[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
“ Mit dem Download des Display Driver Uninstaller (DDU) lassen sich Grafikkarten-Treiber von Nvidia-, AMD- und Intel-GPUs ohne Rückstände deinstallieren.
Dies empfiehlt sich vor allem bei Treiberproblemen oder wenn die normale Deinstallationsroutine versagt. Auch ich so eine saubere Neuinstallation möglich, wenn eine Grafikkarte in den PC eingebaut wird.”
Ich hab aber nur einen und zwar den letzten Nvidia Treiber installiert. Die Ryzen Onboardgrafikkarte habe ich deaktiviert.
Lösche mit DDU den AMD Treiber, wenn du den installiert hattest. Und Anschließend den Nvidia Treiber.
Dann machst du eine frische Neuinstallation und guckst, ob deine Probleme vorhanden sind.
DDU wirkt manchmal Wunder!!
Gut, werde ich morgen mal probieren, Danke.
BeQuiet Adapter ist an 12V4 und 12V5 angeschlossen.
Auch eine Möglichkeit warum das Power Adapter schmelzen nur einige haben könnnten .. manche können den Adapter nich komplett reinstecken
Auch die Kommentare dadrunter lesen :
Aus dem Reddit Post und Kommentaren :
Bündig : ------------------------------------------------- Nich bündig :
Weiss nun nich wie gross da nun der Einfluss darauf is aber is eine Auffälligkeit .. würde auch erklären warum manche ein "click" hören und andere nich beim reinstecken
Es kann "Klick" machen. Von 4mal hat es einmal laut geklickt.
3mal war es lautlos.
Ich würde mich aber nicht auf ein "Klick" versteifen. Ansonsten ziehen die Leute das Kabel noch 3mal raus...
Ist mir bewusst ... Das es immer klick machen sollte war nicht meine Aussage. Ich mache mir darüber keine Gedanken.
Ne, bei den dummen Antworten hier werde ich das ned machen. :o(y) :o
Shice :(
Dumm gelaufen bei mir. Die neue Graka ist gekommen. Ist ne Zotac geworden, passt für mich mit 3+2 Jahren Garantie. Übertakten ist eh nicht mein Ding von daher
könnten wir gute Freunde werden.
Allerding bekomme ich nun kein Netzteil Das ROG Loki SFX-L ist nirgendwo lieferabr. Mein aktuelles Dark Power Pro Platinum hat leider nur 550 Watt. Gut undervoltet würde ich es sogar probieren, nun fhelen mir aber die Kabel. Ach man, irdenwie blöd gelaufen. :cry:. Ich denke das neue sollte zwischen 850 und 100 Watt liegen. Mag aber irgendwie nun auch kein neues BeQuiet kaufen wenn noch keins mit ATX-3.0 dafür ist es dann auch wieder zu viel Geld. Oder was meint ihr? Irgendeinen Tipp für den Übergangn? Der neue Rechner wird erst im kommendne Jahr ca. Februar aufgebaut. Sol lange darf die alte CPU noch werkeln. Nur das Netzteil sollte nun ersetzt werden.
Kauf dir doch ein bequiet mit 1000w. Das hält ne Weile. Straight Power 11 Platinum ist nice oder Dark Power Pro. Dazu das Kabel und der Fisch ist erstmal geputzt.
Mit DDU die AMD Treiber deinstalliert, hat leider nicht geholfen :(
@SH: Kabel sitzen alle richtig. Andere Games laufen auch?!
Bevor man sich so ein overpriced 3.0 China Böller Netzteil kauft, ist man aber definitv besser mit einem ATX 2.X und Adapter oder noch besser Hersteller Adapter Kabel bedient.
@WolfJ13 du hattest doch heut morgen gefragt, wie mans am PSU anschließt:
Laut dem was hier die Leute sagen, 1 und 3
Bei meinem DPP10 ist es 1+3 oder 2+4
oder OC Knopf drücken und dann ist es egal (=Singlerail)
Ein Versuch ists doch wert, es mal an 1 und 3 oder 2 und 4 anzuschließen 😉
Nun habe ich eine MSI Trio mit 140mm Tiefe hier. Laut meinen Recherchen hat mein Gehäuse Platz für CPU Kühler mit 165mm Höhe. Ein Lian Li O11 Dynamic Evo hat auch nur 167mm Platz. Meint ihr, ich komme mit dem Standard-Adapter gefahrlos den benötigten Biegeradius hin? Ein neues Gehäuse war eigentlich nicht geplant… :-(
Hast du auch den Nvidia Treiber deinstalliert und anschließend neu installiert?
Du solltest doch beide Treiber mit DDU ins Nirvana jagen.
Alles mit DDU deinstalliert und Nvidia sauber mit (Neuinstallation) installiert. Jeweils zwischendurch Reboot!
@Ben84: Stimmt, teste ich gleich.
Anhang anzeigen 814116-- Anhang anzeigen 814117--
Danke @Stagefire
Der Thread ist von mir lol
Kommt euch das nicht auch komisch vor? Es gibt Leute mit Adaptern, da schließt alles bündig ab und die berichten, dass sie keine Probleme beim anschließen hatten und auf der anderen Seite Leute wo es nicht ansatzweise so bündig aussieht wie auf Foto 1.
Ähnliche Themen
Antworten
7K
Aufrufe
587K
