bei der Matrix wäre wohl die erwähnte Software mit der man die Spannungen weiter anheben können soll interessant, ob das vielleicht später auch mit anderen Karten von Asus geht?
Geht es alles irgendwie…
Ext. PCBs mit nur Stromversorgung gibt es für ältere Karten. Sind aber sehr rar
Wer es noch nicht gesehen hat, Matrix angeblich selektierte GPU, leisere Spulen (soll wohl bei der Strix auch umgestellt worden sein) und mehr Spannungsänderung via Software:
Scheinbar laut einiger Aussagen 2670 MHz Stock Boost. Ob da jetzt trotzdem groß selektiert werden muss, wird sich zeigen.
Ok wirklich interessant an der Matrix scheint ja dann überwiegend diese Software zum erhöhen der Spannung zu sein ....
Ich glaube das auch erst wenn ich's sehe bzw. höre. Hoffe wirklich dass er da nochmal n Video zu macht.
Die Meldung muss von Asus direkt kommen und nicht von dem Verkäufer da.
Wenn es sich dann zeigt, dass die Spulen wieder nur random fappen, dann hat man Asus bei den Ejan statt den verkaufenden 8auernopfer.
Keine Ahnung warum bei dieser Karte so ein leichter Hype entsteht (8auer machts möglich)
Anstatt mal was an den Problemen zu machen, siehe Spulenfiepen, große Karten, 12VHPWR Anschluss, fehlende Karten mit GPU-Blöcken, etc., werden solche komischen Cashcows auf den Markt geworfen. Mir kann keiner erzählen, das AIO Karten so ne riesen Nachfrage haben.
Es packen sich deutlich mehr Leute ne Karte mit Block ins System, als das es Leute gibt, die sich ne AIO-GPU reinpacken.
Und dann noch die völlig blöde Platzierung der Schläuche bei der 4090 Strix LC
Und was hab ich von der Karte mit mehr Spannung?
660W anstatt 580W?
3150MHz anstatt 3050MHz?
200 Pkt mehr bei TimeSpy?
Oder benötige ich das unbedingt in meiner Signatur um den Längsten zu haben?
Es gibt deutlich wichtigeres als ner Karte 60W mehr im Bios zu spendieren. Ich möchte lieber ne Karte haben, die zu 100% erträgliche Spulen hat, deren Stromanschluss nicht abfackelt und das bei diesen aufgerufenen Preisen.
Dieser OC Kram ist einfach Quatsch... aber damit lässt sich gut Geld aus der Tasche der Nerds ziehen, sieht man ja schon alleine an den ganzen OC Varianten jeder GPU.
Wenn man sich primär mit den Problemen befassen würde, dann gerne auch solche Spielereien, denn das sind diese Karten, reine Spielerei.
Sind Hautfette nicht ein prima Trennmittel, gerade auch bei Minusgraden? Ich mag ja auch sehr viele Sachen von 8auer, aber manchmal kann ich nicht glauben was ich auf seinen Videos sehe...
Zum Thema Spulenfiepen wollen sie ja anscheinend was machen, oder haben es bereits. Klar, bis das verifiziert wurde, bleib ich da auch sehr skeptisch, aber bis dahin unterstelle ich ihm oder dem Asus Sales Rep. gleichzeitig auch nicht einfach so, dass sie lügen. Bin gespannt.
Stimmt, Asus ist so kundenfreundlich, besonders nach deren letzten Aktion mit deren MB, Bios-Updates und Garantiepolitik, dass man denen sofort alles abkaufen kann.
Ich glaube das erst, wenn hier in dem Fiep-Thread jede einzelne Asus-Karte stumm ist, ansonsten ist das reinstes Geblubber. Erschreckend ist es viel mehr, wie so ne in den Raum geworfene Aussage, den einen oder anderen hier völlig freaked out durchs Zimmer laufen lässt.
