[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Aber selbst 7200Mhz sind nicht das Ende der Fahnenstange. Denke mit mehr MHz hätte der Chart anders ausgesehen, aber dann hätte man nicht so ein Clickbait Video machen können, dass AMD nun der neue Gaming-King sei.
Hoffentlich, weil die ganzen Tests mit 6000Mhz einfach Tests mit angezogener Handbremse sind. Es schöpft das Potential der 13ten Gen. nicht gänzlich aus, schließlich liegt in dem hohen RAM-Takt ja eben die Stärke von Raptor Lake!
@Brandur
Oder ganz einfach...
Zwei Top-MBs mit jeweils den besten RAM-Modulen, dann OC, was 24/7-stabil ist
Meinetwegen noch "Perlen" (bester 7950X3D vs bester 13900K/S)
Selbst dann ist der 7950x3d in manchen Spielen viel schneller und ich manchen der 13900ks ;) das Ergebnis kommt auf die Spiele an /wer hat den längeren :)
Der wirkliche Star kommt meiner Meinung nach erst im April.
Mal was schöneres:
Hab das Problem aktuell im MSI Afterburner, das ich das Power Target nur auf 100% stellen kann. Ich konnte das vor nen paar Tagen noch deutlich höher stellen.
Hat hier das Problem auch mal und evtl. ne Lösung dafür?
Hab das Netzteilkabel nochmal neu eingesteckt (sowohl Karte als auch am Netzteil)
Hab das Problem identifiziert. Es war das Kabel, welches nicht richtig saß.
Hab nochmal alle Netzteilkabel abgemacht, weil mein PC ab und an geblackscreened ist (Sound lief weiter) mit dwe.exe error im event log. Google hat mir dann gesagt, dass es daran liegen kann, das die Kabel nicht sitzen und man mal am PC schütteln soll um zu sehen, ob er ausgeht. Hat er dann getan und hab dann alles neu verkabelt.
Dabei ist mir dann auch aufgefallen, das ich nen Leck hatte und mein Riserkabel das Netzteil geschützt hatte, da es das Wasser wo anders abfließen lassen hat. Puh ey, Glück gehabt das ich das im MSI AfterBurner hatte, hat mir echt den Arsch gerettet... auch das erste mal das ich n Leck mit Softtubes hatte. Jetzt ist wieder alles mit Zewa ausgelegt für n paar Tage.... :D
Für mich ist 4k Gaming bis 120fps relevant. Jetzt werkelt hier ein 5800x3D. Ein Upgrade auf Zen4 X3D würde vielleicht +5% Performance liefern und meist eh im V-Sync liegen. Kosten je nach Board/Ram zwischen 1000-1500€. Für mich als Upgrade uninteressant.
Auch bei den min. FPS würde ich wohl keinen Unterschied merken
Für mich ist 4k Gaming bis 120fps relevant. Jetzt werkelt hier ein 5800x3D. Ein Upgrade auf Zen4 X3D würde im vielleicht +5% Performance liefern und meist eh im V-Sync liegen. Kosten je nach Board/Ram zwischen 1000-1500€. Für mich als Upgrade uninteressant.
Seh ich auch so. Der 5800x3d langt erstmal komplett. In ein/zwei Generationen kann man vielleicht mal über Plattformwechsel nachdenken.
@Ben84 Ist ja bei CPU Upgrades meistens so, aber hier noch mal klar sichtbar. Ich denke mal solange die Playstation 5 noch aktuell ist, wird sich an den Game Engines auch nicht maßgeblich etwas verändern und man ist mit 8-Kernen gut unterwegs und kann auch sehr starkte Grafikkarten in 4k gut auslasten.
Wenn man alles neu kauft, könnte ein 7800x3D aber sicher interessant sein. Als Upgrade zum Vorgänger eher nicht.
Selbst vom Low end 🙂rolleyes:) 12700K brächte mir das gerade 5%. Wozu?
Ich denke auch dass ganz viele mit Alder Lake oder einem 5800X3D ganz entspannt bleiben können in 4k.
Die 4090 lässt sich durchaus ins Schwitzen bringen, wenn einige hier meinen die sei völlig überdimensioniert, ist das ein Witz. Im Gegenteil, für 4K Gaming ist sie die einzig sinnvolle Karte und aktuell einfach perfekt positioniert, wenn man einen 120 oder 144Hz Monitor hat.
Bis auf die Scheiss Zirperei bin ich einfach perfekt zufrieden mit meinem Setup momentan. Endlich. :)
Ja notwendig ist das Upgrade vermutlich eher nicht vom 5800X3D aus. Gibt aber doch schon einige Games, die zumindest in bestimmten Situationen arg CPU limitieren können. Da finde ich halt, diese Diagramme mit den average fps zeigen nicht immer das ganze Bild. Meistens treten CPU Bottlenecks ja nur in kurzen Situationen auf, wo die Frames dann mal ordentlichen fallen. Und da kann sich eine neue CPU dann schon deutlich mehr bemerkbar machen, als man bei der Angabe 5% mehr FPS im Durchschnitt denken würde.
Manche Tester machen auch eher unvorteilhafte Benchmarks. Z.B. bei Igor im Test: Da macht er einen Anno 1800 Test und will uns erzählen der 7950X macht 400FPS average in 720p 🤣 Der hat garantiert einfach ein neues Spiel gestartet, 3 Häuser gebaut und dann seine Messung gemacht oder den nichtssagenden Benchmark laufen lassen. Mit einem echtem Spielszenario hat das aber nichts zu tun.
