[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Soo, alles fertig:
(finde es btw sehr schade, dass ausgerechnet das „Geforce GTX“ Logo nicht beleuchtet ist…)
PL 90%, +100/+900:
Hu die aio oben?
Das Wasser wird sich sehr erfreuen über die Abwärme der Grafikkarte.
Die aio muss vorn rein mit Luft von außen. Cpu Temp und das Wasser gehen doch in die Höhe.
Kurze Frage an Euch...hat jemand zufällig diesen Kabelsatz schon ausprobiert und kann was dazu sagen?
Fasgear PCIe 5.0 GPU Stromkabel ummantelt 70cm | 16pin (12+4) 12VHPWR Anschluss für RTX 3090 Ti 4080 4090 | 3x8pin (6+2) PCI-e Stecker kompatibel für ASUS EVGA Seasonic Modular Netzteil https://amzn.eu/d/ijTCiHx
Wenn ich diese verkohlten Adapter sehe bekomm ich das...
CableMod da wart ich schon aber anscheinend kommt das auch aus China...weiß diesbezüglich auch jemand mehr?
Danke und viele Grüße.
Hat jemand da Erfahrungen?
Hu die aio oben?
Ganz so simpel ist es nicht. Wenn du AIO vorne oder unten hinpackst dann zieht sich die GPU die warme Luft. Ist also eine Frage der Prioritäten: Willst du mehr Fokus auf GPU- oder CPU-Kühlung haben.
Ja aber die CPU wird doch mit der aio oben viel heißer wo die Grafikkarte vielleicht 1 bis 2 Grad höhere Temps hat.
Wenn überhaupt.
Sehe ich nicht so und es läuft nun seit 1.5 Jahren einwandfrei (vorher war eine 3090 drin) so und die CPU geht selten über 72 Grad.
Mal was anderes:
Dieses Gimmick war bei der Strix dabei und die Rückseite (Klett) suggeriert halt das es irgendwo drauf soll?
Aus purer Neugier, Wo soll das Teil hin? 😂
Mal was anderes:
Das ist nen Kabelbinder.. um die Kabel zusammenzuhalten :D .. kannst du um ein Kabel rollen. :D
Soo, alles fertig:
PL 90%, +100/+900:
Der Adapterstecker ... Katastrophe ... der macht die ganze Optik kaputt, imo. Bin froh, dass ich einen echten 16 Pin-Stecker habe, den mein NT auch unterstützt.
Endlich mal Bilder der Karte. Noch nie gesehen. Bissl wenig Emotion drin. Angeschnallt im Auto oder vor einer Felge hat schon einen anderen Style. Aber immerhin mit Farbe. Nicht schlecht!
Wow! So sieht sie also aus! Hätte ich so nicht erwartet.
Schade, dass Du die Bilder nicht in noch größerer Auflösung posten konntest. 🙄
Na dann zur Sicherheit nochmals um die Erinnerung zu verfestigen, nicht dass man die FE wieder vergisst. 👍
Bei 200w Verbrauch, werden wohl ca. 350w konsumiert - bis 150w mehr bei UV mehr.
Kannst du unter HWinfo nachschauen.
Meinst du damit das mehr gezogen wird als angezeigt wird oder wie soll man das verstehen? Und wenn ja wie soll man denn auf sowas gekommen sein? Hat man erstmal den Verbrauch mit Adapter gemessen und dann nochmal mit direkt angeschlossenem Kabel ?
Meine FE ist auch eben eingetrudelt, lasse sie aber erstmal ein bisschen liegen, die Karte ist eiskalt.
Damit könntest du aber geile Benchmarks machen jetzt und die Temperatur als Wunder verkaufen :D
ich diskutiere auch nicht sondern gebe meine Meinung wieder wie er eben auch. Aber du siehst ja lustigerweise sogar als Hate an offensichtlich. Verstehe deine Reaktion nicht.
ach so, gleich mehrfach weil du es ja anders siehst als er.
wie gesagt, das erkundigen nach der garantie ist aus meiner sicht in ordnung eben weil ein defekt immer vorkommen kann.
dass du noch keinen hattest ist sehr schön für dich, aber hat zu seiner frage (sorry meinung ;) ) keinerlei relevanz.
Wie erklärst Du Dir, dass hier seit Kurzem so viel gehatet wird?
Das ist ja schlimmer als in den Foren mit dem Video-Bauer :kotz:
seit kurzem?
hier sind seit erscheinen der karte spannungen.
aber es scheint hier nunmal gerne jeder recht haben zu wollen, leben und leben lassen ist hier außer kraft gesetzt.
Liegt wohl an den Sense-Pins.
Ist das dieser Wert hier (markiert, siehe Anhang)? Das ist dann also quasi die gesamte Leistung (GPU Rail Powers), die die GPU benötigt?
Ich habe bisher immer nur bei "GPU Power" (obendrüber) geschaut. Das ist auch der Wert, den MSI AB/RTSS abgreift und der im Ingame-Overlay las Verbrauch dargestellt wird.
Für die bisher zu kurz gekommenen bzw. die nach erfolgreicher Bestellung ein Storno kassiert haben steckt dann schon Emotion drin. 😆
Ja die freuen sich dann bestimmt über Bilder von denen die eine bekommen haben. Wir leben ja Gott sei dank in einer Welt in der die Nächstenliebe mehr gelebt wird denn je :)
Ich gönne jedem sein Kärtchen, aber nur die EVGA RTX 4090 die wir nicht kaufen dürfen löst einen noch stärkeren Habemus Impuls als die FE aus.
