[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Besorg dir am besten noch ein natives Kabel von deinem NT Hersteller . Den komischen Adapter muss man sich echt nicht antuen.
Gibts das Kabel von Seasonic aktuell irgendwo zu kaufen? Bei Alternate hatte ich es verpasst und jetzt kann man nicht mehr bestellen.
Ich hab grds das Kabel von Be quiet, allerdings hab ich wenig Lust, dies anzubringen. Auf welchem Watt bios ist die 4090 Standardtmäßig eingestellt? Ich hatte mein gutes 750w Netzteil bis jetzt immer mit nur drei Kabeln des Adapters angeschlossen an andere Karten. Wenn ich den von Be Quiet nehme hab ich Angst, dass dies meinem Betzteil nicht so gefallen könnte weil die Karte direkt 600w zieht
Die Kürzeren PCIe Kontakte aif dem PCB sind 'Sicherheits' Kontakte die erst Kontakt geben wenn die GPU tief genug im Slot sitzt.
Dadurch 'startet' die GPU erst wenn auch wirklich alle Singnalleitungen verbunden sind.
Das selbe wird ja jetzt auch beim 12vhpwr Stecker geändert das da auch die Sense Pins gekürzt werden so muß man den Stecker halt tiefer einstecken damit die GPU läuft.
450 Watt in der Regel . Die Karte zieht keine 600 Watt , wenn du das Kabel anschließt .
Kann bis 600 Watt durchgeben . Ob das dein NT bereitstellen kann ist dann eine andere Frage . Dagegen kommt es darauf an wie hoch das PL bei der Karte eingestellt ist und @ Stock sind das 450 Watt bei fast allen Modellen .
wenn du in der Nähe von Südhessen wohnst kannst du dir ein seasonic cablemod bei mir abholen. :d
joa einwandfrei. nachdem man halt das falsche getauscht hat :) das erste was ich bekam war eine falschlieferung. hab ein evga bekommen.
dann 2x neue seasonics per fedex express :d
Hast du mal nen Link zu dem richtigen Kabel? Bin zu doof es im Shop zu finden, sehe nur welche die auf 2x bzw. 3x 8pin gehen. Das Ding müsste doch dann nur zwei Stecker haben, einen fürs Netzteil und einen für den 12Vhpwr an der Graka?
Ich glaub ich steh aufm Schlauch, sollte das Kabel nicht eher so aussehen:
Also 2x8Pin (Netzteil) auf 12Pin für die Graka?
das ist das seasonic official kabel
cablemod macht eigene
Herpes hat die FE geliefert. Ich hab sie direkt ausgepackt. Leider ist beim Stromadapter keine Halterung angebracht. Die scheint irgendwo in der Produktion gebrochen zu sein. Zudem frage ich mich, ob an dem pcie Anschluss, oder wie das Ding auch immer heist, etwas fehlt…
sieht aber generell nach bereits 1x verbaut aus => spuren an den pci-e kontakten. lässt die vermutung rückläufer zu, der halteclip am kabel ist halt abgebrochen worden. sowas passiert ja nicht in der box aus spaß an der freude. was aber, wenn die karte sonst funktioniert, kein thema ist, garantie etc. gibt's ja trotzdem.
Klinke mich auch mal mit ein, weil es hier kurz um die Adapter geht!
Was kann man den hierfür nehmen?
Von dem Hersteller direkt gibt es kein Adapter.
fertige wirds von CM keine geben. maximal eins konfigurieren was klar teurer ist und vermutlich lange dauert.
da werden wohl extensions die schnelle lösung sein
Auf Custom PSU Cables, dann Marke und Modell deines PSU auswählen und dann auswählen, was du so haben willst.
Hab da auch eins für das ION+ 2 860W als Mesh Variante, die Flex Variante ist halt etwas biegsamer, wenns eng ist bei Dir
Oder einfach hier die Kabel bestellen, habe ich auch gerade für mein Seasonic Fokus gemacht.
Gerade erst gecheckt, die ist ja gar nicht verfügbar. Das wurde etwas seltsam von Chrome übersetzt.
Da kannste auch auf Englisch im Shop switchen, dann brauchst Du nicht die planlose Google Übersetzung :d
Falls Dir Fiep- & Rasselfrei wichtig ist (die 4090er machen teils ganz schön Radau), dann würde ich Dir die Zotac Amp Airo empfehlen. Meine beiden sind auch unter Wasser schön ruhig bis unhörbar.
Ich schätze noch 2-3 Wochen warten, dann gibt es die auch knapp über 2K - sind zuletzt in DE nur noch im Preis runtergegangen. Wobei die 2179 € bei LDLC für aktuell schon gut sind - und ist lieferbar :d
Irgendwie war ich wohl auch dafür zu zu dumm, hab nur Französisch und Italienisch gesehen :d
Ich bestelle jetzt die "günstige" Zotac für 1999€, da eh auf Wasser umgebaut wird ist mir der ganze andere krams wurscht. Spulenfiepen ist ja eh immer ein Glücksspiel aber ich probiere sie eh erstmal aus bevor ich umbaue.
@Tundor
Zum Glück muss der Graka-Akustikterror eben Dank @scars kein Glücksspiel sein, bzw. kann man sein Glück zumindest stark beeinflussen 😁
Kennste den Thread, bzw. die Tabelle?
12 Pin Micro-Fit to 2x8 Pin PCI-E for NVIDIA 3000 FE Series (NOT 3090 Ti) (GPU) Ist das so richtig?
Brauche doch ein 16 Pin?! kann aber nur das auswählen.
moin; gibt's ggf. schon jemanden, der eine manli 4090 gallardo umgeflashed hat...? falls, welches bios kann man dort nehmen? ansonsten würde ich mich mal an der zotac trinity orientieren, die ja das selbe layout hat. in der hoffnung, dazu etwas zu finden :fresse2:
das hatte ich im visier, die versionen sind allerdings unterschiedlich, ansonsten deckt sich alles. allerdings hat die ja komplett andere vrm ausstattung, da bin ich mir auch bissle unsicher. zumal die manli kein dualbios hat.
Das hab ich mir auch schon gedacht, als ich mir das angeschaut habe. Kabel scheint aber nicht geknickt worden zu sein. Ich werde die Karte mal auf ihre Geräuschentwicklung testen und ansonsten auf eine Neulieferung bestehen.
Edit: Sowohl die Versandverpackung als auch die der FE waren aber versiegelt. Die Verpackung hatte aber einen Stempel aus dem November 2022. war das bei den anderen diesen Drop genau so?
Boah ist Hermes ein Saftladen.
Der Fahrer hat mich einmal verpasst und schaffte es nun schon drei Mal nicht vorbeizukommen, obwohl es angekündigt war. Hab 2x umsonst Stunden gewartet und wäre normalerweise weg gewesen. Frauchen ist gestern alleine los und ich hab hier gecampt. Nun dachte ich das käme dann heute (stand da gestern noch), ne, wurde nun heute morgen einfach auf Montag verschoben? (y)
Gerade noch mal refresht, jetzt steht da nur noch "bald":
Die Lieferung deiner Sendung verzögert sich, bald geht’s weiter!
Ähnliche Themen