Wenn er den anno test mit den anderen cpus vor Monaten so gemacht hat, muss er den Test mit dem 7950x3d exakt genauso machen.
Oder er muss alle cpus nochmal mit einem neuen Szenario testen.
Igor hat alle benches mit allen CPU‘s komplett neu gemacht . Sagte er gestern in seinem Video zum Test .
Anhang anzeigen 860613 Anhang anzeigen 860614
Danke für die Bilder. Das vermisse ich bei den Tests auf Hardwareluxx und Co immer. Praxisnahe Tests in vernünftigen Auflösungen. Jetzt ist auch mir klar das ein Wechsel auf den 7950 X3D (von meinen 5800 X3D) keinen Sinn macht.
Super bei den neuen schnellsten cpus 7950x3d ist der Verbrauch. Dann sind die Temperaturen im case der 4090 sicher noch besser bei nur fast 1/3 dem Verbrauch
Du hast dir im selben Test aber schon auch die Temperaturen angeschaut oder?
Die sind mit minimalen Unterschieden die selben wie auch beim normalen 7950X.
Nur durch weniger Verbrauch sind die Temperaturen nicht automatisch niedriger.
Will das Thema nicht länger weiter führen, nur noch ein Beispiel.
Gamers Nexus Shadow of the Tombraider medium 1080p Setting
7950x3d 382 Average fps / 185 fps lowest
Mein 12900k 354 Average fps / 216 fps lowest
Out of the Box ist der AMD schon sick aber wer die Zeit/Lust hat holt wahrscheinlich mit einem 13900k oc setup mehr raus allerdings nur mit mehr Energiekosten. Also Daumen hoch für AMD
Ja außer beim Netzteil
Interessanterweise meinte er, auf ein Z690er Board ausgewichen zu sein, denn mit den Z790ern hätte er beim 13900K ca 5% Leistungsverlust gehabt.
Bei dem engen Rennen durchaus relevant (bei den ganzen anderen Reviews).
Mir persönlich sind die AVG FPS komplett egal. Ich schaue nur noch auf die 1% Lows bzw. P1-Werte. Die müssen möglichst hoch und maximal nah an den Averages sein.
Mit auf Anschlag getuntem RAM auf einem 2-DIMM-Board wird man da mit einer Intel-CPU in den meisten Fällen sowieso besser dastehen. Nur sehe ich bei den Tests maximal mal DDR5-7200. Finde ich schon schade, wenn die Platform nicht ausgereizt wird. Scheint jedoch keine Sau zu interessieren, da wahrscheinlich komplett Nische.
Ich persönlich würde z.B. gerne mal Benchmarks in 20-30 Spielen (insbesondere neue Games mit Raytracing) mit solch einem System (DDR5-8800 mit scharfen Subtimings) im Vergleich zum Ryzen 7 7950X3D mit DDR5-6400 sehen:
Das wird wohl mit der 4090 besser harmonieren als mit jeder AMD-CPU.
Ich habe das neulich schon einmal im PCGH-Forum geschrieben. Ich wünsche mir genau das. Einmal gebencht komplett nach Herstellerspezifikation mit JEDEC RAM-Standard, damit es auf jeder Krücke läuft und einmal alles auf Anschlag mit gebinntem IMC und RAM auf 'nem 2-DIMM-Board. Das was Hardware Unboxed und Co. verzapfen ist doch Bullshit.
Da würde man auch endlich mal die Spannen hinsichtlich dessen, was auf der jeweiligen Platform eigentlich möglich ist, nachvollziehen können. Da wären sowohl "Faule" als auch Tuner bestens bedient. :)
Das verstehen Manche (auch das HWluxx-Team) irgendwie nicht und beharren steif und fest auf "ihren" (einzig wahren) 720p-Bench mit ungünstigen RAMs, die CPUs etwas einbremst
Wenn die dann noch patzig und persönlich werden, weiß man schnell, wie es um den Charakter bestimmt ist. K.A. was mit Manchen los ist... 🙄
zeig doch einfach Einsicht, dass du einfach mal nicht richtig liegst. zumal das hier der 4090 bereich ist.
im CPU bereich spammst du GPU limits
im GPU bereich kommst du mit cpu themen.
das sind 2 paar schuhe.
cb testet in 720p
luxx testet 720p
pcgh testet 720p
hub testest 1080p und hat sogar vor 2 wochen ein ausführliches video dazu gemacht
steve testet in 1080p
roman testet in 1080p
igor testet in 720 oder 1080p
etc... pp
du willst jetzt der king sein und den ganzen testern erklären sie wüssten nicht wie man den job macht?
wo ziehst du denn die grenze mit welchem ram man eine intel cpu bitte testet? 6000? 7000? 8000? 9000? lexi hat dir erklärt wieso das wenig sinn ergibt und dennoch beharrst du auf diesem käse.
wenn amds cpu hardwareseitig bei 6000mhz dichtmacht (IF) dann wäre das beste man testet die intel mit genau den gleichen ramsettings. denn dann kannst du genau sehen was die cpu isoliert leistet. und genau das ist der sinn und zweck eines CPU testes. RAM OC ergebnisse sind schön und können gerne als Zusatz mit gezeigt werden aber alleine ohne realistisch zu erreichende werte für den normalo eben nicht.
