[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Steht und fällt m. E. mit der Erkennung ob die Sense Pins des 12VHPWR-Steckers 600W melden. Wie hast du deine Karte denn angeschlossen? Bei Verwendung des beigelegten Adapters müssen z. B. alle 4 Stränge angeschlossen werden, bei nur 3 Stk. wären 450 Watt die Obergrenze.
Habe die FE nun eingebaut. Alles wie zu erwarten. Leider.
Die 30% Mindestdrehzahl gehen ja schon gar nicht eigentlich. Wie unnötig laut das ist. Die 3090 FE ist um einiges leiser.
Der knick ist völlig wumpe hab meine auch schon bei 2 cm geknickt siehe Bild im Anhang und null Probleme, wichtig ist dass der adapter komplett einrastet, alles andere ist Panikmache. Ich hab das kabel vor dem einstecken gebogen, geschaut ob alle stifte noch richtig sind und dann in die Karte gesteckt so dass es voll eingerastet ist . Läuft so seit 2 Monaten ohne irgendein Problem
Ähnlich würde ich es auch handhaben habe schon das CableMod Pro ModMesh.
Also die FE mit den 1100rpm Mindestdrehzahl. Mir geht das Teil nach nur wenigen Stunden schon gehörig auf die Nerven. FE = Fail Edition.
EDIT: Konnte man die über den AB weiter reduzieren? Man verliert dann nur fan off oder wie war das?
Gestern mit meinem Bruder Sniper Elite 5 im Coop gezockt da viel mir am Ende der Mission auf das das Spiel die vollen 24 GB der 4090 belegt hat hab ich bisher so noch nicht gesehen.
Bei meinem Bruder waren mit der 4080 in WQHD die 16Gb auch fast voll belegt.
Hätte ich jetzt so nicht erwartet bei dem Game.
Die Founders läuft bisher echt super .
OC hab ich bisher noch nicht gemacht sehe da aktuell noch kein Bedarf.
Der 7700X passt bis auf ein Paar ausnahmen ganz gut zu 4090 mit dem X3D sollte das später dann aber auch dort passen.
Grüße an alle.
wenn du kein anderes Bios draufflashst, nicht.
FE Bios lockt die 1100 rpm als Mindestdrehzahl. Ist dir das zu laut, geh auf Wasser oder Custom.
30% sind Minimum.
Kann es nicht auch einfach sein, dass die Lüfter erst bei 30% zuverlässig laufen? Das könnte ein Grund sein, dass NVidia das so im BIOS voreingestellt hat.
Ich hatte ja auch ein paar Wochen die FE mit Lüfter verbaut, mir kam sie nicht so laut vor - und ich habe auch noch einen offenen Systemaufbau. Wenn man im Idle ist, gehen die Lüfter doch eh aus. Und wenn man zockt - nun dann sind die Lüfter doch das letzte was ich höre. In den Vergleichtstests ist die FE doch Kühler- und Lautstärkenmäßig eher immer positiv aufgefallen? Deswegen kann ich das jetzt nicht so ganz nachvollziehen.
Brauchst Du ja auch nicht. Wie schon hundert mal festgestellt, kommt es auch immer auf das persönliche Empfinden an.
Die FE Lüfter (bzw. der zweite) sind eine absolute Katastrophe und völlig inakzeptabel. Und das selbst im geschlossenen Gehäuse unter dem Tisch.
Entscheidet am Ende des Tages aber am besten einfach jeder für sich selbst. ;)
Also ich fang damit jetzt nicht schon wieder an. Vielleicht mag ein anderer.
Im time spy extreme im Notebook area51m mit spezieller alienware egpu schafft die 4090 ventus nur 19000 Punkte im ts extreme
Also Notebook mit RTX 3070 oder so.
Kann es sein, dass ich ein auf 450 W gelocktes vBIOS habe?
So umständlich.. mach GPU-Z auf und guck da einfach unter "BIOS". 🤣
Wenns dich stört, nimm dir 2 Minuten Zeit, flash ein anderes Bios und freu dich. Du kannst da nämlich nichts falsch machen, jede 4090 hat nen Dual Bios! Woah!
In einem offenen Aufbau sollen die 30% der FE nicht stören? :oops:
Meine hat ein sonores Geräusch, der hintere Lüfter ist lauter und von der Charakteristik brummiger, aber wenn ich den anhalte, ist der vordere auch noch zu laut. Selbst mit Kopfhörern und Musik hör ich das noch. Einfach unnötig nervig. Ich kann nur allen raten die empfindlicher sind, Finger weg von der Karte.
Die Gamerock sieht aus wie eine Kirmesbude und wirkt viel billiger, wischt mit der FE aber Hinsichtlich Lautstärke komplett den Boden auf (nicht nur bez. Lüfter ;) ).
Notebook mit 9900k und 2080. Area51m
An alle 4090 FE Besitzer hab hier eine 4090 zum testen..aber die Lüfter schalten sich im Idle nicht aus sollte ja nicht so sein oder?
