[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Joa ist in der Regel ein CPU Limit , wenn die GPU nicht voll ausgelastet ist . Irgendwas limitiert halt immer . Die RTX 4090 muss nicht zwangsweise über 400 Watt verballern auch wenn diese ausgelastet ist @ Stock . Am besten immer mit benches vergleichen die man zu genüge im netz findet . Bei timespy Extreme wird nichts limitieren bei einem 7900X . Da hat selbst mein 10900k nicht limitiert.
Wenn Time Spy ein reiner GPU Benchmark ist warum ist die Karte dann nicht zu 100% ausgelastet?
Gut der Benchmark ist schon was älter vielleicht reizt es die Karte in gewissen Szenen nicht aus?
Schau mal nach im Bereich Oktober - Dezember hier in dem Thread. Da wurde so viel 3dmark getestet . Auch gibt es hier einen 3dmark Thread . Ich komme mit dem 13900k nicht mehr ins CPU Limit bei Timespy normal.
Vorher mit Cometlake definitiv.
Wieviel GPU-Auslastung hast du bei Furmark @4K ohne AA und 2x AA?
Bei diesen Settings werden bei mir die vollen 666W gezogen
ich? 100% auslastung bei 96% tdp was ca 430-435w entspricht.
meine frage bleibt:
wieso dümpelt die grafikkarte ingame bei rund 50+% gpu load und knapp unter 50% power consumption herum, wenn damit nicht konstant 144 vsync fps gehalten werden können?
nein, dlss ist ausgeschaltet.
meine frage bleibt:
Was zockst du denn und welche CPU hast du? Wahrscheinlich limitiert es da an anderer Stelle.
Intel Core i9-13900K. siehe auch mein system.
das verhalten ist bei jedem aktuellen game das gleiche...
"maximale leistung bervorzugen" und "fortgeschrittene 3d einstellungen" verwenden. wobei die umstellungen beider punkte exakt gar nichts verändert. die auslastung oder die fps betreffen.
Anderes Bios schon getestet?
Flash mal Bios von Asus drauf.
Das kann ja nicht die Lösung sein. Zumal er sich selbst als Noob bezeichnet…
Andere Games testen… Eventuell CPU Limit durch Ingame-Settings wie RayTracing.
Der RAM läuft auch im Gurkenmodus mit 5200 MHz.
Oder andere Ingame-Settings testen.
Och, mit Hilfe von Teamwiever ginge das schon :d
Wir kennen halt die Verhaltensweise von diesem Omen-Komplett-PC nicht. Ist ja nicht unüblich, dass MBs etc firmeneigene FWs erhalten
Aktuelle Games laufen öfters ins CPU Limit, vor allem mit Raytracing. Müsstest schon genaue Titel nennen, dann könnte man vielleicht sagen, ob das Verhalten des Rechners nicht vielleicht doch normal ist.
bios(fremd) flashen und oc kommen für mich aktuell nicht in frage, da ich dadurch die garantie verlieren würde (2Jahre noch).
5200 mag gurkig sein, kam werkseitig mit 4400 weil xmp off. was (beides) für das setup eine frechheit ist.
was wäre denn im gesamtkontext sinnvoll an mhz und cl? gerne einen konkreten vorschlag ;)
das grundlegende problem fängt tatsächlich schon bei spielen wie wow an und zeigt sich bspw. auch bei sons of the forest, medieval dynastie oder cyberpunk.
und das auch mit ausgeschaltetem raytracing. ich denke nicht, dass die cpu die bottleneck sein wird. deshalb nehme ich gerne konkrete empfehlungen zum ram an. (der preis ist erst mal zweitranging)
Sinnvoll? Im Luxx? :d
Du bist ziemlich sicher im CPU Limit. Deine genannten Games haben jedenfalls alle das Potenzial dazu bei 144fps Zielframes, auch ohne Raytracing. Schnellerer Ram kann da schon was bringen, kenne mich bei Intel aber nicht aus, was da der Sweetspot ist. Hier sind aber einige mit Geschwindigkeiten jenseits der 7000 mt/s
@newb1
Erlaubt es HP überhaupt den Arbeitsspeicher zu übertakten? 5200 ist halt Intel Spec.
