[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
So, die GPU taktet im Desktop nicht mehr runter. Hängt ständig auf 2520MHz fest, VRAM auf 10500MHZ, 60W. Kein OC, alles default.
Noistart des PCs bringt nichts.
Energiesparshice immer auf "Minimum Leistung", in Windows und auch im Treiber.
Im BIOS nichts verändert.
Kann das mit keinem speziellern Ereignis in Verbindung bringen. Aufeinmal fiel es mir auf.
Was can man dagegen machen?
MSI AFTERBURNER und force voltage option aktiviert?
Dann musst du MSI Afterburner inklusive profile deinstallieren und dann ist das Problem behoben 👍
Danach kannst du es ganz normal wieder installieren
Ey Leute... wir krank sind die Karten bitte?
mit 3030MHz bei 1065mV ingame Stable und die Karte macht nicht über 47Grad im 4K Gaming unter schlechten AirFlow Bedingungen?! WTF!!!
Mit 950mV bei 2600MHz maximal 40Grad 4K Gaming!
Das geht doch unter Wasser nicht besser oder?
Genau dein Problem wurde doch vom Hotfix Treiber gefixt, hast du den installiert?
Wenn ja: DDU und dann erneut drauf.
Nein, kein HF Treiber installed, d8e da war nur was mit COD MW. Habe mir nur den Shice gemerkt und habe das Spiel nicht.
Jedenfalls habe ich erneut noi gestartet, nun taktet die Shice richtig runter. Werde, wenn der Takt wieder locked, an den HF Treiber denken. (y)
So da WoW ja nicht allzu fordernd ist, habe ich mal AC Valhalla gezockt. Die Auslastung war bei 95-98% und die Leistung der 4090 ist ja disgusting (im positiven Sinne). Alles auf max. bei meiner Auflösung (kein upscaling) und man hat zwischen 120-200fps. Die Karte bleibt trozt der hohen Auslastung bei 52° GPU und 59° VRAM und 60° Hotspot. Die Backplate ist lauwarm, das Stromkabel kalt. Wie hat Nvidia dieses Meisterstück hinbekommen?
Bezüglich Spulenfiepen: Also man hört die Karte unter Last aber es ist kein Fiepen wie bei der Suprim, sondern eher hört man Strom "fließen" aber sehr gedämpft und man muss schon wirklich mit dem Ohr ran (wenn das Gehäuse offen ist). Selbst im Menü mit ca. 500fps wird dieses Geräusch nicht mehr.
Jap! Bin mit meiner Gaming OC auch sehr zufrieden! Übelst performant und verdammt leise, absolut kein Spulenfiepen, Hammer 👍
geile Karte
Bin nun stolzer Besitzer einer 4090 FE 😍
Meine vertikale Halterung für das Lian Li O11d muss ich morgen erstmal ausbauen 😅 Das Teil ist einfach zu fett …
Statt ihn einfach sofort zu installieren und gut ist? Hmm, na wenn du meinst 😂
Und was machst du bitte mit der deutschen Sprache? Ist ja kaum lesbar der denglische Kauderwelsch.
BTW: Die Karte hat den 16-Pin anschluss hinten.
Ist diese Anschlussvariante für den Airflow im (geschlossenen) Gehäuse nicht eher suboptimal, weil die Luft von den blasenden Frontlüftern erst einmal am Adapter und den vier baumelnden PCIe-Kabeln vorbei muss?
naja es ist Luft und kein Joghurt.. die kommt da schon vorbei
Jap! Bin mit keiner Gaming OC auch sehr zufrieden! Übelst performant und versammt leise, absolut kein Spulenfiepen, Hammer 👍
Keine Karte, kein Stress, kein Spulenfiepen, nichts, läuft bei dir 👌
Das wird am ende wohl kaum viel ausmachen denk ich. Aber mit nem anschluss hinten könnte man wenn das Problem mit engen biegeradius nicht wäre recht gut nach "hinten" biegen und dann direkt durch den Gummi durch vom Gehäuse somit wäre quasi gar kein Kabel mehr im weg.
