[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Mach Mal bitte ein Video vom Zirpen, aber bei 120 fps hält sie die schnautze oder ?
Falls du mich meinst .... das bringt nix .. hatte ich aber damals schon gemacht is noch irgendwo im Coilwhine Thread zu finden ... einnmal mit der enfernung wie man normalerweise davon weg sitzt
und einmal von nahem man hört dannn im Video auch wie es lauter wird je näher ich an den PC gehe aber man zockt ja nich mit dem Ohr an der GPU :ROFLMAO:
Ansonsten findet man im Coilwhine Thread auch schon einen Ausführlichen Bericht zum fiepen meiner Karte ... hatte 13 oder sogar 15 Games getestet und nur bei Cyberpunk und bei 3D Mark hab ich fiepen
is für meine fast 41 Jahren und einem Abstand zum PC von etwa 80 cm aber absolut erträglich und nur hörbar wenn ich den Gamesound ausmache is mehr ein seichtes Surren
Aber klar wer nun auf absolut Silent aus is der hats dieser Tage schwer .. aber wenn ich halt Game dann laufen meine 7 x 140mm Lüfter auf so 1200 - 1500 Umdrehungen ich bin da nun nich sonderlich empfindlich
was lautstärke angeht
Ich schau mal ob ich mein Beitrag zum fiep verhalten meiner Karte im Coilwhine Thread noch finde
Karte : 4090 Strix :
bisher getestete Software ( 4K mit 117 FPS Cap ausser 3D Mark )
1. 3D Mark = Leichtes bis Mittleres Surren schwankt je nach Scene
2. Elex 2 = Nichts was ich mit meinen Ohren hören konnte
3. Spiderman mit Ray = Nichts was ich mit meinen Ohren höhren konnte
4. Cyberpunk mit Ray = Surren ähnlich dem von 3D Mark aber für mich nich stöhrend und geht größtenteils im Spielsound unter
5. Control mit Ray = Nichts was ich mit meinen Ohren höhren konnte
6. Quake 2 RTX = Nichts was ich mit meinen Ohren höhren konnte
7. Age of Empires 4 = beim normalen Spielen hört man nix nur wenn man ganz ganz schnell von oben nach unten die Karte scrollt mit den Pfeiltasten kommt ein leichtes Surren was man aber mit Game Sound nicht hört
8. Age of Empires 2 Def. Edition = Nichts was ich mit meinen Ohren höhren konnte
9. Golf With Your Friends = Nichts was ich mit meinen Ohren höhren konnte
10. Borderlands 3 = leichtes Surren .. wird weniger wenn man im Game in den Himmel schaut und dann noch nur 200 Watt anliegen .. stöhrt mich 0 is so seicht das der Game Sound das locker übertönnt.
Ab 230 Watt fängt das Surren bei Borderlands 3 an.
Was ich in der Zeit noch getestet hatte nachdem ich die Liste erstellt hatte ( die hatte ich damals gemacht als ich die Karte neu hatte also vor so 5 Wochen ) seit dem hab ich noch folgende Games getestet :
11. Witcher 3 mit Ray = seichtes surren nur hörbar wenn Game Sound aus
12. Spider-Man Miles Morales mit Ray = Nichts was ich mit meinen Ohren hören konnte
13. Portal RTX = nichts was ich mit meinen Ohren hören konnte
Zu finden dort :
Ne meinte Gurkengräber mit seinen Weißen Strix
Mit Galax Bios boostet die Karte auf 2790 ab und zumal sogar 2805mhz bei mir.
Alles auf Stock natürlich.
Gibt es irgend ne Seite, wo man Mediendateien zum direkten Abspielen hochladen kann? Also ohne dass man sich anmelden muss.
Ich nutzt immer Youtube dafür aber dafür muss man da natürlich angemeldet sein bzw bei Google .. mache ein Video mit meinem Handy und pack es auf den PC und lad es dann auf meinem Youtube Kanal hoch
und wenn es nur ne Sounnddatei is muss man da halt noch ein Bild dazu packen damit es als Video durchgeht
Hier mal das von meiner Strix da hatte ich noch den Ori Kühler drauf ... man sieht bzw hört da auch gut wie das surren erst hörbar is wenn ich mit dem Handy nah an der Karte bin aber so zockt man ja nich 8-)
Das Tuckern was man da noch hört is meine HDD Platte kann man auch gut als Masßstab der Surr Lautstärke meinner Strix nehmen
Möchte kein Youtube Konto (oder sonstwo :) ) machen. Hatte mal irgend so eine Seite gefunden, wo ichein Video hochladen und einen direkt Link zum Abspielen verschicken konnte. Eben wie bei Youtube nur ohne Konto. Finde die Seite aber nicht mehr.
