[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ja. Vom Stecker an sollen 3-4cm Kabel grade weg gehen und danach kannst du ruhig 90Grad runter knicken
Bekomme es nur so hin. Man ist das Panne ey.
Zu blöd das ich für das O11 Dynamic gerade keine Vertikale Halterung bekomme.
Es wird früher oder später ja auch 90° Adapter geben. Einer ist sogar schon lieferbar, aber nur diese blöde Version mit 12VHPWR auf 4x PCI. Cablemod sollte auch irgendwann im Februar zumindest bestellbar sein laut deren Roadmap. Würde solange einfach die Seitenwand auflassen bis du ne bessere Lösung hast bevor du das Kabel zu kurz biegst.
Ja hab ich mir auch so gedacht das ich die Seitenwand erstmal weg lasse. Allerdings sagt be quiet wenn ein Adapter dazwischen ist und was passiert gibt's keine Garantie.
Das sollen sie dir erstmal nachweisen, dass da ein Adapter dazwischen war :d Es ist auch egal welches Kabel oder Adapter man da verwendet, jeder kann anschmoren wenn er nicht richtig eingesteckt ist, darauf muss man einfach peinlichst achten.
Hab ne 4090 Strix und das Be Quiet Kabel…einfach:
Abstecken!!! und dann…
Mit der einen Hand hinter dem Stecker auf die Kabel fassen und dann mit der anderen Hand biegen auf 90 grad.
Danach Pins im Stecker kontrollieren ob „verschoben“ oder „reingezogen“.
Ohne Gewähr, aber geht und hat auch 600+ Watt überlebt.
Ne also das ist mir echt zu gefährlich. Da bin ich ein Schisser :fresse:
Könnte genau so breit sein.
Naja, wenn Du damit aussagen willst, dass es riskant ist, das Kabel zu biegen: Nein, ist es nicht wirklich, wenn es richtig steckt. Die frühen Ursachenforschungen, auch die von Igor, sind bei ihren Tests einfach nie auf die Idee gekommen, dass der Stecker nicht ganz eingesteckt gewesen sein könnte. KEINER konnte bisher ein Problem provozieren, der alleine durchs Biegen bei vollständig eingestecktem Stecker entstanden wäre.
Naja es gibt Leute die Biegen so
und Leute die Biegen so.
Beim 2 ten ist davon auszugehen (Mechanische Belastung auf den Pins)
Letzteres ist dann wohl in dem oben gezeigten Gehäuse notwendig. :fresse:
Und Anpressdruck...
Naja für eine AIO kühlt die recht ordentlich und ist unhörbar. Die Lüfter drehen jedoch im Idle bei 250rpm und unter Last nie höher als 1100rpm (max. sind 2000rmp möglich), daher werde ich schauen, ob ich da nicht ein paar Noctuas draufschnalle, die dann die Abwärme aus dem Radi schneller abtransportieren.
Ich konnte meine 4090 problemlos in mein O11 Dynamic einbauen, keine Ahnung wo das problem ist :d
Naja es gibt Leute die Biegen so Anhang anzeigen 850383 und Leute die Biegen so. Anhang anzeigen 850384
Klar ist die Belastung dann höher, aber niemand hat es geschafft mit einem solchen Aufbau deutlich erhöhte Temperaturen zu erreichen. Selbst mit nur je EINEM pin jeweils für 12V und Ground, der ganz steckt, hat man nennenswert erhöhte Temperaturen.
Die bekommt man wirklich erst dann, wenn nur noch Bruchteile von mm² Kontaktoberfläche vorhanden sind, und das passiert eben genau dann, wenn der Stecker nur noch gerade so eben Kontakt hat.
Hier gibts den Testaufbau wo man auch sieht wie knapp der Stecker nur Kontakt haben darf bis es brennt:
Welche 4090 gibt es eigentlich mit fertig montierten Cover? Aktuell ist mir nur die Inno3D iChill Frostbite bekannt, welche gibt es denn noch? Es gibt einige Cover wohl in der Pipeline, aber wegen Garantie etc. wäre ein vormontiertes Cover eher etwas für mich. Von Gigabyte hatte ich vor langer Zeit mal Gerüchte gehört, aber die haben nur die 4080 mit Cover rausgebracht, die 4090er Version ist ja die typische AIO-GraKa.
Ähnliche Themen
