[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Scheiß auf Technikchecks, einfach CPU auf 10GHz übertakten und gib ihm.
Day1 Patch wirds schon regeln. EA hat ja in der Vergangenheit schon bewiesen das man in den letzten 2-3 Wochen vor Release alles fixen kann /s
Naja wenn die 4090 mit nur 50% Leistung zwischen 45 - < 60 FPS bei WQHD und maximalen Details schafft, spricht das eher weniger für ein angebliches Performance Problem. Nur die hohe VRam Auslastung ist erstaunlich. Das könnte aber auch sein dass das Spiel, wie manch andere, einfach nur den VRam volllädt.
Mal abwarten.
Mit Limiter sind solche Leistungsunterschiede nicht erstaunlich. Auch mit der Unreal 4 Engine etc. bewegt sich eine 4090 bei max. 60 FPS zwischen 150 - 430 W.
Ok Leute, was ist euer Trick um den Clip am pci-e Steckplatz zu lösen, wenn man zwischen CPU Kühler und Grafikkarte nicht mehr mit der Hand dazwischen kommt? :d
Einfach ein Lineal nehmen, ist stabil genug und aus Kunststoff. Da kann man nix kaputt machen wenn man mal abrutscht.
Mal abwarten.
Die 4090 läuft nur mit <50% Leistung, weil hier anscheinend ein CPU Bottleneck vorhanden ist und das ist natürlich ein massives Performance Problem, wenn das schon im Bereich 30-60 Fps mit einem 5900X passiert. Ich denke die Leute mit 13900K oder 7000X3D kriegen hier wahrscheinlich ein paar mehr Frames raus. Und es ist ja auch nicht das einzige Problem. UE4 typisches Stuttering ist natürlich auch wieder da.
HDR ist anscheinend auch kaputt. Echt ein top Release xD
einfach gnadenlos kaputtvoten. anders lernen die es nicht
Einfach mal nicht vorbestellen und bei Release kaufen. Das würde helfen. Wenn das Spiel in den "Regalen" verstaubt werden sie es merken.
Ist halt die Frage ob hier wirklich die CPU limitiert. Denn im Video war hier keine Kausalität mit der Welt zu erkennen. Ein CPU Limit würde man bei vielen Objekten erwarten. Nur im Video war das in einer leeren offenen Welt eher sehr sporadisch, auch waren mir hier die FPS zu unterschiedlich. Mal 45, mal über 60. Sah für mich nicht wie ein CPU Limit aus. In 4K und 720p wurde hier dann auch nicht getestet.
Einfach mal abwarten, von PCGH ist darüber noch nichts erschienen.
Gliedermaßstab Vorher vorne die Messing Verstärkung entfernen.
smartphonehülle, pfannenwender
Habe am 27.03. bestellt und der Adapter ist heute eingetrudelt, nachdem er 2 Wochen bei DPD in der Blackbox unterwegs war.
Fun fact: Das Seitenglas des Lian Li O11 Dynamic mit der Gigabyte Gaming OC geht auch mit / trotz Adapter nicht zu. Der Adapter baut einfach zu sehr auf. Geil..
Schade, dass es keine kürzeren Adapter gibt...
Bei einer ABP wären die Normalen ok
was hast du vor?:LOL:
Danke an Alle, paar gute Ideen dabei. Die Gefahr ist halt wenn man mit was spitzem abrutscht (sowas wie Schraubendreher oder das Noctua Ding). Vielleicht versuch ichs mal mit der Rückseite von nem Plastik Filzstift. Ich hab ka was so nen Board aushält wenn man da mal rein haut :d
Können wir die bei Kleinanzeigen zu einem angemessenem Preis kaufen ?
Ein Teil ist schon weg ... ein teil geht evtl. in den Marktplatz ...
War ne ganz "altbackene" Sammelbestellung mit ein paar Freunden.
Meine Bestellung vom 22.3. sollte laut Support heute versendet werden, bin mal gespannt :rolleyes2:
Ein paar sind jetzt im Markplatz zum EK ...
Sehe ich das richtig, außer ASUS bietet niemand zwei HDMI 2.1 Anschlüsse? Ich brauch unbedingt zwei weil mir für ein Vorhaben die DP 1.4 Bandbreite nicht reicht.
Das ist echt richtig ätzend o_O
Ich hab bei meiner Recherche grade auch noch weitere Nachteile entdeckt bei 4K Monitoren mit 144hz+ und Displayport. Wird DSC (notwendigerweise) verwendet, gibt es durch ein Bug bei nvidia beim Alt+Tab aus Spielen im Vollbild Modus ein ätzendes Blackscreen Delay.
Viel schlimmer sind die Farbverfälschungen, die man eventuell sehen kann.
Ich bin da ständig drüber gestolpert, und hab den alten DSC-Monitor deshalb nur mit 120hz betrieben, bevor ich ihn gegen einen 120hz Oled getauscht habe.
Hats einfach nicht gebracht. Hat man bei dem lahmen Display sowieso nicht gesehen ob da jetzt 120 oder 144hz anlagen.
Dann muss ich wohl wieder ASUS Karten selektieren. :ROFLMAO: Dabei ist meine FE ein Träumchen. o_O
Ich hoffe ja, dass dieses Jahr noch was im Bereich IPS, FALD, HDR + High Hz + G-Sync Modul released wird. Der Oled hat ein super Bild aber er kommt mir bei kompetititven Spielen zu langsam vor. Mal sehen :)
Oled ist für mich keine Option mit dem Pixel Layout. Primär zeige ich Texte an und die müssen knackscharf sein.
Wie jemand ein Oled als Hauptmonitor nutzen kann und daran auch surft/arbeitet etc. ist mir schleierhaft.
OLED ist ja nicht gleich OLED, es gibt meines Wissens nach derzeit drei unterschiedliche Pixelstrukturen auf dem Markt.
Aber ja, das Allheilmittel ist OLED auch nicht...
Ähnliche Themen
Antworten
7K
Aufrufe
588K
