[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich glaube nicht, war bei mir eher Zufall. Ich hab eine Inno3D X3 OC gefunden nach der Arbeit zum guten Preis und der Block fürs Referenz Design war lagernd. Inzwischen ist ja glaub nichts mehr lagernd.
Gerade meine Gigabyte Gaming OC eingebaut und getestet. Wesentlich ruhigere Lüfter als die KFA2, die ich hatte und Spulenfiepen auf identisch leisem Niveau. (Evtl. die Gigabyte sogar noch etwas leiser. Das Rasseln nehme ich hier gar nicht wahr) Was mir jedoch aufgefallen ist, ist, dass sowohl OC- als auch das Silent-BIOS sich scheinbar gleich verhalten. Lüfter gehen auf ca. 1800rpm hoch und halten 65 Grad. Ist der Default das OC-BIOS? Laut Kartenbeschriftung müsste es so sein. Kann jedoch keinen Unterschied zwischen den beiden feststellen. Lässt sich irgendwie herausfinden welches BIOS gerade rennt?
Auch neugestartet wenn du umgeschaltet hast? :)
Gigabyte aero oder hof😆
Oder ne weiße strix wenn asus die auch für die 4090 bringt
Was geht denn so am OC bei der FE? Ich hoffe, dass ich unter WaKü da stressfreie OCen kann.
Mehr als 2880MHz bei 1.1V nicht machbar (damit meine ich game stable und nicht 4min 3dMark), unter Wakü vllt 30MHz mehr. Würde mir keine Wunder erwarten. Liegt aber nicht an der FE, sondern einfach Chiplotterie.
Bei meienr 3090 gab es halt einen enormen Unterschied zwischen LuKü und WaKü. Aber ja, die Kühler der 4090 sind ja schon total überdimensioniert
Ne die sind genau richtig 🙂
Ich hoffe man bleibt dabei.
Ich habe gerade meine 4090 Suprim X Liquid eingebaut. Es ist ein 600W Bios drauf!!!!!!
Das ist neu und normal sollten es nur 530W sein.
Es ist schon länger bekannt, dass MSI wenige Versionen der Liquid mit 600W Bios vertrieben hat. Die neueren Versionen haben alle 530W als Standard.
Eine Neuheit ist also weder die News, noch bedeutet es das MSI nun alle Liquids mit 600W Bios ausliefert.
Also die MSI Liquid ist auf jeden Fall die Karte mit dem besten Kühler. Die Waterforce mit dem 360 Radi war schlechter gewesen in den Temps
Passt eine 4090 eigentlich in ein Darkbase Pro 900 rein ? Hat jmd das Gehäuse ?
Na ja, Asus selbst nimmt 2210, die anderen Händler, wenn lieferbar, um die 2300, also nur 200 Scalper € darüber, dafür kann der Interessent dann 12 Monate ohne Zinsen finanzieren. ;)
Wer eine Graka finanzieren muss sollte sein Geld besser für andere Sachen aufsparen .
Man kann auch mit weniger zocken .
Bei mir 3060 Mhz mit 1,1V unter Luft, habe ja noch keinen Wasserkühler.... damit dann 3h das neue MW2 gezockt mit allen maxed out ohne Abstürze gehabt. Wahrscheinlich bissl Glück in der Chiplotterie gehabt. Andere Spiele ebenso um die 3000er Marke
Der ist sich aber ganz sicher, dass er bei jedem Drop eine bekommt :unsure:
Welche ist denn besser? Die TUF oder die Strix? Lautstärke vor allem? Die Strix sieht von vorne ziemlich häßlich aus imho.
KFA2 bei MM grad durchgeclickt (via Merkzettel gecarted weil der Cache der Artikelseite scheiße war) und bei Paypal abgebrochen, ging easy. Meine Abbruch Karte wird in ~30 Minuten re-droppen, könnt euch schon mal auf die Lauer legen (falls noch wer Interesse hat).
ich hab die im Warenkorb und konnte nicht zur Kasse, also alle 20s geklickt aber keine Chance...
Hat die noch jemand von hier bekommen?
Ähnliche Themen
Antworten
7K
Aufrufe
583K