Aber am schlimmsten ist der Fakt, das es anscheinend DOCH ein Problem mit den Spulen gibt, was man ja nun so beiläufig zumindest erwähnt hat, aber von keinem Hersteller in der Vergangenheit irgendein Muks gekommen ist. Selbst die unzähligen YTer, die ja immer alle ganz nah an ihrer Community sind (aber wohl doch einen Tick näher an den Herstellern), nichts dazu in voller Breite gebracht haben.
Alter, ich glaub Du hast n paar persönliche Probleme oder so... :lol: aber schimpf nur weiter. N bisschen Wut ist ja bekanntlich gut fürs Blut. :teufel:
Kein Mensch rennt hier aufgeregt durchs Zimmer...
Ahha, direkt mal schön persönlich werden. Aber 'tschuldigung, dass deine "Lieblingsfirma" nun mal in letzter Zeit kein gutes Bild von sich abgibt. Vielleicht solltest du deine Wut lieber in Richtung dieser Firma lenken, kein anderer User kann etwas dafür und schon lange nicht dafür, dass er das Aufzählt was Fakt ist.
Und du hast doch zu den ersten gehört, die sofort ne Mail an Asus geschrieben haben, nur weil in irgendeinem YT Video einer rumplappert.
Spulengeräusche gibt es schon lange .
Also meine erste Karte die ich dahingehend im Kopf habe ist die Leadtek GTX 275 .
Hatte danach von jeder Gen. mind. eine Karte . Die Lüfter bzw. waren damals wesentlich lauter . Man war nicht so sensibel wie heute .
Als ich auf Wasser umgebaut habe war es dann für mich gefühlt extremer . Allerdings bei mir war eine Aorus RTX 2080TI WB Extreme tatsächlich die schlimmste Karte , weil die richtig gefiept hat . Da ist die Asus ein Witz gegen ^^ .
Hab letztens ein Thread gelesen mit einer News zur 8800GTX Ultra . Die Kommentare
Zu den Preisen wie heute alles zu teuer , aber als wirklich leise Karte empfunden . Heute könnte man das knicken .
Sicherlich gibt es Spulenfiepen schon lange. Nur nie in so einem Ausmaß wie bei dieser Gen... die 3000er Karten waren ja schon ein leichter Vorgeschmack. Wir sind jetzt bei den teuersten Karten ever angekommen, aber diese haben massig qualitative Probleme.
Warum geht man das Problem dann nicht schon seit Jahren an, wenn das doch schon so lange bekannt ist? Ist anscheinend nur ein Problem was ziemlich weit unten in der Problem-Skala rumdümpelt. Oder einfach nur nicht interessant weil man da kaum Kapital rausschlagen kann?
Jeder der seine Karte auf Wakü umgerüstet hat und der Mal ein paar Watt mehr genehmigt hat, kennt das. Und nicht erst seit der 4000er Generation. Die meisten merken es nur nicht, weil der Lüfter bisher immer lauter war.
Btw, meine Inno3D hat nur sehr minimales Spulenfiepen :)
Ist meiner Meinung nach nicht wesentlich schlimmer geworden, gleichbleibend schlecht würde ich es wohl nennen 🤘
Woher nimmst du diese Annahme? Glaube deine Sicht ist hier verzehrt aufgrund deiner eigenen Interessen. Man muss sich doch nur das Angebot angucken, dann weiß man, dass die Nachfrage für AiO viel höher sein dürfte. Sonst würde wohl kaum jeder zweite Hersteller eine mit AiO Kühler rausbringen und fast keiner eine mit Block.
Woher ich meine Annahme nehme? Ganz einfach in diversen Foren lesen weltweit, PC Builds angucken weltweit... Und da ist klar zu sehen, dass ein Bruchteil der User auf Karten mit AIOs setzen.
