[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Was ist der Unterschied zwischen der Suprim und der Suprim X ? Und die kostet 200 Euro mehr als eine FE vom Scalper auf EKA.
Mein Favorit wäre im Moment die Zotac Extreme Airo. Gute VRM und tendentiell weniger Spulenfiepen als die MSI. Gigabyte Gaming OC würd ich auch nehmen oder am liebsten natürlich die FE.
Die x ist doch ne aio Variante wenn ich mich nicht irrer
Kann mir jmd sagen, warum ich den ECC-Status im NV-Treiber nicht ändern kann?
Nach einem Neustart sollte der Haken drin sein. Geht bei mir nicht :oops:
Laut Datenblatt 30Mhz Boost ^^
2610MHz bei non X
2640MHz bei der X
Das ist die Suprim Liquid, die es auch nochmal als X und non X Variante gibt.
Hat es jemand von euch geschafft die Beleuchtung seiner Trio / Suprim zu steuern ?
Willkommen in der RGB Hölle :ROFLMAO: Hab jetzt extra alles von Asus geholt damit es einigermaßen funktioniert
Gibts btw schon irgendwie Erfahrungsberichte bzgl. dem "besten" vBios oder nehmen sich die alle nicht viel?
Meiner meinung nach nicht nötig. Vor allen dingen wird auch die lüftersteuerung geändert... oc und uv geht mit dem ab bei jeder karte.
Ich habe die Suprim X und mir ist aufgefallen, dass sich die Karte die gespeicherten Einstellungen vom MSI Center merkt. Heißt ich habe einmal auf statische Beleuchtung gestellt und konnte dann sämtliche Tools vom PC wieder runterschmeißen. Super Sache (y)
Selbst die Beleuchtung der FE kann ich mit Armor Crate in mein RGB Set einbinden. So schwer sollte das nicht sein.
Was soll so schlimm sein an Armory Crate?
Es macht doch was es soll und steuert unter anderem das RGB zuverlässig.
Also bei mir funktioniert es von Anfang an gut. Auch die Fan Control ist für mich völlig ausreichend.
Es laufen zig dienste und prozesse. Deinstalliert bekommt man es nicht mehr. Und wenn du pech hast geht mal ein update schief und man bekommt es gar nicht mehr installiert. Hatte damit tage für meine 3090 tuf verschwendet. Am schluss hatte ich eine extrawindowspartition nur für amory crate.
Doch da gibt es extra ein tool dafür:
Da ist rgbfusion von gigabyte gold gegen. Schlankes programm. Keine prozesse im hintergrund und kannste de und installieren innerhalb 10 sekunden.
Die tools hatte ich alle. Bleibt trotzdem was übrig. Musste mit regedit tausend sachen löschen usw. Habe es aber nie mehr installiert bekommen. Der fehler kam bei etlichen beim googeln vor. Weiß nicht mehr was es war. Es hat immer gemeckert dass ein asus dienst fehlt.
Zudem kann die cpu mit armory crate nie mehr richtig idlen.
Hab Armoury Crate einmal installiert und das reichte mir. Die Software ist schlimmer als ein Virus.
Haha quasi der Trojaner im Bios 😂
Armoury Crate funktioniert wie es soll und ist zuverlässig. Kann man aber nur mit Windows Neuinstallation richtig entfernen wieder aber das ist für mich ok , mache ich eh alle paar Monate :LOL:
Armoury Crate hat mein Bart noch weiter ergrauen lassen, bis ich merkte das dieses Kack Programm für diesen Fehler verantwortlich war. Und man festellt das sich dieses Programm wie ein Tumor über den ganzen Rechner verbreitet. Der Fehler war immer reproduzierbar, 3 Windows clean Installationen gemacht. Immer wenn das Tool Installiert war hat es diesen Fehler beim runterfahren verursacht. Es hing immer mit Programmen im Autostart zusammen.
Global Rank #3 beim GPU-Score - wie geht das bei diesem Takt und der Temperatur? :oops:
Wegen dem hohen CPU-Takt und schnellerem System-RAM? Der Grafik-Test 1 geht bei ihm extrem gut ab
Zum Vergleich...
Mein durchschnittlicher GPU-Takt ist ca. +100MHz höher, als seiner (beim VRAM hat er +60MHz mehr)
Armoury Crate finde ich auch unter aller S.. bis ich das wieder weg hatte unglaublich.
Und das MSI Center ist auch ... hatte es beim Release (4090) versucht zu installieren aber keine Chance.
Heute habe ich es dann noch einmal probiert und es läuft alles wie es soll ich kann endlich die Suprim einstellen.
Als weiteres nutze ich nur noch Open RGB damit steure ich meinen Ram und Mainboard.
Und Danke für den Tipp habe MSI Center aus dem Autostart entfernt und die Suprim behält die Einstellungen bei !
