[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wurde auch Zeit für eine Matrix, bin auf den Preis gespannt.
"NVIDIA Krake" gegen natives 600W Corsair Kabel ersetzt. Wird - obwohl nur 2 Anschlüsse statt 4 - deutlich weniger heiß am Stecker.
Vorsicht, der PC steht geschlossen unter dem Schreibtisch, daher nicht besonders clean 😇
Vorher:
Nachher:
Per Hwinfo/RTSS könnt ihr euch ja vorsichtshalber die Werte einblenden lassen und ggf. einen Alarm setzen, ganz praktisch:
Ich werde heute mal das native Seasonic Kabel von der GPU lösen und da kommt der 180 Grad Adapter drauf. Mal sehen wie das dann aussieht. Ist halt bisher alles gut gegangen aber dennoch, dieser Knick ist net so nice auch optisch nicht...
Lasst euch bitte nicht von meiner Fake Asus ROG Strix RTX 4090 Gaming OC irritieren, sind nur Aufkleber 🤣 außerdem habe ich das "Tuning" nicht offiziell angemeldet 🤫
... und wieder zwei Steckvorgänge verbraucht. :fresse:
edit: sieht doch gar net so schlimm aus. Solange es im Bereich kurz vor dem Stecker gerade ist, ist doch alles im Lot.
Ja sieht auch nicht schlimm aus 👍 aber will es halt optimieren.
Hoffe wird keine Verschlimmbesserung 🙏😃
Also ich hab auch so ne "Kurve" drin, dazu noch das ugly RGB-Kabel der Gainwardkarte aber irgendwann sollte die Form der Funktion folgen und nicht umgekehrt.
Ja, aber bei dir ist eine dann eine Abdeckung davor und steht bei dir womöglich nicht vor deinem Gesicht. In meinem Fall ist es aber genau das Problem, dass mich dieser Stecker über der GPU von vorne anschaut und die Kabel sind dicht am Glas des Case dran, was an sich nicht schlimm ist. Dennoch stört mich einfach diese Konstruktion und möglich ist da immer durck drauf, der nicht perfekt runter sondern leicht seitlich wirkt.
Auf den 180 Grad adapter hab ich schon lange gewartet jetzt wird der auch genutzt. Bei dir würde ich es auch so lassen wie es ist.
Ich verstehe echt nicht was sich die Karten Designer dabei gedacht. Also alle Designer. Selbst das größte Case hat dieses Problem bei einer Custom 4090 und diesen dämlich empfindlichen Stecker. Gehört fast schon in den Frust Thread.
@Mainhatten
Da hast vollkommen Recht!
das hätte sicherlich so einfach vermieden werden können.
Ach was die Dinger sind genau richtig so .
Keine Angst die werden wieder kleiner .
Als ob die Hersteller mit Absicht diesen Material Verschleiß wollten . Man dachte ja die Karten würden mehr verbrauchen .
Der Anschluss ist an für sich auch ok .
Nur einige Hersteller sind dafür zu dumm Kabel zu produzieren.
Ansonsten ich hab genug Platz. Ein Monster dieser Art darf diesen auch haben . Ansonsten halt einen Mora raus und mit Wasser kühlen , weil die PCB der Dinger sind nicht so riesig .
Das sehe ich anders. Die Karten sind diesmal perfekt dimensioniert. Endlich anständige Temps. Und mein NZXT H7 Flow beispielsweise hat absolut kein Problem mit der Höhe der Karte. Selbst der NVidia Adapter passt total entspannt. Und hätte es das Seasonic Kabel schon bei Release der 4090 gegeben, hätte ich vielleicht noch nicht mal vom Lian Li 205 Mesh gewechselt.
Mittlerweile ja schon durchgerutscht, dass es nur ne ROG Matrix 4090 wird.
Da wäre mal interessant wie asus da noch deutlich mehr Leistung raus bekommen will, so eine Matrix wäre als ti sicher interessanter, aber wenn die als normale 4090 kommt, könnte das auch ein Hinweis darauf sein, dass vielleicht keine 4090ti mehr kommt!?
@Holzmann
Denke vielmehr, dass es sich um eine mögliche 4090 Ti Version handelt. Anders macht es doch keinen Sinn mehr... Oder die wollen unbedingt die Galax Hall of Fame übertrumpfen 🤔
Dann wäre es völlig absurd aber traue es Asus durchaus zu.
Die Asus Rog Strix RTX 4090 OC LC ist ja auch bald verfügbar. Weiß nicht wohin die noch wollen. Vielleicht mit einer seltenen oberklasse Chipgüte usw...
WTF??? :oops:
Ich habe in den letzten 1-2 Wochen plötzlich ab und zu einen Absturz, dass steht dann in der Ereignisanzeige:
Den Nvidia Treiber habe ich nun widerholt komplett neu installiert und vorher mit DDU entfernt, nützt nichts. Irgendwelche Ideen?
Klar, quasi als erstes.
Mainboard Ram mal default laufen lassen? Irgendwas zwischen Ram und Ram der GPU, Riser Karte? Bios update gemacht? Asus Tools deinstalliert?
Naja das Ganze ist bissel schwierig nachzustellen, tritt ja nur ca 1x die Woche auf.
Bisher in 3 Wochen genau 3x, RAM etc habe ich noch nicht nach unten geschraubt, da er mir ja recht eindeutig sagt das die GPU bzw. dessen Treiber hier den Fehler verursacht. Und ne, eine Riser Karte ist es nicht, neue Asus Tools sind auch nicht drauf, Bios Update ist ewig her da es schön stabil läuft.
Karte lief bisher seit November auch völlig und komplett störungsfrei. Dabei spiele ich zur Zeit nur ein Spiel: Wartales, GPU geht auch nicht über 50 Grad dabei.
Blase mal den Kühler der Grafikkarte richtig aus und entferne allen Staub. Evtl. hat sich auch nur ein Stromkabel gelockert? Wenn die Karte lange Zeit übertaktet war, kann sie natürlich auch einfach defekt sein. Hast Du eine andere zum testen da?
Falls es jmd. interessiert, dass sind die Werte einer Gigabyte 4090 Aorus Waterforce Extreme, nach eine 2 stündigen gaming Session, finde die Temps ganz ordentlich, hier bei reduziertem Lüfterprofil auch sehr leise:
Jeder, der sich heute noch n Radikallüfter ins Gehäuse schraubt, hat die Kontrolle über sein Leben verloren. :d
Radikallüfter :d Der Radiallüfter auf der LC kühlt aber nur die Komponenten der Stromversorgung mit geringer Drehzahl, sonst ist das auch ein Fullcover Kühler.
Aber ihr habt recht, gegen die Poseidon/Matrix wird die LC Kinderspielzeug sein .....
