[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Mal schauen was AMD heute Abend zu bieten hat.:angel:
Was ist eure Einschätzung zur RX 7xxx Serie .?:asthanos:
Ich finde es lustig wenn alle immer AMD als Heilsbringer sehen wenn Nvidia nen guten aber teuren Klopper raushaut.
Dann hoffen alle das AMD viel günstiger anbietet.
Tun sie nicht (Siehe AMD CPU's vs Intel). Wenn AMD mit dem Preis runtergeht, würde es NVIDIA auch tun. Dann hätten am Ende beide eine niedrigere Marge. Hat auch mal der XBOX CEO gesagt als er gefragt wurde ob er einen preiskampf mit Sony anfangen möchte. Ich glaube eher Nvidia und AMD sitzen teilweise gemeinsam im stillen Kämmerlein um Pläne zur Ausbeutung der Käufer zu schmieden.
Zur Leistung. Für mich sind die Karten bisher uninteressant gewesen. Mag sein, dass sie eine gute Effizienz in Rasterization haben. Aber was nutzt es mir die Leistung nur bei Games zu haben die 10 Jahre alt aussehen.
RT und DLSS 3 ist ein mächtiger Schritt für die Spielegrafikrevolution. Man kann nun die volle Pracht mit zu niedrigen Frames x2 beschleunigen.
Kurz gesagt. Mich interessiert nicht was die raushauen da sie NVIDIA diese Runde schon mal gar nicht toppen können.
Jedem das seine. 😎👍
@X Cellence Thumbs up für "The Ascent" echt mein Überraschungshit der letzten 12 Monate. Den DLC fand auch auch klasse.
Heute Morgen habe ich E-Mail bekommen das meine ASUS TUF in Braunschweig bei Alphacool gut angekommen ist und nun vermessen wird. Da die 3080 schon einen neuen Besitzer hat, habe ich mir als Kontrastprogramm mal was kleines, schwarzes und stilles zugelegt.
IMG_20221103_162019.jpg IMG_20221103_163147.jpg IMG_20221103_163206.jpg Screenshot 2022-11-03 183829.jpg
Bin echt erstaunt. 4K/60 via HDMI auf dem LG C2, bisschen Forum surfen und parallel Netflix oder Youtube ca. 8 Watt Verbrauch.
Mh, da ist überhaupt keine Zugentlastung oder sonstige "Sicherheit" an den Pins. Der Adapter mag von der Farbe gefallen, aber ob der technisch gut ist? Sieht für mich qualitativ deutlich schlechter aus als der originale NVIDIA Adapter. Die Abstandshalter der Kabel werden wenig helfen, wenn Zugkraft auf das Adapterstück vorne kommt.
Die Farbe war nicht gewollt, gab einfach nur noch diese Variante ^^ Und Zugentlastung hin oder her, ich fahre nicht mit der Bahn! Spaß bei Seite, der Adapter macht für mich einen besseren Eindruck, da hier nix verlötet ist, sondern alle Kabel einzeln gecrimpt. Die Zuglast auf dem Kabel ist sogar geringer als beim Original, da es weniger wiegt... Fühlt sich für mich auf jeden Fall "save" an :)
AMD könnte flach spielen aber hoch gewinnen.
Man wird auf jeden Fall effizienter daher kommen und und preislich attraktiver sein. In RT wird man auf Ampere aufschließen in Raster eventuell sogar an NVIDIA ran kommen aber mal sehen....
Bin auf jeden fall gespannt. :banana:
Ich hatte mit all meinen 3090 Karten auch kein Problem. Aber mit all meinen 4090 Karten schon.
Ist auch egal welcher Treiber, Problem bleibt bestehen.
Was ich absolut nachvollziehen kann!!!
Bios mal upgedatet? Klick mich Allerdings ist die TXT falsch geschrieben, zumindest vor paar Tagen noch.
N4090GOL.f2.exe ist das OC Bios und N4090GOA.f2.exe ist das Silent Bios.
Probier einfach aus, je nachdem welches Bios du gerade aktiv hast, kommt beim Flash ne Fehlermeldung, beim Anderen funktioniert es dann. Möglicherweise haben die auch schon die TXT richtig gestellt, hab es jetzt nicht nochmal neu runtergeladen.
Danke, werde es mal testen. Kannst du bei dir einen Unterschied zwischen den beiden Modi feststellen?
Soooo… ich hab nun auch endlich eine FE abbekommen.
Frage an euch: muss ich alle 4 Adapter Stecker nutzen ? Oder reichen quasi auch 3 ? Denn mit 3 läuft sie …. Wenn ja / nein - warum (nicht)?!
Danke !
