[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Um den Leute die Kohle aus den Taschen zu ziehen. Komischerweise gab es im ASUS Store mehr OC Versionen als non OC :rolleyes:
Es gab aber einen User, der hatte die Hersteller allen Ernstes verteidigt, nachdem ich schrieb, dass es Täuschung ist:
Es gibt überhaupt keine Daseinsberechtigung für solche OC Modelle außer den Kunden zu melken.
Scheint jedenfalls so. Aber das mit dem Geld aus der Tasche kann zumindest bei Asus nicht stimmen, da sind die OC Versionen dieser Tage günstiger als die non OC. Bei PNY auch. :D
Wie bekomme ich nvidia-smi -lgc x,y in den Autostart :fresse:
Endlich mal was Sinnvolles hier nach fast 900 Seiten :o
kurz version mal schnell vorm schlafen gehen:
- bat Datei erstellen mit dem Inhalt (cd, Start und dem nötigen smi Zeug)
- Task schedualer neuen task
- start „when computer starts“ und WICHTIG „with highest privileges“
- wenn alles richtig ist muss man sein Windows password eingeben beim speichern.
Ich habe 4 bat Dateien; 1x Autostart und 3x mit Desktop Link für undervolting. Die desktop links müssen auch „als Admin ausführen“ in den Eigenschaften haben.
Gute Nacht.
Hallo. Mal eine Frage an die Profis hier. Ich hab gerade wieder Cyberpunk angefangen und merke, dass die 2080 Ti arg an die Grenzen kommt. Ich überlege daher eine 4090 zu kaufen. Ich zocke primär auf 3440x1440. Die Frage ist allerdings, ob ich meinen Unterbau (9900K mit DDR4 4000) behalten kann oder das wenig Sinn macht. Laut Anzeige in spielen (hier zB Cyberpunk) hänge ich im GPU Limit. Hab irgendwie wenig Lust alles auszutauschen.
Ya reicht: DLDSR 2,25x und in DLSS-Q + FG spielen. Gibt oft um die 100fps, top Bildqualität und GPU limit. 👍
Hatte eben beim Netflixen folgenden Bluescreen VIDEO_MEMORY_MANAGEMENT_INTERNAL.
Hatte das schon jemand und ist das besorgniseregend?
In PCGH 02/2023 steht im Artikel "Die richtige CPU für RTX 4090 und RTX4080" folgende Benchmarks:
RTX 4090 in UWQHD 3440x1440 native Cyperpunk (Ultra-Preset (ohne Raytracing)) min-fps 64, max-fps 86
Intel Core i9-9900K in 720p Cyperpunk, min-fps 59, max-fps 84,3
Bei den Ergebnissen bin ich der Meinung, dass bei nativer Darstellung in 3440x1440 der 9900K und eine 4090 ein noch recht harmonisches Gespann sind.
Sobald DLSS ins Spiel kommt, ist der 9900K überfordert.
Ich würde die CPU behalten, und bei einer 4090 einen Mix aus maximalen RT und DLSS-Q einstellen.
Nachricht gelöscht
Sieht sogar „einfacher/schlanker“ aus als meine Lösung… 👍
Jetzt noch das Icon auf „Nvidia“ umstellen, dann sieht es auch richtig professionell aus. Glaube das ist auch im System32 oder sonst im Programme\Nvidia Ordner drinnen.
Muss aber bei jedem Systemstart ausgeführt (Doppelklick) werden?
Oder geht das automatisch mit dem shell:startup?