Hat jemand Erfahrung mit Reichelt.de? Versand? Storno?
Habe mir dort ein 12vhpwr bequiet Kabel bestellt.
War klar das es ne TUF ist, knapp 30% Failrate :d 8 von 26
Und trotzdem wollen alle die haben...
Jup die is auffallend oft vertretten ( wird aber auch viel Produziert vonn Asus sind allein 7 Seiten im Verfügbarkeits Thread die die TUF alleine füllt von 26 Seiten bisher während die Strix nich mal 1 Seite füllen kann )
und die FE is bisher garnicht in der Liste der Schmelz Adapter ist auch auffalend.
Es sind 21. Ich weiß nicht, warum du die unbestätigen Fälle mitzählst.
Selbst in Reddit Thread sind sie separat aufgeführt.
Nur weil sie unbestätigt sind sind es dennoch Fälle ... spielt doch auch garkeine Rolle auch wenn man die weglässt wird das Problem dadurch nich kleiner
währe es nichts dann würden sie dort nämlich garnicht geführt aber sie werden dort geführt also zähl ich die mit... ausserdem Poste ich ja immer das Bild mit allen Fällen mit in den Beitrag
kann ja dann also jeder selber lesen welche da bestätigt sinnd und welche nich
@Stagefire : wir wissen Bescheid nachdem du über 20 mal darauf hingewiesen hast ^^
manche anscheinend aber noch nich sonst würde es nich hier und da mal solche wiederworte geben
Eigentlich wollte ich ja nur noch so 2 - 3 Fälle Posten aber ich hab vorgesternn beschlossen noch etwas Länger davon hier zu berichten das schadet ja nich und ist ja immernoch ein
aktuelles Thema besonders da ja noch die 16 Pin Nativ Kabel von MSI letztens dazu kammen die auch verschmort sind.
Ein paar der "bestätigten Fälle" sind aber auch nur mit viel Phantasie "angebrannt", bei einem sieht es aus wie ein Kratzer, beim anderen, als hätte er den Anschluss in Sekundenkleber gedippt ...
Womit kann ich denn am ehesten VRAM-OC auf Stabilität testen? Hab' vorhin mal spaßeshalber den Slider im Afterburner auf max (+2000), und Heaven, Superposition, Metro EE & Port Royal laufen alle durch, ohne irgendwelche Bildartefakte, und +2000 sorgt tatsächlich für minimal höheren Graphics-Score als z.B. +1500 - Fehlerkorrektur betreibt der Speicher also scheinbar nicht.
Mag ich aber irgendwie nicht so recht glauben, das wäre ja schon ziemlich heftig?!
Üps, danke dir für den Hinweis 😂😝
Okay ich hab jetzt schnell nen Screenie angefertig von dem Spiel was ich aktuell zock.
Chernobylite mit Ultra Setting, DLSS Qualität
einmal mit UV
einmal mit 60 Prozent PT
Zocke das auf 4587*1920
MIT UV:
75 FPS bei 202 Watt
Ohne UV und mit 60 Prozent PT
78 FPS bei 292 Watt
Ohne UV und mit 50 Prozent PT
76 FPS bei 242 Watt
Beim PT limitieren kann es aber auch sein das die Leistung schlechter bleibt, weil iwann eine Szene kommt wo mehr Leistung benötigt wird.
Bei dem Spiel ist z.b ist UV effizienter.
Sehr interessant 👍 danke für den Bericht und deine Untersuchung!
Muss es mal mit ein paar anderen Games die Tage testen!
Werde aber wohl bevor ich irgendein Spiel großartig starte es erstmal auf die Grafikkarte einstellen und dann, wenn der Verbrauch und Spielbarkeit zufriedenstellend erscheint, das Spiel richtig starten.
Ähnliche Themen