3 = 450 W
4 = 600 W
Ist das Spiel inzwischen problemlos Bugfrei spielbar? War wohl am Anfang extrem verbuggt wenn ich die Testberichte richtig in Erinnerung habe…
Selbst der Nachtest von Gamestar vom Januar diesen Jahres war noch voller teils recht massiver Bugs:
@ssj3rd Also ich habe jetzt den DLC im Oktober mit der 4090 auf dem 4K LG OLED mit 120fps gespielt und es hat mich einfach nur weggehauen. Für mich eine absolute Gaming Perle der letzten Jahre. Ich habe mich aber auch eingelassen das Ding mit (Stadia)Controller zu spielen. Ist ja ursprünglich ein dual-stick Shooter. War ungewohnt aber sehr geil wenn man sonst nur Maus/Tastatur gewohnt ist.
Anbei ein paar Screenshots von mir. Leider nur Standbilder, aber stellt euch das mal auf dem Desktop in 42" OLED und sehr hohen FPS vor. https://imgur.com/a/M63IShp
Kann mal jemand der auch Probleme hat mit Blackscreens, Monitor geht aus, Sound kratzen etc in Verbindung mit der 4090 folgendes probieren? LatencyMon laden und bei Twitch, Youtube, herumsurfen im Idle (die Graka muss im Idle Modus sein) folgendes probieren:
Dito. Dazu noch zwei Beobachtungen: Den letzten Fehler hatte ich laut Ereignisanzeige am Montag. -105 normaler Energiemodus. Ich hab auch so komische Frametime Spikes (aber ganz selten) bei SOTTR die ich mir bis dato nicht erklären konnte. Glaube die kommen auch vom takten (Game läuft meist nicht am Anschlag und Takt schwankt gut).
Liegt vermutlich auf dem Niveau der 3090ti.
21:00 Uhr wissen wir mehr.
Ja eben nicht, es kommt ja kein Testbericht/Review oder Ähnliches. Nichts dergleichen.
Wir dürfen uns wochenlang bis zum Release im Dezember alles mögliche zusammenreimen aus den Data Sheets die heute veröffentlicht werden. (Mehr kommt ja heute nicht!). Yay…
Das werden wieder „schöne“ Wochen voller Vermutungen und Ähnliches werden, bis dann endlich der klärende Test irgendwann kommt.
Habe es extra noch einmal getestet:
Mit 522.25 habe ich keine Probleme. Ich zocke RDR2 am TV und anschließend kann ich problemlos mit "WIN+P" zurück zum Monitor wechseln.
Kein black screen gebugge.
Bei CB hat auch einer geäußert, dass er mit 522.25 keine Probleme hat.
Ich wechsle zwischen meinem 48C1 und 77C2 und habe da manchmal auch einen black screen. Das war meine ich aber schon seit 522.25 so. Könnte sein, dass man da einen bestimmten Weg bzw. Reihenfolge einhalten muss. Habe das Gefühl, dass ich den C1 nicht ausschalten darf, bevor ich auf den C2 wechsle. C1 anlassen, C2 einschalten, dann auf C2 wechseln und dann C1 ausmachen. Aber ich muss es noch weiter beobachten :hust:
Auch wenn AMD nicht zur 4090 aufschließen kann, wenn sie eine 4080 wegputzt und 1000 Euro max kostet, dann verliert Nvidia ihre größte Käuferschicht diese Gen an AMD denn eine 4080 kaufen wirklich nur ahnungslose Idioten. Und eines ist bei AMD sicher: Sie werden nicht so einen lächerlichen Fehlstart wie Nvidia die letzten 3 Gens hatte haben wo bei Release die Speicher zu heiß werden, die Pcs herunterfahren oder die Adapter schmelzen. Und das sage ich als eigentlicher Nvidia Fan. Wenn Nvidia so weitermacht und Intel halten kann was es vorhat, nämlich sowohl im CPU als auch im GPU Markt die besten Produkte zu bringen dann kann sich Nvidia in paar Jahren von der Spitze verabschieden. Und Intel traue ich es durchaus zu, dass sie binnen der nächsten 2 Gens zu Nvidias zukünftigen Flasgships aufschließen oder diese schlagen können
Naja, falls AMD Balken vs die 4090 zeigen würde, und die wären gleichauf, weiß man zumindest, dass sie nicht schneller sind.
Anhang anzeigen 811650 Anhang anzeigen 811651 Anhang anzeigen 811652 Anhang anzeigen 811654
Und spulenfiepen?
3 Jahre halt, hat man bei Asus doch so oder so.
Jo, hab schon so lange nichts mehr Registriert, dass ich ganz vergessen habe das die Garantie 3 statt 2 Jahre beträgt.:rofl:
  • Haha
Reaktionen: hwk
Ich hatte ja auch das Blackscreen Problem was dann meinen Moni nach kurzem Flackern auf 85hz gestellt hat. Habe einfach den anderen Displayport der Graka genommen und paarmal aus und angesteckt und seit dem nie wieder...