Jedenfalls klingt Deine genau wie meine. "In echt" ist das halt noch 5x lauter, wenn man wie ich in einem Raum ohne Nebengeräusche an einem leisen Rechner zockt.
Bei meiner nich ... es is exakt so wie man es auch im Video hört .. nur ein seichtes Surren ... hatte da 3D Mark laufen
und man merkt da auch gut wie es leiser wird wenn ich mit dem Handy wieder weiter weg gehe bzw es lauter wird wenn ich näher drann bin
Also will hier niemandem zu nahe treten, aber ich glaube nun nicht mehr an Einhörner. Die Strix werden alle gleich klingen. Der Unterschied liegt allein im persönlichen Empfinden und was sonst noch so im Raum an Geräuschen vorhanden ist. Hatte es ja schon mal gesagt, ich freu mich (ehrlich) für jeden, für den das Geräusch kein Problem darstellt. Aber 4090 Strix zu binnen macht keinen Sinn. Alle zu 100% gleich.
Also will hier niemandem zu nahe treten, aber ich glaube nun nicht mehr an Einhörner.Die Strix werden alle gleich klingen."In echt" ist das halt noch 5x lauter
Wenn dem so währe würde meine HDD Platte auch extrem laut Tuckern tut sie aber nicht .. man hört meine HDD ja auch im hintergrund tuckern im Video und so ein HDD Tuckern is nun auch nich grade laut
daher kann man das HDD Tuckern im Video auch gut als Maßstab der lautstärke des Surrens meiner Strix nehmen
Hier nochmal das Video : ( Da läuft grad 3D Mark wo meine Karte am lautesten ist ... in den meisten Games ( liste hatte ich ja schon mehrmals gepostet ) ist sie aber leise .. hört da im Video auch auf das HDD tuckern )
Meine HDD sitzt da : ------------------------------------------------------------------- und so sieht die 4090 Strix in meinem PC nun aus :
Hab auch 0 binning gemacht .. einfach damals anfang Dezember die erste genommen die ich bekommen hatte für nen vernünftigen Preis für die damalige Zeit ( 2350 Euro )
... hatte auch bei der 3080 Strix damals ne gute sowohl beim Takt als auch bei der Lautstärke
Und wie gesagt und gezeigt meine 4090 Strix läuft mit Stock mit 2865 mhz bzw 2850 mhz und nicht mit 2700mhz und schafft max 3195 mhz core und +2000 bis +2040 mhz VRAM
.. muss halt einfach wohl ein gutes Asus GPU Händchen haben
Verrückt, dass die Strix so "schlecht" selektiert ist. Meine normalo inno3d boosted auf 2805Mhz.
Da kannst dann wohl 45MHz im Vergleich zu nem anderen Hersteller abziehen.
Meine 4090 Frostbite hat nämlich mit der INNO3D-FW 2850MHz und mit der KFA2-FW nur noch 2805MHz.
Den höchsten effektiven Boost den meine PNY mit Stock PL gemacht hat war 3045mhz. Jetzt läuft sie gemütlich mit 2730mhz @925mv und +500 MHz VRAM.
Wollte mir unbedingt die Suprim X holen, aber da hört man auch nur Negatives was Spulenfiepen betrifft.
Bin ich eigentlich der Einzige der sich einbildet dass das Spulenfiepen nach einiger Zeit besser geworden ist?
Keine Sorge, bist du nicht ;)
Meine Suprim X klang im Oktober auch noch haarsträubend. 48h Dauerlauf im MSI Kombustor konnten das aber für mich ins Erträgliche absenken und mittlerweile muss man schon richtig nah ran um es noch zu hören.
Deine Ohren sind nach einiger Zeit nur schlechter geworden xD
Ich glaube eher man gewöhnt sich einfach daran. Wie die Leute, die am Flughafen wohnen. Sie nehmen das nicht mehr so wahr, aber jeder Besuch kotzt dreifach ab.
So ist es auch mit den 4090, und darauf baue ich um ehrlich zu sein auch bei meiner Karte jetzt. :fresse:
Früher haben sich Karten auch immer noch eingebrannt (Furmark laufen lassen für 48 Stunden)
Aber bei den Temps die die 4090 Kühler mittlerweile produzieren bringt das wohl nichts mehr :d
Wow, das sowas möglich ist bei einer Strix. Meine macht 2850 Stock.
Meine erste Strix machte 2805MHz. Die beiden hier gehen schlechter, aber am Ende ist mir das wirklich egal, in Games macht das wenig bis gar keinen Unterschied. Nur halt schade dass wirklich alle identisch laut fiepen/rasseln.
Meine Game Rock Omni Black machte stock 2607 MHz da war ende
Natürlich hat man andere Ergebnisse mit einer anderen FW. Auslesen tue ich den Takt mit HWinFO und das sollte korrekt sein!
Ähnliche Themen
Antworten
7K
Aufrufe
586K
