[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Kann das einer empfehlen hat da schon eine Erfahrung mit gemacht.?
Lg
Fasgear PCIe 5.0 GPU Stromkabel ummantelt 70cm | 16pin (12 + 4) 12VHPWR Anschluss für RTX 3090 Ti 4080 4090 | 3x8pin (4+4) CPU-Stecker nur für Corsair / Great Wall / Thermaltake modulares Netzteil https://amzn.eu/d/d7dPlSa
Also ich habe das Kabel dran und habe nichts zu bemängeln einwandfrei und klare Kauf Empfehlung von mir !!
@pajonk
Grüße dich erstmal .
Eine Sache mit der Latenz bin ich mir nicht sicher ob ich die auf Ultra hatte!
Sobald ich halt Vsync global aktiviert habe im Treiber im Spiel na klar aus kam ich nicht mehr auf die 120HZ wohl 135 -180 z.b gehen mit Frame Generation.
In dem Video zeigst du ja auch das mit dem Afterburner die FPS nicht mehr passen das hat bei Darktide einen sehr schlechten Bildablauf zu Folge auch dort könnte ich über Vsync die FPS nicht auf 120 festmachen.
Obwohl nahe zu alles wie in deinem Vid konfiguriert nur bei der Latenz bin ich mir nicht mehr sicher.
Da meine Karte noch auf Retoure unterwegs ist kann ich das jetzt erstmal nicht gegen testen.
So bald ich wieder eine Karte habe Werd ich deine Tips noch Mal durch gehen !
Grüße
Ach so ein Abo hast du ja schon länger von mir mach weiter so !
Alles Familienvater finde ich meist keine Zeit um großartig rum zu Doktern am Rechner da kommen solche Hilfe Stellungen immer gut.
@pajonk
Die Latenz auf Ultra funktioniert nur bei Dx9-Dx11. bei DX12 hat sie keine Auswirkung.
Verstehe nicht was Du meinst?
Wenn Du über deine reefreshrate kommst ist Vsync auch nicht aktiv. Es gibt laut usern wohl spiele welche die NVCP VSYNC ignorieren und es im Spiel aktiviert haben wollen. Ich habe so ein Spiel nicht. Evtl. ist es bei dark tide so...?
Verstehe ich auch nicht? Welche FPS passen nicht zum Afterburner?
mit was bist Du Dir über die Latenz nicht sicher?
Grüße
Also Spiderman im Treiber Gsync +Vsync an gehabt und Framegeneration im Spiel da hat der mir irgendwas um die 106 FPS angezeigt obwohl wen ich Vsync ausmache um die 135 an der Stelle erreiche es müssten ja laut deinem Video aber 120 sein.
Als wen VSync nicht geht!
Das selbe auch bei Darktide .
Wen ich nur den Limiter setze ohne Vsync zeigt der AB mir Ingame aber ganz andere FPS an!
Wen das limit z,b 118 FPS setze macht der mir 100 106 FPS manchmal 116.
Auch Vsync funzt nicht da haut der mir auch ganz krumme FPS raus was zum Stottern führt.
Erst wen ich das ganze Gelumpe ausschalte lief es vernünftig mit zwar weit über die 120 FPS aber da für sauber.
Aber hey komme noch mal auf dich zu wen ich wieder eine Karte habe.
So ohne jetzt testen zu können bringt das nix.
Bleibt mehr Zeit fürs Forum. Das du Zeitmangel hast merkt man gar nicht :)
Hab wahrscheinlich was übersehen. Aber hast du nicht eine Strix ? Ich bin nicht mehr jeden Tag hier, da meine 4090 läuft wie erwartet.
Diese phänomene habe ch nicht.
Spiderman Morales:
NVCP Vsync an, FL 116
In Game: FG an, Vsync ist dann eh ausgegraut
Spiel läuft dann auch mit 116FPS
Habe gestern meine 4090 FE eingebaut. Soweit alles ok aber: bei mir gehen die LEDs der Karte aus wenn ich mal vom Rechner weg bin und bleiben dann aus. Hatte die 3090 nicht. Ist das normal? Hat das jmd anderes hier auch?
Der letzte war Mittags :P
Ui purzeln mal langsam die Preise .
Ne TUF OC sogar für 2192€ dabei verfügbar .
So langsam aber sicher scheint der Markt gesättigt .
Also bei mir gehen sie auch nach stand by wieder an.
Lg
Fasgear PCIe 5.0 GPU Stromkabel ummantelt 70cm | 16pin (12 + 4) 12VHPWR Anschluss für RTX 3090 Ti 4080 4090 | 3x8pin (4+4) CPU-Stecker nur für Corsair / Great Wall / Thermaltake modulares Netzteil https://amzn.eu/d/d7dPlSw
Ich kann später berichten, hab mir das Kabel für Seasonic / Asus / etc. gekauft. Ich warte aktuell nur auf ne 4090.
Es macht aber einen super Eindruck, fühlt sich hochwertig an. Nur find ich den Connector absolut lächerlich weil so "dünne" Kabel und klein XD
Kann es sein, dass Du noch einen anderen framelimiter eingeschaltet hast? Überprüfe mal RTSS!
Mahlzeit...wieder kein NBB Drop heute wollen sie nicht oder können sie nicht? :ROFLMAO:
Ek ist noch voll. So lang kommt dann auch nix.
Limiter nutze ich immer über RTSS über den Treiber nie.
Du meinst also nur über den Treiber Mal ausprobieren ja?
Werden alle (FE+custom) 4090 in China produziert oder gibt es andere Länder wo die Karten her kommen ? Gigabyte Produkte waren glaub oft aus Taiwan...
Kam die FE nicht von Foxconn laut Verpackung? Die sitzen in Taiwan.
Naja der Chip kommt aus Taiwan wegen TSMC und meistens gehen die dann zu sowas wie Foxconn für den Zusammenbau. Die haben Werke in Taiwan aber auch eine ganze Menge auf dem Mainland China
Vielleicht hätte ich es präziser ausdrücken müssen, was ich eigentlich damit meine. Umso weniger China in einem Produkt steckt, umso besser für mich. Auch wenn ich weiss, das man mit "Made in" nicht herleiten kann wieviel eigentlich aus diesem "made in land" kommt. Aber mehr hab ich nicht zur Hand (bis halt das der GPU Chip von TSMC in Taiwan produziert wird).
Daher würde ich mich freuen, wenn Besitzer einer 4090 schreiben könnten, was auf der Verpackung steht.
4090 FE: Made in China
4090 PNY: Made in China
Glaubst Du echt, es gibt eine Karte wo das nicht drauf steht? Und selbst wenn irgendwo Made in Taiwan drauf steht, kommen 99% der Teile aus China.
Ich will nicht glauben, eher wissen. ;-). Ich denke da wie schon geschrieben an Gigabyte...
Der wichtigste Teil kommt schon mal nicht aus China. Die GPU. Und wo der Rest her kommt ? RAM Samsung/Micron ? = nicht zwingend aus China. Keine Ahnung . 99% woher weisst du das ? sinds viellicht nur 63 % ?
Also ich würde denken (hoffen) das wenn ein Produkt "not made in China"ist, auch weniger China drin ist, also wenn Made in China drauf steht....
Na dann viel Glück bei der Suche.
Warum?
Ich hätte gerne eine made in Germany... hach man wird ja wohl träumen dürfen.
Ähnliche Themen
Antworten
7K
Aufrufe
584K
