[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Mein Kabel ist immer noch in Shenzhen im Van ... :d
Also nur um das mal gesagt zu haben dieses "Brummproblem" haben auch Noiseblocker eLoops z.B. wenn sie im "pull" montiert sind und zu nah an Lüftungsgittern/Finnen liegen, das ist kein neues Phänomen, vermutlich sind Lüfter bei denen die Lüfterblätter in einem "Ring" münden da empfindlicher als andere.
FE Fan Mode
Das Modding kann beginnen.
Jetzt muss ich nur warten bis meine KArte von NBB zurückkommt und bestelle schon mal folgende Dinge:
1.
2.
So kann man den Fan mit den Distanzringen variable anbringen und hat die passenden Schrauben um die Längendifferenz auszugleichen...
Hoffe das wird was :-)
Hmm, vielleicht müsste man die Öffnung nur mit einem Stück Plastik schliessen... :unsure:
Mal bei Gelegenheit Prüfen.
Ja dachte auch daran ein 3 eckiges Schaumstoffpolster / Styropor dort reinzumachen damit der Resonanzraum gefüllt wird..
So in etwa:
Problem ist, dass man das PCB abheben muss. Und Laut Nvidia Ingenieur ist dann die Kühlung nach dem Zusammenbau nicht mehr so gut wie vorher. logisch. Von daher ist es ein Risiko es zu testen... Freiwillige vor :-)
und von der Lüfterseite aus bekommst Du es nicht geschlossen, da der Lüfter nur um Schamhaaresbreite daran vorbeidreht.
So meine Ersatz 4090 FE von NBB ist da und ich kann sagen, dass auch sie brummt, aber etwas leiser. Dafür eiern beide Lüfter und man hört das Schleifen der Lüfter bei höherer Drehzahl.. macht euch keine Hoffnung dass es eine geräuschlose FE gibt.
Wie ein User hier zu mir sagte, so klingen FE Lüfter halt.
Nachdem das jetzt meine siebte 4090 ist und ALLE entweder laute Lüfter oder Coil Whine des Todes hatten, bleib ich letztendlich bei dieser FE.. ich hab auch einfach keine Lust mehr weiter zu suchen
Wow, sieben ist beachtlich. Aber nicht 7 FE's oder? Danke für Deinen Bericht. Das erspart mir das Austauschen. Was aber schon geschehen it... Hoffe NBB schickt mir die gleiche zurück :-) Habe es per mail und am Telefon geäußert.
Du hast 6x die Karte zurückgeschickt, obwohl kein Defekt vorhanden war und du sie haben wolltest? WTF?!
Vergiss es, ich wollte meine auch zurück da der Chip top war. Meine Anfrage wurde auch berücksichtigt, bekommen habe ich aber trotzdem eine neue.. is halt ein Standard Prozess.
Neine waren keine 7 FEs,
strix, tuf oc und non oc, ichill black, gigabyte gaming oc, 2x FE
Für teils 2300€ und mehr erwarte ich ein Produkt in diesem Segment, dass mich zufrieden stellt. Und wenn extremes Coil Whine kein defekt ist mache ich von meinen Rückgaberecht gebrauch
Oh nein:-(. ich habs geahnt :-( Der am telefon meinte ist kein problem. Per Mail, keine Reaktion.
Mein Cablemod Kabel für Seasonic Netzteile funktionierte auch nicht. Hab gestern eine Antwort vom Support bekommen, dass scheinbar Kabel beim Versand vertauscht wurden.
