[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
ModDIY Kabel für mein Corsair Netzteil ist bestellt, aber ich habe noch keine 4090FE...
Und selbst wenn ich eine 4090FE vorher bekomm..mit Adapter ist eh kein Platz um das Gehäuse zu zu machen, ergo der Adapter wird nicht gebogen :P
Haha und je nachdem wie oft er schon aus und eingesteckt wurde muss eine kleine Gebühr zahlen ^^
Okay, die Art von Humor verstehe ich nicht.
Die nehmen das nur als Verifizierung, dass Du Inhaber eines solchen Kabels (bzw. der Karte) bist. Ob das Ding verbrannt da ankommt, oder nie Gebrauch war, ist doch ....-egal.
Wenn man denn überhaupt in der Lage ist einen zu erhalten, wegen künstlich verengter Verfügbarkeit. :fresse2:
Ja, du musst auf den Austausch dann zwischen 4-8 Wochen warten^^......übel nur, dass ich mir alles vorstellen kann, nur nix Schönes
9? Kannst du die mal aufzählen?
Für mich wäre das #6 oder #7.
Hab ich hier im Thread schon gemacht ab Fall Nr 4 hab ich die Beiträge dazu geschrieben mit Link zur Quelle .. is also schon alles hier im Thread zu finden.
Mit unseren Luxxer ( der sich ja nich mehr dazu äussern wollte ) sind es 9 und ohne unseren Luxxer 8 Fälle bisher .. aber 1 Fall allein reicht ja schon
wir können nur Froh sein das bisher nichts weiter passiert is ausser etwas schmoren ... hoffentlich verliert einer Seine Bude deswegen nich oder schlimmeres
da man ja nich immer am PC is wenn der grad läuft.
kurze Frage zu UV
meine Karte lässt mich nicht unter 875mv gehen?
sobald ich 850 oder 800 einstell crasht alles
/gibts eig schon nen 4090 UV Thread?
Hab noch keinen Thread gefunden, hätte da auch ein paar Fragen.
In Afterburner kann ich die Kurve bis 700 mV bearbeiten, das regelt das BIOS aber höher.
Liegt halt satte 300€ über den Asus Webshop Preis, ist schon extrem frech. Aber dachte eigentlich auch, dass selbst die Teile weggehen wie warme Semmeln...
Hat die Asus TUF (Non OC) eigentlich einen Drei oder Viezack im Gepäck?
Was in der Kiste liegt habe ich nicht herausgefunden, die Karte lässt sich aber angeblich mit der Vierer-Peitsche auf 600 Watt betreiben.
ja das ist ja das Problem, ich sehs im Afterburner auch bis 700, aber wenn ich weniger einstell, gibts nen crash
Viel Spaß damit. Berichte mal wie sie klingt, ob z.B. die Lüfter irgendwie komisch sind, oder ob sie gar flüsterleise ist
Die 4090 TUF non OC aus dem ASUS eShop diese Woche waren übrigens keine Rückläufer. Kumpel hat eben seine bekommen und alles versiegelt und unbenutzt.
Macht also Hoffnung das ASUS eShop ab und zu doch noch neue für 1949€ rein bekommt.
Gibt ja auch noch solche Fälle…
hatte bei meiner TUF Bestellung (Asus eShop) z.B. die Sendungsannahme verweigert.
DLSS 3 , da wird doch die Anzahl an FPS durch gerenderte Bilder zwischen 2 Frames gepush.
Schau mal ob du das ganze auch noch al Variante ohne DLSS3 findest, wenn es um die pure Leistung geht.
Steht doch in der Grafik die Leistung ohne DLSS...
4090 // 74,7 FPS
4080 // 66,4 FPS
3090 // 43,3 FPS
usw.
Bezüglich Gainward Karten...
meine Phantom läuft derzeit mit 2580@875mv im 10. exodus loop ohne probleme
coil vine in games bisher nicht vorhanden, identisch zu meiner alten EVGA die auch unhörbar war
der Lüfter macht leider irgend ein leichtes eigengeräusch, das hab ich bisher noch nie gehört, werd am Abend nochmal genauer hin hören (wenn ruhe einkehrt), aber es ist nicht nur das luft Geräusch
Vielleicht hilft es ja die Aufkleber von den drei Lüftern zu entfernen...?
Wie lang ist sie im Einsatz?
Hast du übertaktet und das TDP Limit angehoben?
3-Zack oder 4-Zack?
seit 17.10.2022 13:27Uhr
17.10.22: Stock + OC Benchmarks
18.10.22 bis einschließlich 19.10.22: auf Stock 48h durchgängig im MSI Kombustor um die Spulen zu ölen
ab 20.10.22: Faulpelz UV = PL 70%
Nvidias Zorn ist im Einsatz = 4-Zack
Seitdem 20.10.22 3 bis 4 Std. am Tag Kingdome Come Deliverance @4k 120Hz
Metall, 3 Jahre Garantie, endkundensupport,
Ist das aktuell ekelig eine Karte zu kaufen die man will !
Diesen Ganzen Zotac Kramm will ich nicht :fresse:
Die TUF ist einfach awesome. ich ziehe die der Strix vor. Vor allem jetzt bei der 4090 da der Unterschied kaum vorhanden ist. Aber TUF einfach hochwertig verarbeitet ist. Die Serie an sich ist nicht schlecht.
Es haben ja viele hier die 4090 mit Riser Kabeln im Einsatz, welches nehmt ihr da um die volle Bandbreite Fehlerfrei übertragen zu können? Habe mit den meisten nur bei PCIE3.0 noch Fehlerfrei bei PCIE4.0 fängt er an Fehler in der Systemsteuerung zu schmeißen und die Bandbreite zu drosseln.
Ist die TUF auch der Strix vorzuziehen?
Ich denke bei vielen ist es auch eine Frage der Optik. Mir wäre die Stix auch lieber weil sie meiner Auffassung nach am „schönsten“ ausschaut von den in Deutschland erhältlichen Modellen.
Allerdings ist das Teil auch mit Abstand am teuersten. Und nur um ein „schöneres“ Layout zu haben ein paar 100€ mehr zu blechen… irgendwo hört auch der Spaß auf.
Von LINKUP auf Amazon.
Hat aber ne Weile gedauert mit deren Chargen...das dritte jetzt läuft einwandfrei auf PCIe 4.0 Specs
EDIT: Das dritte ist jetzt seit 15.02.2021 im Einsatz
Geschmacker sind halt verschieden, ich finde außer der Gainward Phantom (schön schwarz) alle 4090 sehr unschön.
Haben die einen Optischen Unterschied oder gibt es keine möglichkeit zu erkennen ob das eine Charge ist die funktioniert?
Ähnliche Themen
