[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@klasse08-15: alles, gut - ich hätte nach meinem bisherigen Eindruck von inno3d noch die Hoffnung, dass die sich vielleicht gar nicht so anstellen, wie sie sich vielleicht anstellen dürften. Ist ja auch bei vielen anderen Herstellern so, dass es dann doch nicht so heiß gegessen wie gekocht wird. :) So'n Siegel ist halt misslich. Aber mich würde jetzt doch mal interessieren, ob Du den Block nicht vielleicht doch "auf" bekommst, ohne das Siegel zu brechen? Und im Zweifel echt: sch*** drauf. :d
Die Schrauben vorn gehen sicher auf Und das Acryl damit ab. Die Frage ist nur, geht es auch ohne viel Kraft wieder zu? Bei meinem Aquacomputer hat die Dichtung und die kurzen Schrauben das nicht so einfach zugelassen. Man brauchte viel Kraft.
Es gab Berichte das manche auch erst gar keines hatten und besonders gut ist die Position auch nicht gewählt. Es wäre sicherer für den Hersteller gewesen es über einer Schraube anzubringen.
Ich bin auch echt doof. Hätte ich es abgerissen und den Support gefragt, warum ich kein Siegel habe und ob das ein Mangel wäre, hätte ich wohl auch so eine „Freigabe“ bekommen. :fresse:
Ohne es vertiefen zu wollen, dafür haben wir ja ein eigenes Sub:
2019 hab ich meinen aktuellen PC aufgebaut.
DP Ultra clear, das war nun 4 Jahre im System, und kam glasklar heraus, als ich gestern Wasser gelassen habe :)
Ob sich allein auf den Umstand eines fehlenden Siegels die Verweigerung von Garantieleistungen stützen lassen, halte ich ebenfalls für zweifelhaft.
Zumal muss man auch noch beweisen dass die Karte mit einem Siegel ab Werk ausgeliefert worden ist und das dürfte ziemlich unmöglich sein, da es eben wohl keinen aufgezeichneten Nachweis (Bild/Video-Material) für jede einzelne Karte vorliegen dürfte. Und wie gesagt, es ist technisch nicht ausgeschlossen das sich das Siegel wie es positioniert wurden ist, sich nicht selbst ablösen bzw. bei einer leichten Kollision abgestreift werden kann.
Vielleicht schlecht für denjenigen dem das nicht nennenswerte eine Jahr der Garantie wichtig sein sollte. Ansonsten eher irrelevant.
Ja, das macht DP-Ultra toll. Problem ist nur, es klebt an Oberflächen und schliert. Das zeig selbst bleibt klar
Kann ich nicht bestätigen.
Alter GraKa Kühler sieht aus wie frisch aus der Verpackung :)
6 Jahre DP Ultra klar mit epdm Schlauch verwendet . Jeweils 3 Jahre drinne gelassen das Wasser . Alles sauber und keine Rückstände und auch der CPU Kühler aufgeschraubt und alles sauber gewesen .
Radiatoren müssen alle vorher gereinigt werden und der richtige Schlauch kann auch entscheidend sein . Ek ZMT, noprene oder WC EPDM eignen sich gut für längeren Einsatz .
Ich hab das auch nur auf der Distroplate. Das könnte an der Oberfläche des Acryls liegen. In den Tubes und im Aquacomputer-Block hab ich auch nichts. Ich vermute aber, es liegt auch daran, dass in der Distro halt auch Luft steht. Überall wo DP-Ultra voll fließt Ist alles prima.
Also wer noch nen schnapper machen möchte:
bei galaxus gibts grad 10% cashback über shoop.
Die Gigabyte 4090 OC ist für 1919€ drin - 162€ cashback (die 10% gibts auf den netto wert) - 20€ gigabyte cashback = 1737€. (Strix für 2311 ist ebenfalls verfügbar)
Cashback Tracking scheint direkt zu klappen, habe mir dort selbst grad nen MB gekauft.
Kann man da mit Kreditkarte bezahlen? Würde nochmal 2,5% Cashback über meine Amazon Visa zusätzlich geben :d
So oft wie Cashback bei Galaxus aber den Kommentaren nach wahllos abgelehnt wird. Tracking ist das eine, aber durch die 100 Tage Rückgabegarantie wird das frühestens danach erst freigegeben und wohl oft wahllos gecancelt, siehe Krokos. Also ich würde das nicht FEST in die Kaufentscheidung mit einbeziehen :/
Danke, war mir nicht bekannt :bigok: . Für Hohe Beträge scheinbar öfter der Fall.
LoL, bei Shoop steht "bitte beachte dass die Prüfung 4-5 Monate dauern kann".
Nee is klar. Wer wegen sowas da kauft, hat die Kontrolle über sein Leben verloren. :fresse:
das darf keine woche dauern. ok in deutschland 2 wegen FAG aber danach muss die kohle aufm konto sein sonst fliegen die fetzen
Da fliegt gar nichts, lies Dich da gerne ein bisschen ein. Die meisten geben auf und die paar übrigen hören nichts mehr außer "sie haben die Cookies nicht akzeptiert". Habe da selber noch nicht bestellt, mich allerdings wegen der Strix ein wenig eingelesen. Nein Danke.
Vielen Dank, dann ist da echt noch "Luft" im O11 Dynamic Evo von LianLi der "nur" 167mm Höhe angibt. So sollten 3-4cm bis zur Seitenwand drin sein um das Powerkabel ohne viel "Knick" nach unten zu verlegen.
Wieso wird noch mal der Teil mit dem "Knick" genannt ?
Der knick ist völlig wumpe hab meine auch schon bei 2 cm geknickt siehe Bild im Anhang und null Probleme, wichtig ist dass der adapter komplett einrastet, alles andere ist Panikmache. Ich hab das kabel vor dem einstecken gebogen, geschaut ob alle stifte noch richtig sind und dann in die Karte gesteckt so dass es voll eingerastet ist . Läuft so seit 2 Monaten ohne irgendein Problem
Wie ist denn so die AStandardpunktzahl im TimeSpy für ne 4090 out of the box?
Und falls doch übernimmst du die Gewährleistung ;)
Ist er nicht und wird er nicht. Insofern muss er da keine Gewährleistung übernehmen. ;)
Und wenn man sich zu blöd anstellt war das schon immer ein Problem für die Chance auf Ersatz. :d
Denke auch es sollte besser sein als 32k oder…… meine 4080 Frostbite macht out oft the box 29k
