[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wartet hier noch jemand, auf die Netzteile mit ATX 3.0 oder auf neue 12HVPWR Kabel der älteren Netzteile? Ich habe eine Zotac RTX 4090 ergattert und liegt leider seit 2 Tagen rum. Ich traue mir nicht die Adapter die bei der Karte dabei liegt zu benutzen, wegen die Probleme.
Meiner Meinung nach wird zu viel Wirbel um den Adapter gemacht. Meine Karte läuft noch mit dem Adapter. Und nein ich kaufe mir kein Kabel ich warte auf das Be Quiet Dark Power Pro 13 Netzteil, das sollte dann auch schon ATX 3.0 haben.
Ich werde das cablemod Kabel nutzen und dann voraussichtlich den 90 Grad Adapter. Oder ich komme auf die Idee ein 3.0 nt zu bestellen
Also stellst du deine Hardware selbst her?! Oder kaufst sie doch weiterhin bei einem der „widerwärtigen“ und „ekeligen“ Händlern?
Denn die machen gerade ausnahmslos (!) das Gleiche!
Hui Äpfel und birne..
Und mit den Adapter hast du keine Probleme? Dann hast du ja Glück gehabt 🙂
Was ja definitiv nichts gutes ist und ein absolut verachtenswertes handeln darstellt!
Ich finde du übertreibst. Die Karten gehen problemlos woanders für weit über 2500€ über die Theke oder von der einen Hand in die andere.
Wenn jetzt hier ein weitaus anderer Preis aufgerufen worden wäre - okay… dann wäre ich bei dir. Aber das finde ich ja nahezu noch human. Stell dir vor du willst genau die Karte, zahlst 100€ weniger und die Lüfter sind beispielsweise am rattern wie ne Eisenbahn, was der User ausgeschlossen hat.
Nein, ich habe den zuerst auf die Grafikkarte gesteckt, dann die Kabel vom Netzteil angeschlossen. Gebogen auch nur bisschen.
Und ich weis nicht wie viele Tausend 4090 inzwischen verkauft sind, bekannt sind eine Handvoll Probleme mit dem Adapter. Heist doch der großteil hat keine Probleme.
Ich will nicht sagen das der Adapter perfekt ist, das ist er nicht. Aber das Problem wird größer gemacht als es ist.
Ist und bleibt wohl Ansichtssache wo jeder persönlich seine Linie zieht…
Aber Scalper und scalpende Händler zu verteidigen muss irgendwie jetzt auch nicht sein, schönreden kann man sich aber wohl alles. 😕
(PS: und bei 100€ mehr hätte ich wohl nichts gesagt, aber er hat ja 300€! mehr aufgerufen, er selber hat sie ja für 1949€ geholt, hat er mir selber per PN gesagt, kann gerne ein Screenshot als Beweis liefern.)
Auch wenn mein Adapter eventuell fehlerfrei ist ich will den Oktopus weggeben unter der graka 😅
@Naennon und @***** sind beides alte Hasen aus dem Forum, ist doch in Ordnung wenn die beiden sich einig sind.
@ssj3rd : Bei ***** finde ich jetzt nicht so dramatisch . Finde es eher hart wie FAG von manches missbraucht wird nur nach eigener Ansicht die Karte nicht den Vorstellungen entspricht . Da braucht man sich auch nicht wundern warum in DE Hardware so teuer ist und Händler die Preise anheben bei solchen Menschen .
CSM enable … bringt den Splashscreen wieder.
Aber das Windows Bootlogo statt Asus bleibt dann natürlich.
Ich hatte 8 Strix.
Keine davon ein OC Wunder und keine davon ohne Spulenfiepen inkl. Rasseln.
Kann die Strix absolut keinem Empfehlen! Schade .. ist aber so!
Bei den TUFs sieht es nur etwas besser aus.
KFA2, Palit, Zotac waren alle zumindest was Spulenfiepen angeht leise.
Gigabyte Waterforce hab ich noch und die FE beide sind bis jetzt TOP aber mit dem Radiator kann ich nicht anfreunden auch wenn die Pumpe relativ leise ist. Die FE hat leider im OC auch Spulenfiepen wird mit WB sicher schlimmer. UV mit weniger Takt ist sie aber OK.
Ich habe noch 2 Karten die aktuell unterwegs sind (weitere TUF und Gigabyte Master) aber vorerst habe ich genug gesehen. Die Karten die ich hatte, hätte ich keinem weiterverkaufen wollen. Entweder ich habe sie selbst deutlich über UVP gekauft oder sie hatten meines Erachtens definitiv Mängel (Im Sinne Spulenfiepen des Todes)!
Retouren ohne Ende :
Ich konnte es nachvollziehen, deine eigene (persönliche) Rechnung, heißt nicht das ich sie gutgeheißen habe…
Aber egal jetzt, kein Bock mehr zu diskutieren. Ich finde halt scalpen Scheisse, egal aus welchen gründen, egal wer es begeht und warum. Punkt.
Tldr: Scalpen ist Scheisse! 🙏
USB-Flashback mal das UEFI vom Board, vielleicht haste dir ein Beta-Bios mit Implantat eingefangen. :sneaky:
Bei dir, mein Freund, verwundert mich nichts.
Wärst du so schlau, wie du durch den Gebrauch lateinischer Wörter den einfachen Leser zu beeindrucken (oder zu täuschen :d) versuchst,
würdest du nicht so nen Quark von dir geben.
Bist du nicht daher selbst ein Oxymoron? Denn es gibt sehr viele Arten und Formen von Oxymora.
_________________
Feiertag, Sonne und es ist Popcorn-Time, was will man mehr. :LOL:
Wir leben in einem freien Land mit freier Marktwirtschaft "Angebot und Nachfrage reguliert den Preis"!
Könnte man hier nicht den Smalltalk Thread drauß machen?
Hier ist wenigstens was los und wenn die 4080er kommen, will ich auch hier drüber lachen können.
Ich hab sogar das ganze Board gewechselt … von Z690 auf Z790 oder meinst du das MB Flashbacks macht was mit der GraKa wenn eingestöpselt?
die HOF sieht lecker aus, was sagt TDP/TGP?
Yep, das ist echt krank. Und das alles nur für minimale Unterschiede, bzw. den E-Penis.