Mhmm, wenn ich mich jetzt da also melde bekomme ich ein weiteres Kabel gratis? :ROFLMAO: Die wirken ja nicht so, als wenn sie Ahnung hätten welche Bestellungen betroffen sind
kann man bei fucking dhl keinen mensch mehr sprechen? 3 standardfragen vom roboter und man fliegt wieder raus.
hst
Selbst wenn du das schaffst, dann wünscht du dir wieder mit dem Roboter zu reden. Unglaublich unfreundlich und unwillig. Du bist in jedem Fall ein Bittsteller der nur stört.
hast Recht. eine Tschechische Generälin war es. Aber immerhin hatte sie rücksprache gehalten und eine lösung parat. habe nun ein webformular ausgefüllt welches sich in den tiefen der dhl seite verbarg.. Mal scjauen ob das klappt :-)
Einfach wirres Zeug über die Tastatur eingeben, dann bekommst eher jemanden dran.
Meine Vermutung: egal was du da angeben musst. Zum Schluss kommt raus dass du irgendwas falsch gemacht hast und deshalb selbst Schuld bist. Man kann dir nicht helfen.
Das System ist leider von DHL extra so designt. Die haben grundlegend kein Bock auf Privatkunden Support. Wem schonmal ein per Privat versichertes Paket abhanden gekommen ist und was man alles tun muss um den Versicherungswert wieder zu bekommen, entscheidet man sich meistens lieber irgendwann freiwillig darauf die Sache einfach aufzugeben. Die Passierschein A38 Methode.
Meine 4090 läuft mit 0,89 mV bei 2620Mhz.
Speicher OC hab ich mal +1000 Mhz gemacht, allerdings kostet es auch etwas mehr Strom und am Ende kommen nur 1, im besten Fall 2 FPS mehr dabei raus.
Speedway ist da natürlich eine Ausnahme, aber bei Spielen merkst du es nicht.
Ob sich das RAM-OC daher lohnt, muss jeder für sich selbst entscheiden, ist zudem auch eine potenzielle Quelle für Instabilität.
Mal eine Frage, wie sehr macht sich das übertakten des Speichers im Alltag beim gamen bemerkbar? Also wenn der Core Clock gleich bleibt und nur der Speicher übertaktet wird.
Edit: mein Post hast sich gerade mit dem oberen überschnitten. Wie sich das liest, bringt es nicht wirklich was.
Erstmal ein dickes Danke an alle, die sich dem Thema annehmen. Zwar sicherlich auch aus eigenem Interesse, aber ich gehöre ja schon zu denen, die das mit dem Brummkreisel bei der FE etwas mehr stört.
Neue Entwicklung bei mir: Anhand der eingesendeten Videos sieht NVidia einen RMA Fall als gerechtfertig an. Ich soll unter zig Auflagen und vorher einzusendenden Dokumenten / Screenshots / Fotos den entsprechend Fall eröffnen. Ich werde das auch tun weil ich sehen möchte, ob die Ersatzkarte (bzw. die "reparierte" Karte) nun besser ist oder nicht. ich gehe allerdings zu 100% (nicht zu 99) davon aus, dass auch der Ersatz, egal ob neu oder nicht, ebenso brummen wird. Dazu sind einfach die Erfahrungen hier bzw. die Videos im Netz zu eindeutig.
Aber ich bin überhaupt erstmal überrascht, dass die sich das weiter anschauen wollen. Also packen wir's an.
Das kannst du auch im Live Betrieb testen, einfach dir ne Stelle in einem Spiel deiner Wahl suchen wo die GPU ordentlich was zu tun hat.
After-Burner bzw. Riva Tuner OSD laufen lassen und dann den Speicher um +1000 Mhz erhöhen und die FPS beobachten.
Oder einen Spiel-Internen Bench bei einem Spiel nutzen, mit Stock und + 1000 Mhz mehr auf dem Ram.
:mad: So da liegt sie im Warenkorb die Suprim und ich kann die Bestellung nicht abschließen
Vielleicht eine etwas teurere Alternative, dafür ohne Stress mit Bots:
Gibt wohl noch 20 Euro Rabatt bei der ersten Bestellung.
Wo her wird die versendet ?
Zoll?
So sehe ich es auch. Aber ich hatte ca. 5% rausgeholt
Probier es doch aus...???
Ähnliche Themen
Antworten
7K
Aufrufe
588K
