[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Die habe ich. Aber in der Minigröße nicht. 2mm ist echt eng. Selbst wenn ich mit 1-1,5mm ausbohre könnte ich das gewinde ankratzen. Das müsste man an einer Standbohrmaschine einspannen und bohren. werde wohl mal nach lust und laune zu meinem Ex Tischlerkollegen in die Werkstatt fahren.
heißkleber ist auf jeden Fall nix. Das Gewinde steckt fest drin. Hätte es mit einer mininuss anziehen sollen. aber die hatte ich nicht. 3 gingen leicht rein und die 4te wollte nicht ganz...
Aber unterm Strich läuft es...
Der „Wera“ geht auch wieder zurück. Ich halte selbst 0,3Nm für zuviel (bräuchte 0,1-0,3 oder so)
Diese 0,6Nm von EK sind Wahnsinn!!! und davon sollte man definitiv Abstand nehmen, wenn man Schrauben und Blöcke von anderen Herstellern benutzt und deren Festigkeit nicht kennt
Welche kostenlosen RT-Benches benutzt ihr?
Hab hier noch Niemand gesehen, der "Neon Noir" von Crytek gebencht hat
klar :d --> https://www.forum-3dcenter.org/vbulletin/showthread.php?t=597407
Hey, nicht alle auf einmal...
:fresse:
Dann mach ich halt mal den Anfang @ 4K/Ultra/Fullscreen (noch nicht ganz ausgelotet)
Von der 3090 hatte ich damals keinen Bench gemacht (irgendwie vergessen), aber hier mit 2080Ti
Ich meinte mit 4090 ;)
lol what
Die sind ja schlimmer als die deutschen Wakühersteller :d
Gnadenlos überfordert.
dito da ist ja schon fast die 5090 draußen
Hör blos auf. Hab nen hals. Weiß nicht wie ich das rauskriegen soll. Wenn ich dort Bohre wird es echt eng bei 2mm :-(. Hast nen guten Tip?
Handbohrer aus dem Modellbau
hab sowas bis 0,4mm runter.
Hat hier jemand bei Witcher 3 Nextgen dasselbe Problem, dass es mit Frame generation zu heftigen Rucklern kommt, wenn man ins Pausenmenü geht und dann wieder raus? Oder auch bei Zwischensequenzen? Es dauert dann immer einen Moment bis es sich wieder fängt. Je länger ich im Pausenmenü bin, desto länger sind diese Diashow-Ruckler dann auch. Ich habe hier gefühlt alle Einstellungen ausprobiert, aber nichts hilft. Wenn man DLDSR mit FG nutzt, ist es sogar noch schlimmer.
Wenn das nicht bloß nicht wäre. Mit FG sieht es nämlich traumhaft smooth aus.
Ich finde den Zustand ohne Frame-Generation ja schon schlimm (selbst bei 80 FPS fühlt sich das nicht rund an) mit ständigen Nachlade/Shader-Generation-Rucklern.
Das kann ja nur schlimmer werden.
Ja schon. Mit FG ist es aber trotzdem WESENTLICH flüssiger. Vor allem in Novigrad in der Stadt ist es nur mit FG smooth. Ich kapier diese Aussetzer nur nicht, die ich mit FG habe. Immer wenn ich das Menü verlassen geht die GPU Auslastung teils kurz auf 0% bis die sich dann wieder fängt. In Zwischensequenzen auch oft.
jau, isso. CDRP sagt, dass sie die Probleme erstmal nicht so schnell lösen können. So macht nextgen echt kein spass. kommt ja nur alphaschrott raus.
Gotham Knights ruckelt
Witcher 3 ladestutter
portal kam ich nicht über 40FPS. War gelocked. Danach startete es gar nicht mehr
Calysto Protocol Ruckelorgie
Das einzige Nextgen Game welches rund läuft ist spiderman
rendern ist nicht Gaming. mach mal 450W MSI Kombuster Donut
Dann kannst du die Karte immer noch mit 1000rpm laufen lassen und bist bei ~72 grad auf dem Core. Die PNY ist leiser und kühler als die TUF, wie ich inzwischen auch mal selbst testen durfte.
Bei Portal hatte ich komischerweise keine Probleme. Da hatte ich dieses Multicore Rendering deaktiviert, weil mir das Probleme machte.
Also irgendwas stimmt mit deiner Karte definitiv nicht. Idle Verbrauch ist bei mir vergleichbar mit der Fe, bzw. 2-3W weniger. Macht auch Sinn aufgrund des kleinen VRMs.
Aber ganz kurz zum Verbrauch: 18-22W klingt plausibel, 6-9W bei der FE hingegen klingt eher nach Auslesefehler. Da verbraucht der VRM schon mehr.
Deine Temperaturen sind aber vollkommen komisch und nicht nachvollziehbar. Die PNY hat bei mir dauerhaft 1000rpm und war bei allen Temperaturen 6-8 Grad kühler.
Entweder ist der Kühler nicht richtig drauf, oder du hast nen ITX Case wo die Karte kaum Luft unter sich hat.
Sag hat meine mir einem Lineal vom Boden gemessen etwa 1mm.
Also irgendwas stimmt mit deiner Karte definitiv nicht. Idle Verbrauch ist bei mir vergleichbar mit der Fe, bzw. 2-3 weniger.
Wieso sind meine nicht nachzuvollziehen, vielleicht sind es ja deine nicht. :fresse:
Aber Scherz beiseite, die Temps können natürlich dadurch begründet sein, dass ein Lüfter nicht mitläuft. Was den idle Stromverbrauch angeht, bin ich natürlich für jeden Tipp dankbar. Habe alles probiert inkl. komplett schwarzem Desktop Hintergrund. Aber da die FE ja zufriedenstellend läuft, kann es kaum an meinem System /den Einstellungen liegen.