Nachricht gelöscht
Das war ne Frage weil ich es nicht richtig verstanden hab. Steht sogar ein Fragezeichen am Satzende.
was macht ihr denn da mit bat datei und co :fresse: :d :)
aufgabenplanung starten, aufgabe erstellen. namen geben. unten "nur ausführen wenn benutzer angemeldet ist" aktiviert lassen. mit höchsten privilegien ausführen und ausgeblendet anhaken. weiter zum nächsten tab: neuen trigger erstellen. bei anmeldung auswählen, entweder jeden benutzer oder bestimmten nutzer wählen. hierdurch kommt am ende der erstellung eine passwortabfrage, bei fertigstellung. weiter zum nächsten tab: aktion neu erstellen. programm starten wählen, pfad zur exe mit durchsuchen auswählen und öffnen. jetzt das wichtige: bei argumente hinzufügen tragt ihr die optionen ein, die ihr haben möchtet, also zB "-lgc 1000,3000" für minimal 1ghz, max 3ghz takt. ggf. bei "starten in" nochmal den pfad zur exe eintragen. auf ok klicken. ggf. noch bedingungen anpassen im nächsten tab sowie einstellungen im übernächsten.
fertig. ganz ohne bat datei. 👍 die aufgabenplanung ist schon'ne feine sache.
Hogwarts Legacy scheint das nächste Spiel mit massiven performance Problemen auf dem PC zu sein :shot:
Day one braucht man echt nix mehr kaufen. Hoffe der versprochene Day1 Patch und ggf. Treiber update beheben das noch.
Wo bleibt der Drop :heul:
Auch gerade gelesen. Es ist einfach nur nervig was mittlerweile mit PC Games zu Release los ist. Denke mal ich weiche dann auf die PS5 Version aus
Ist es nicht eine Beta, wenn der Day One Patch fehlt :fresse2:
Doch, kann man schon so sehen. Die Gold Master Version ist oft 6 und mehr Wochen älter als der DayOne Patch. Und man sammelt alle Probleme des GoldMasters und fixt sie im Day One. Natürlich nicht immer perfekt, aber gerade der Unterschied zwischen dem Gold Master und dem Day One Patch ist oft massiv. Gerade auch auf den Konsolen.
Müssen die Reviewer halt auch ein Review zum Day One Patch nachschieben. Was sollen sie sonst machen? Haben das Game ja vorliegen und können es nur so testen, wie es eben vorliegt. Und freiwillig auf Clicks für ein Review verzichtet keiner, davon leben sie nun mal.
Also wenn kann man hier nur dem Publisher einen Vorwurf machen, sicherlich nicht den Testern.
Same here!, hab sie unter Wasser gesetzt, kein Zirpen oder ähnlich, einfach geiles Kärtchen, wie empfindest Du die Lüfter ?
Bei mir genau so, absolut leise.
Die Lüfter machen nur kurz ein "Anlauf" Geräusch, aber dann laufen sie auf 30% was ja ca 1100rpm sind. Ich empfinde sie als seehr leise.
Ich bin echt mega glücklich mit der Karte.
Ich lasse sie mit 80% PT laufen was 350W~ sind, und Leistung ist da gut gleich. (Hätte Nvidia gleich so Launchen sollen)
Wird bei dir das 16Pin auch so warm/heiß unter Last?
Also laut Infrarot Thermo ist es zwar "nur" 40-43°C, aber es fühlt sich halt mehr an. :D (Auch an der Glasscheibe)
Also laut Infrarot Thermo ist es zwar "nur" 40-43°C, aber es fühlt sich halt mehr an. :d (Auch an der Glasscheibe)
Du musst bedenken, das Kabel ist an einer extrem beschissenen Position, Hitze von der GPU wird da unter anderem voll dran gepustet.
Ja, da hatte ich anfangs nicht dran gedacht, da die Karte seitlich auch echt gut Hitze raus bläst.
Das wärmt zusätzlich zu der Leistungsaufnahme am Kabel mit auf.
Ist nur etwas "ungewohnt", da mit der 3080Ti sowas ja nicht war mit 3x8Pin. :D
Das weiß man nie. Aber eine Betaversion testet man nicht. Punkt.
Das ist ne review Version die der Hersteller zur Verfügung stellt, gefühlt mag das Beta sein, offiziell ja wohl kaum.
Zählt das auch für die User hier im Thread? Ne 4090 wird doch problemlos mit dem Teil fertig. Hab auf PCGH eben was von über 100FPS für die 4090 gelesen.
Was bringen über 100fps wenn man Stuttering des Todes hat? Kennt man doch von aktuellen Releases...