Kenne die OEM Dinger leider nur als Notebooks und da ist das UEFI ziemlich eingeschränkt.
xmp ist im uefi auswählbar und wird auch durch bspw. cpu z bestätigt.
custom werte gehen übrigens auch.
neue newb these:
meine cpu befindet sich laut xtu quasi dauerhaft im current/edp limit throttling. auch wenn bspw. nur chrome geöffnet ist.
ich habe also gar nicht die volle cpu power zur verfügung. leider kann ich dazu keinerlei änderungen im uefi vornehmen.
gibt es da auch andere "tools"?
Müsste man ja am Boost-Takt sehen ob deine CPU nicht das bringt was ein 13900K bringen sollte. Cinebench R23 laufen lassen und mit hwinfo gucken wie der Takt und Punktzahl aussieht und mit Reviews vergleichen. Hab ich aber auch schon mal gehört, dass Fertig PCs die CPU drosseln in manchen Fällen. Denke da würde wahrscheinlich nur Mainboardtausch dann helfen, was aber auch so ein Ding ist bei den Fertig PCs. Da werden oft Spezialanfertigungen verwendet, damit man bloß nicht selbst dran basteln kann. Weiß nicht wie HP das heutzutage macht, kenne nur einige Reviews von Gamers Nexus auf Youtube z.B. Das sah schon manchmal echt übel aus.
neue newb these:
Welche CPU-Temp?
Linus hat den Pc ja sogar getestet:
Ist zwar ein älteres Modell noch mit 12900K aber der (und der RAM) ist tatsächlich von HP künstlich limitiert. Ist dann sehr wahrscheinlich auch beim neueren Modell so. Da hilft dann wirklich nur Mainboardtausch. Scheint aber zumindest ein Standard ATX Board und Netzteil zu sein.
Bleibt zu hoffen, dass das BIOS, der 4090 nicht noch irgendwie limitiert, da es wahrscheinlich auch von HP modifiziert wurde
das verwundert mich jetzt positiv, bei furmark geht es bis 450 in spitzen auch bis 460W hoch.
also wieso dümpelt die grafikkarte ingame bei rund 50+% gpu load und knapp unter 50% power consumption herum, wenn damit nicht konstant die 144 vsync fps gehalten werden können
und auch mit deaktiviertem vsync steigert sich die leistung nicht.
oder habe ich ein grundsätzliches verständnisproblem?
Die Anzeige von 450-460W reicht leider nicht aus...
Man müsste wissen, was wirklich über die Leitungen gezogen wird
Will damit sagen, dass man BIOSe so modifizieren kann, dass diese zwar in GPU-Z zb 600W anzeigen, aber real nur 400W gezogen werden
Oder umgekehrt, das zb 350W angezeigt werden, aber real mehr als 500W gezogen werden (wie in meinen Fall an der 3090 FTW3 Ultra)
Alles nicht so einfach, wenn man das Teil nicht selbst vor sich stehen hat
Hast du ein Leistungsmessgerät (für Steckdosen)?
das ist offenbar unabhängig von der temperatur, wir sprechen hier schon von situationen mit 45-50°. das thermal throttling ist in diesen momenten natürlich auf "no".
augenscheinlich macht es den anschein, als ob ab 1,4v core voltage das current/edp limit throttling eingreift. mehr wird wohl einfach nicht geliefert.
arghs, na da lag ich ja mit meiner letzten these gar nicht mal daneben. leider!
immerhin xmp lässt sich bei der aktuellen version aktivieren.
Finde sowas grenzt schon an Betrug, weil das auch nirgends angegeben wird und es dafür ja auch keinen thermischen Grund zu geben scheint bei dem Case. Man bezahlt eh schon mehr für den Prebuild und bekommt dann so hinterlistig auch noch weniger Performance als die Komponenten auf dem Papier versprechen.
Ähnliche Themen
Antworten
7K
Aufrufe
588K
