[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ahja. Also mein System rennt ohne Probleme und ich wüsste aktuell kein Game das unbedingt ne 4090 brauch, aber gut du scheinst es ja besser zu wissen :lol:
Weiß ich nicht besser und muss ich nicht besser wissen, denn es ist mir egal. Allerdings war meine Aussage eher auf den Beta Tester bezogen. Den hättest du nicht lassen können. In Wirklichkeit wartest du halt weil du schlichtweg keinen Bedarf hast. Aber das führt sowieso zu nichts. Du machst das schon richtig.
Habe die Suprim storniert.... 500€ mehr als die FE sind mir am Ende doch zu viel.. :d
Diese Spontankäufe, wenn man nicht richtig wach ist, sind schlimm...
Insbesondere weil sie höchstwahrscheinlich pfeiffen wird
Wenn sie so Top war wieso hast du sie dann abgegeben? Geht mir einfach nur darum das es ein Outlet Modell ist und die Karte unter UVP angeboten werden müsste, also unter 1999€ für die OC.
Das war eine 3080 und auch damals hatte die ein schlechtes Image. ;) Ich frag mich nur warum. Weil weniger Phasen evtl...
Hängt immer vom Game und den Settings ab.
Ich fühle mich nicht wie ein Beta Tester. In meinem Bekanntenkreis ist bisher nichts von Problemen bekannt. Kann gut schlafen nachts.
Nachricht gelöscht
Hat jemand eine Meinung welches von den folgenden Netzteilen gut ist für die RTX 4090 in Verbindung mit einem 7950X? Geplant ist dann Cablemod Kabel zu verwenden:
Corsair HX1000i (2022)
ROG Thor 1000W Platinum II
Seasonic Prime TX-1000
Warum gehst du nicht gleich auf ein ATX 3.0 Netzteil?
Ansonsten sind alle gleich gut zu gebrauchen.
Das Seasonic ist nicht zu empfehlen, es kann warschienlich nur 225W maximal pro 8-Pin ausgeben. Das Thor möglicherweiser auch. Beide haben zumindest keine Daisychain-Kabel mit 2x8-Pin.
Beim Seasonic gab es das Thema vor kurzem, das der 12VHPWR Adapter zwar 600W kann, aber das Netzteil nur 450W mit 2x8-Pin.
Das HX1000I hat Daisychain Kabel, sollte also 2x8-Pin auf 12+4-Pin gehen.
Wenn du allerdings einen 4x8-Pin Adapter nutzt, ist das egal :d Hast aber dann 4 lange Kabel rumhängen...
Ich selber würde auf dieses hier warten, wenn ich eines bräuchte:
309€ ist aber sportlich... (Vorbestellung)
Ich hab ja das Kabel von Amazon für 20 € gekauft.
Bei Ali ist es auch verfügbar:
Für deine 2K+ Karte holst du dir ein ungetestetes Billo Kabel von Ali? Whoa, Mutig Mutig....
Würd ich ja aber da gibt's doch bislang noch nichts
Doch:
Thermaltake ToughPower ist in 2 bis 3 Tagen bei Alternate Lieferbar.
Silverstone ist lieferbar (aber teurer)
Asus lässt die Netzteile bei Seasonic bauen, da kannst auch gleich direkt ein Prime nehmen.
Was für ein Theater ihr wegen des 90° Adapters macht. Zockt doch einfach mit dem alten Adapter und gut ist.
Wenn irgendwas passiert, dann lasst die Karte halt tauschen.
Ich kann mein case aber mit diesem beschissenen 4-pin Adapter nicht mehr schließen. Das cablemod Teil ist sinnvoll
Nochmal meine Frage dazu...
Das trotz Single Rail?
Wie gesagt Seasonic hat es selber so angegeben, das der mitgelieferte Adapter mit 600W falsch eingestellt war und nur 450W haben sollte...Das war allerdings ein anderes Netzteil mit 1500W...aber selbe Baureihe
Hin wie her ... ich hab das CableMod mit 4 x 8 pin zu 16 pin Kabel für Asus Seasonic bestellt.
Was ne FAIL Aktion von cablemod.
Gut, dass ich direkt pennen gegangen bin, nachdem der Witz-Countdown angezeigt wurde.
Kollege blieb wach und fluchte anschließend per WhatsApp :popcorn:
Zwei 8-Pin auf 12vhpwr
Drei 8-Pin auf 12vhpwr
Ich würde bei Single Rail das zwei auf 8-Pin kaufen. Macht keinen Unterschied.
Und bei Multi Rail wäre fraglich, ob das bei 3 oder PCI Stecker sich nur auf zwei Rails verteilt, dann macht es auch meinen Unterschied.
Mit meinem Corsair AX1000 gingen über 500w problemlos. 5 Mins und nix hatte gestunken :bigok:
War echt ne mega fail aktion, konnt mich heute um 10 noch für die 90 grad B Variante anmelden
Macht euch nicht verrückt wegen Netzteilen: Mein putziges 700W Teil von Seasonic kommt mit der 4090 + 5900X + AIO + zig RGB´s locker zurecht.
Habe extra auf Last getestet die ersten Tage und das sehr massiv und konnte meinen PC nicht zum abschmieren bringen (selbst 1200 FPS bei PUBG beim rumspringen im Hauptmenü, oder auch Quake RTX/Cyperpunk mit Psycho RT/Dying Light 2, Plague Requiem, Metro Exodus Enhanced).
Meine 3090er war da empfindlicher und hat durchaus mal ein Neustart provoziert (Lastspitze).