Also 6-8W kann die Karte rein technisch überhaupt nicht ziehen, da sind einfach die Werte von HWInfo falsch. Alleine über die ganzen VRM Module entfallen ~1W pro Modul. Da bist du schon weit über 6W. Miss und Vergleich am besten mal den Verbrauch ab Steckdose :)
Schick mal ein Bild wie bei dir die Karte im Case verbaut ist. Bedenke die PNY ist einen halben Slot dicker, das kann viel ausmachen bei der Lufzufuhr.
Also ich habe bei meiner PNY auch schon 6-9W angezeigt bekommen, passt nur nicht zu dem was an der Steckdose verbraucht wird^^
@pajonk @Gurkengraeber
Ich habe nochmal bissel gesucht, als ich die Karte neu bekommen hatte, da hatte ich für knapp 3h den Port Royal Stabilitätstest laufen um zu gucken wo die Reise hingeht (incl. RT)
Dabei lief die Karte fix bei 30% und 1000 rpm, die 1100 rpm sind vermutlich ein Auslesefehler. So heiß habe ich die Karte nie wieder bekommen, aber denke bei den Temperaturen kann man trotzdem echt nicht meckern:
So mein CableMod Custom Cable vom US Shop ist da. Echt super 6.12. bestellt heute da. Nur 10 Tage, kann mich nicht beklagen. Die Qualität ist auch top. Hier mal ein Vergleichsfoto zwischen Original Seasonic (was imho enorm hochwertig ist für ein kostenloses Kabel, da hätten die auch 50€ verlangen können).
Also ich denke der Platz ist nicht das Problem. Außerdem sind auch nicht die Temps das Problem, es laufen wie gesagt nur zwei Lüfter. ;) Das mit dem idle Stromverbrauch finde ich viel interessanter. Selbst wenn ein Tool das falsch ausliest, so wäre es ja unter den Karten vergleichbar. Also egal wie viel die FE wirklich verbraucht, die PNY nimmt sich 12W mehr.
Nein, der Wert bringt dir nicht wirklich was. Wie gesagt, meine hat auch gerne mal 6-8W stehen. Wenn die HWInfo auf 20W springt steigt aber nicht gleichzeitig der Verbrauch an der Steckdose. Der Wert ist einfach völlig sinnlos ^^
Meine FE hatte zB immer mehr angezeigt als meine PNY, was soll man nun also jetzt aus dieser Information ableiten?^^
Wenn du wirklich den Idle Verbrauch vergleichen magst kannst du wirklich nur gucken wie viel wird aus der Steckdose gezogen. 15-20W sind da deutlich messbar, mein gesamtes System liegt im Schnitt bei ~65W.
Wo soll zudem so eine enorme Abweichung beim Verbrauch herkommen? Da kommt ja nur der VRM in Frage, die Daten kann man aber dem Datenblatt entnehmen und die Effizienz ist im idle ziemlich egal. Da ist es sogar so, dass der VRM mir den meisten DrMOS Komponenten die höchste Leistungsaufnahme generiert. Geht einfach rein von der Physik gar nicht anders. Jede Abweichung von mehr als 5W lässt sich einfach rein logisch ganz schwer begründen. Und da sollte man dann eben, wenn man dem wirklich nachgehen mag, nicht mit Softwaresensoren arbeiten, sondern mit Hardwaresensoren.
Aber der Platz passt in jedem Fall.
Junge Junge, du lässt auch nicht locker, wie? ;) Ok, dann jetzt halt mal der Wert an der Steckdose, gemessen mit einer Voltcraft SEM6000. Idle Verbrauch mit der PNY: 68W. Idle Verbrauch mit der FE: 54W. Jeweils das gesamte System, aber alle anderen Komponenten natürlich unverändert.
Sorry aber die PNY ist einfach Scheisse, was den idle Verbrauch angeht. Außerdem haben dies mehrere Review Seiten (ich glaube auch HW Luxx) bestätigt, dass sich die FE unter 10W zieht.
Was heißt nicht locker lassen? Ich kann das einfach nicht nachvollziehen. Bei Techpowerup liegen alle 4080 und 4090 im idle gemessen auf 1-3W zusammen (also bei gleichem Chip), da ist auch die PNY als 4080 dabei.
Außerdem sehe ich bei meiner ja auch (zumindest in HWInfo) teils 6,xx W, aber eben nur nur in HWInfo.
Deine ganzen Ergebnisse sind eben das komplette Gegenteil von meinen eigenen Erfahrungen FE vs. PNY und auch die TUF war nicht groß anders.
TUF ist laut HWinfo durchgehend bei 21 bis 23w
Die FE bei ca. 7w.
Gleiches Setup - alles gleich eingestellt.
Meine PNY ist auch immer mal wieder bei 6-9W im idle nach HWInfo… und nun?
Im Mittel jedoch eher bei bei 16-18W, was ja immer noch deutlich von 25W abweicht.
Mist ist die Karte eher unter Last, da eben die Effizienz recht beschissen ist, sind eben bei 450W fast 30A pro Komponente.
Naja du ziehst die falschen Schlüsse.
HW Luxx sagt
Ich komme zwar nicht auf 6W, aber unter 10 waren es immer. Kann das gerne nochmal hier zeigen, wenn die Karte zurück kommt. Es geht darum, dass mal völlig unabhängig von der absoluten Zahl, bei absolut gleichen Bedingungen die PNY mal gut 10 bis 12W mehr zieht im idle. Soweit ich das mitbekommen habe, ist das auch bei den anderen Boardpartnern so. Also auch unabhängig von den Schwankungen. Ich mein dafür braucht man ja nur den Mauszeiger zu bewegen.
Ähnliche Themen
Antworten
7K
Aufrufe
617K