Und wenn die Nachfrage doch so hoch ist wie du meinst, warum gibt es sie dann nicht, die etwas günstigeren Karten mit AIOs? Nein das ist dann immer ne Suprim, Strix oder Xtreme. Und was die Blöcke angeht. Was erwartet man von den Usern, wenn die Karte mit Block erst 1 Jahr später kommt. Die wenigsten werden natürlich solche Karten kaufen, weil sie schon seit 1 Jahr selber Hand angelegt haben und die Karten somit völlig uninteressant sind. Die Karte mit Block muss zu Release parat stehen, so wie es Inno3D gemacht hat.
Hier geht es rein um finanzielle Interessen, was ja auch völlig legitim ist. Wasserblöcke zu bauen kann teuer werden bzw ist teuer, wenn man es nicht so wie Inno3d macht und sich Alphacool als Partner ran holt. Dann lieber ne Asetek Pumpe drauf, Alu Radiator, völlige Unwartbarkeit der AIO, bissl Bling Bling und Marketing-Bla-Bla
Also erstens ist es wohl kaum als "aufgeregt" zu bezeichnen, wenn man so ne Aussage von nem Techtuber gerne vom Hersteller selbst verifiziert haben möchte. Und zweitens geht es Dich einen feuchten Kehricht an, wie viele Grakas sich die Leute bestellen. Wenn ich noch Bock auf 20 weitere 4090 habe, mach ich das einfach.
Zu guter letzt ist das mit der "Lieblingsfirma" ne Unterstellung, für die Du überhaupt keine Grundlage hast. Eine nicht fiepende 4090 Strix wäre der Inno, die ich aktuell habe in jedem Fall vorzuziehen. Ansonsten find ich aber Asus auch nicht so pralle, mal ganz generell gesprochen.
Hast du belegbare Zahlen? Ich denke AIO Karten sind nur eine Minderheit. Und Custom die Minderheit. Man sollte nicht ein paar Foren oder YT als Grundlage nehmen. Gucke ich in meinem Umfeld bin ich der einzige mit Wakü. Aus diesem Grund kommen auch wenige Karten mit Block drauf. Es lohnt sich einfach nicht. Frag doch zB bei WC und Co Mal nach wie viele sie absetzen. Und setz das in Relation zu den verkauften Karten.
Davon ab, was soll eine AIO auf einer günstigen Karte? Der die günstige kauft, kauft sie des Preises wegen. Sprich, eine AIO, die das ganze teurer macht, macht das null Sinn. Die kaufen eben die, die eine bessere Karte wollen. Und der Aufpreis eben nicht "stört".
P.s. ich mag AIOs auch null, aber der Markt scheint diesen eben seine Daseinsberechtigung zu geben. Würde deine These stimmen, wären mehr Karten mit Block statt AIO verfügbar.
Alles klar, also rein persönliche Wahrnehmung auf Basis von Usern in Enthusiasten Foren... Sorry das ist garnix. Die AiOs werden sich schon lohnen für die Hersteller und Blocks eher weniger, sonst würde der Markt anders aussehen.
Vor allem wenn Hersteller wie Gigabyte das Modell auf AiO gewechselt haben, die hatten sonst immer nen Highendmodell mit eigenem Block.
Und man kann sich bei Mindfactory ja einfach mal die "Verkauft" Zahl anschauen, damit man mal wenigstens n kleinen Einblick bekommt, anstelle sich auf Gefühle zu verlassen.
War Capoo nicht auch der jenige der Panik wegen den Stromsteckern gemacht hat, weil er n Montagsmodell erwischt hat? Nur zur Einordnung.
Was für ne Einordnung? Und Panik habe ich sicherlich nicht geschoben, sondern schön gechillt meine Karte getauscht. Aber stimmt, ein Anstieg von Postings zu abgerauchten Adaptern im Cablemod Reddit ist natürlich nicht aussagekräftig, alles nur Montagsmodelle, übrigens auch so ne Gefühlsaussage. Panik und Tränen in den Augen hat hier der eine oder andere, nachdem er 20 Karten wegen Spulenfiepen bestellt und wieder retourniert hat.
Ähnliche Themen
Antworten
7K
Aufrufe
588K