Im idle sind die aus. Allerdings dauerte es auch bei meiner FE etwas, bis die nach einem Lastszenario wieder auf 0 waren. Bei der Strix ging das wesentlich schneller. Also der FE Kühler braucht wahrscheinlich etwas länger, die Wärme abzutransportieren.
Kenne aber die Temperaturgrenze nicht, wann der Zero Fan Mode greift. Wenn Du in ner Sauna idlest, laufen sich die Lüfter tot. ;)
Sie schalten sich aus bei ca 33°C GPU temp. GPU wärmt sich dann auf auf ca 55°C, dann schalten die Lüfter ein. Usw.
@Zw3nn0r
Du warst doch an der Qualität des EKWB Kühler intressiert?
Gestern habe ich die Karte umgebaut, wofür noch warten, hab ich mir gedacht.
Der Kühler ist für meinen Geschmack wunderbar verarbeitet, der Umbau wäre "eigentlich" problemlos gewesen, wenn man denn die Anleitung aufmerksam gelesen hätte... :unsure:
Es gibt Thermal Pads in 2 Stärken, 1mm und 2mm, und was glaubst du, welcher Blödmann das nicht gecheckt hat, und dann die Hälfte wieder neu machen musste?
:d
Zum Glück war der ausreichend dabei!
Weiterhin war Thermal Grizzly WLP dabei, auch ausreichen, denn ich musste ja den Kühler dank der Pads die ich verwechselt habe, ein zweites mal reinigen und neu mit WLP versehen.
Das einzige das ich wirklich kritisiere:
Wenn man die Backplatte abschraubt, fallen dir alle Abstandshalter raus, und für meinen Geschmack war es eine riesen Fummelei, die dann später wieder nutzen zu können.
Einen habe ich gleich gar nicht mehr gefunden, aber das ist nicht so tragisch, ich habe in da weggelassen, wo die Backplatte am GraKa Halter anliegt.
Beim Aufräumen später habe ich ihn natürlich gefunden, trotz vorheriger erfolgloser Suche :d
Die Temps sind Top, ich habe einen MO-RA3 extern, unter Luft waren es um die 65 Grad, nun bewege ich mich um die 46/47 Grad, hab aber noch eine fette Luftblase in der GraKa, die einfach nicht verschwinden will.
Alles in allem bin ich absolut zufrieden!
Hab mir jetzt noch einen GraKa Halter bestellt, so eine Stütze, das die Gurke dann auch mal gerade Hängt :)
Soll morgen schon kommen, dann mach ich ein Foto, bei Bedarf.
Ich habe jetzt die Suprim X und die Gigabyte Gaming OC noch ausprobiert, und denke die FE bleibt wohl.
Die Gigabyte fiept auch, mehr oder weniger so viel/wenig wie die FE ist im Quiet BIOS mit Default Fan Curve bei ca. 1400 RPM auch nicht leiser als die FE... Wenn ich die Lüfter der Gigabyte dann auf ca 1000-1100 RPM Drossel, dann ist sie leiser als die FE, die Software (ich weiß nicht der genauste Wert) zeigt mit gleichen UV Settings (0.9V 2610MHz) ca 30W höheren Verbrauch als bei der FE und Suprim an und ist in RE2 Remake bei 340W (FE und Suprim 310W in der gleichen Szene) bei 70 Grad core und 80 Grad Hotspot, die FE liegt da nach einer Weile bei 62 Grad Core und 72 Grad Hotspot mit Lüftern auf 30% gepinnt. Beim anlaufen klingen die Lüfter der Gigabyte manchmal nicht ganz "sauber" und ein "Vogelgezwitscher" Geräusch machen sie auch ab und zu :d
Die Suprim fiept einfach deutlich mehr die Lüfter sind aber toll, aber für den Aufpreis gebe ich mir das fiepkonzert nicht :)
War hier nicht jemand, der meinte, der Kühlblock von EK habe nur unzureichend Kontakt zur GPU und den anderen Komponenten?
Eventuell ist dem dasselbe passiert wie mir, und er hat die Thermalpads vertauscht?
Hab jetzt mal Rage2 getestet, alles auf Ultra, durchgend 165FPS, Temp liegt bei 37Grad, Hotspot waren glaube ich 42 Grad.
Denke schon, dass das passt :)
Mag gerade FC6 testen, muss ich allerdings neu installieren.
100% ausschließen kann man das nicht. Genau deswegen habe ich mir neue Pads besorgt. Aber ich hab erst mal keine Lust alles wieder zu demontieren. Irgendwann mal, aber nicht gerade jetzt.
Es kann auch einfach sein, dass es Schwankungen in der Produktionsqualität gibt. Sowohl vom Heatspreader als auch vom Kühler.
Ähnliche Themen
Antworten
7K
Aufrufe
434K
